Question about Microwave Ovens
Jennair Microwave comunication error between UI and AM
Jennair microwave jmc813odds wiring diagram
Request a wiring diagram directly from Jenn-Air.
Jun 22, 2017 | Microwave Ovens
My JennAir went completely dead. It is probably 13 years old. Should I replace or have someone try to fix it?
Hello -
I cannot give you instruction on how to remove the kit(?) surrounding your microwave.
I can provide you with information which may help you decide if arranging for an repair technician authorized to service your JennAir microwave is the best option compared to replacing it. I refer you to the information from Angie's List:
https://www.angieslist.com/articles/microwave-repair-and-what-it-costs.htm
Best wishes.
Jan 15, 2018 | Jenn-Air JMC8100 Microwave Oven
Jennair JMC9158AA microwave not heating consistently - turntable moving, fanblowing - sometimes heats convection oven feature still working fine
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 08, 2010 | Jenn-Air JMC9158AA Convection Microwave...
What other stovetop will fit in the space ofr my Jennair C301? I can't find a replacement for it but have had granite countertops and don't want to have to cahnge them.
Contact Jennair (Maytag / Amana / Whirlpool) customer service here and ask if they have a "drop-in" replacement.
Jul 01, 2010 | Microwave Ovens
Jennair JMV8208BCS No instructions in box
Hello. the installation of wall mounting bracket is not too difficult. you will need a drill, some bits, and a scrrewdriver. you will also need an electrical outlet at that spot to plug in the microwave.
Jennair makes a bracket kit for each microwave. Call any jennair dealer, have your model # handy and they will get you the bracket you need, also ask specifically for the instructions.
Aug 12, 2009 | Jenn-Air JMV8208A Microwave Oven
Need to replace JMC7000 Microwave
Yours will likely have a bad high voltage diode, transformer or magnetron, all of which are covered under the extended parts warranty for five years from the date of purchase!
All you have to pay is labor, unless it's less than the two-year full warranty, then there's no charge.
That's a really great warranty!
It's on the back page of the owner's manual.
If you opt for replacement, Jenn-Air Customer Care can tell you which model would be a "drop-in" replacement.
Jan 06, 2009 | Jenn-Air JMC7000 Microwave Oven
JennAir JMC7000ADW Microwave Oven Not Heating Well
Assuming the turntable is working and the power at the outlet is correct (110 to 125VAC) then you almost certainly have a failing magnetron.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first: http://www.gallawa.com/microtech/mag_test.html (continuity can be good even though it is bad!)
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Nov 22, 2008 | Jenn-Air JMC7000 Microwave Oven
JennAir microwave JMC7000ADW lightbulb replacement
their is a panel up near the top on the right hand side of the interior cabinet just remove the screws and put in a new bulb
Jan 28, 2008 | Jenn-Air JMC7000 Microwave Oven
JennAir Microwave worked one minute then won't the next.
If this microwave is more than a couple of years old, it's possible that the magnetron tube or a rectifier has burned out. You'll probably need to take it to an experience microwave service technician to get a diagnosis.
Jan 16, 2008 | Microwave Ovens
Microwave Ovens Logo
46 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
