Question about Gateway FPD2275W LCD Monitor
All of a sudden the monitor resolution on my Gateway FPD1975W monitor is off. I am not given the option for 1440 x 900 as recommended. Icons are huge, screen saver is distorted. Was fine before.
  • Anonymous Mar 23, 2009
    After going through some troubleshooting with a tech at Gateway,including reinstalling the video drivers, I was told I'd have to reinstall Windows (Vista). I am not about to do that. I can live with the distortion if I have to. Thanks for your responses, though.
  • caller4dance
    caller4dance May 11, 2010
    You may be in "Safe Mode". If this is the case, something has occurred that caused the computer to crash, or create an unstable software or hardware condition that the operating system "felt" that normal oprerating conditions were not stable enough to continue "as-is". The operating system puts itself into "Safe Mode" until the problem can be fixed (by you.) Depending on your operating system, reboot your system and look for the start menu, arrow down to normal (the mouse will not work at this point) and hit the "Enter" key. It should work from here.
    If you are not in safe mode. Somehow, the monitor or video video card drive has been lost or corrupted. In that case, you simply have to re-install the drivers. I can help you, but I need to know what operating system you are using and some aditional specifics about the hardware you are using.
  • 558 Answers
Caller4 dance has the correct idea most likely the computer needs a video adapter driver installed or even an agp bridge depending on the OS and the motherboard type, it doesn't seem like a safe mode issue because windows restarts on Normal when it reboots in an error situation. let us know how it turns out.
Posted on Mar 22, 2009
My FPD1975W blinks off and on. the power light never goes out though. The monitor was given to me by a friend so that i could have 2 monitors on my windows 7 delll optiplex 760.
The problem is in the power supply inverter board module, often caused by bad capacitors. If you are handy with a soldering iron an attempt at repairing it can be made or replace the board. The other option is get a professional estimate to see if it can be done at a reasonable amount.
Jun 07, 2011 | Gateway FPD1975W 19" LCD Monitor
I havew a gateway FPD1975W monitor and I can not get it to fit the screen correctly. It stretches outside of the screen.
You need to set your PC video resolution to the native resolution of this monitor: 1440 × 900 @60Hz.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Feb 15, 2011 | Gateway FPD1975W 19" LCD Monitor
How do I get my gateway fpd1975w tft lcd monitor to not stretch images images across the screen?
You need to make sure your computer's display resolution is set to 1440x900, which is the monitor's native resolution. Other resolutions will result in fuzzy displays or, as you're seeing, distorted images.
Right-click on an open area of the Windows desktop (that is, not over any icons), then select "Properties" from the pop-up menu. Click the "Settings" tab and you'll find a slider adjustment to set the resolution. If 1440x900 is not offered as a resolution, you'll need to upgrade your video card (or add a video card if you have a motherboard with integrated video). Most newer computers support that resolution, but some older systems may only go to 1024x768.
Thanks for using Fixya!
Oct 20, 2010 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD 1975W LCD monitor,on light blinking, but wont turn on
I will assume you have already try this monitor with other PC? You should also set the PC VIDEO output resolution to be at native resolution of this monitor, which is 1440x900 @60Hz.
Mar 29, 2010 | Gateway FPD1975W 19" LCD Monitor
Dont have a driver for itis one needed for mon
You do not need the monitor driver to use monitor, but you do need correct driver for your video card, but if still want the driver, here they are: http://support.gateway.com/s/MONITOR/7005574R/7005574Rsl.shtml
Just make sure to set the video resolution of your monitor to be at native resolution 1440 x 900 (native)
http://support.gateway.com/s/MONITOR/6895R/6895Rsp2.shtml
Mar 14, 2010 | Gateway FPD1975W 19" LCD Monitor
My monitor blinks at random intervals at 1024x768 resolution but never at 800x600.
Your Video Card doen't support the 1024X768 that is why your first resolution is blinking and your second resolution is staying on.
Dec 06, 2009 | Gateway FPD1975W 19" LCD Monitor
Poor resolution
try and reinstall the VGA driver for your system i think it will solve this problem..........maybe the VGA driver is not installed?
Sep 01, 2009 | Gateway FPD1975W 19" LCD Monitor
Fpd1975w display flashes on and off
what resolution are you setting your screen to? if you are setting it too high or to a resolution/frequency that your monitor doesn't support, it will do this. Try setting it to 800 x 600 w/ 32 bit color and a frequency of 60Hz. If you do this and the monitor still blinks, you may just have a bad DVI cable.
Jul 13, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor appearance is short and fat
set the resolution to its native resolution 1440 x 900 this should correct things.
Oct 07, 2008 | Gateway FPD1975W 19" LCD Monitor
Gateway FPD2275W LCD Monitor Logo
55 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
