Question about HP Photosmart 2575 All-In-One InkJet Printer
When I try to change my ink cartriges the carriage will not move
I have to manually move the carriage to the right to change cartrige. This is supposed to automatically do this when I open the top portion of the printer.
  • 63 Answers
With the lid open, you will see the two arms that stick out of the lid, and go into the body of the printer, they are black. and on the far left and right of each side of the lid. They have Teeth on them like a saw. When the lid is closed, these go down into the printer, and hit a little micro button on the back of the printer. When this button is pressed, the printer knows that the lid is closed. I am guessing that this button has gone bad, so the printer does not know you have opened the lid, and therefore it does not move the print cartridges into the parked posistion.
Posted on Jan 18, 2009
Black Cartrige Missing
Did you use a brandname ink cartridge - or is it a knock-off brand? If it is a brand name - then the cartridge is most likely defective. If it is a knock-off brand - some printers do not recognize the electronic in the cartridge and therefore don't see it as one being installed.
This may also help
Dell 922 AIO Black Ink Cartridge Missing Message
May 02, 2017 | Dell AllinOne Multifunctional (v515w)...
My friend had a problem of his printer, cause the printer didnt recognize the ink... it has 6 colors epson ink. we dont know how to fix it... all the cartrige shows x
Is your friend use CISS. If so
Move Ink cartrige holder to cartrige change station.
Put off cartrige ( genuin or CISS) from carrage
Take a soft erager try to remove dry in or dust or waste everything smothly
reassemble the cartrige again
push top of the cartrige gentaly sothat it struck acurately.
Turn on printer.
I think you will get rid from your pprinter problem.
Thank you
Aug 21, 2011 | Office Equipment & Supplies
Canon printer ip4700 can't replace ink cartriges holder does not stop at the right place
force carriage to one side fully with power off, this might reset carriage sensor and get it to go back where it needs to be to change ink.
Oct 19, 2010 | Canon iP4700 InkJet Photo Printer
I have inserted both my blacl & colour cartriges properly but still my printer is showing some problem with my black cartrige
When ink cartridges get low they can dry out if you do not print that frequently. So try a new cartridge. Make sure that the carriage is clean, wipe down the copper contacts on the carriage under the black cartridge with alcohol. Also ensure that the cartridges themselves are not all coated in ink.
Dec 03, 2009 | Office Equipment & Supplies
The printer do not recognize the new replacement cartrige
I have many epson printer, some more than 5 years old. It's ok. some have printed more than 50.000pages, it's ok.
If Ink cartridge Unrecognizable, there are two posibilities : Chip Error at ink tank, or printer error. For chip error, try to plug the ink tank to another printer (same type). If the ink tank recognized by other printer, so the problem is printer.
So ;
1. Check chip conector at head carriage.
2. Check the wiring of the head, and chip.
If two point above is ok, the last action is check the power supply and board. It may be epprom is damage.
May 28, 2009 | Epson Stylus R380 InkJet Photo Printer
We reciently bought new ink cartriges and now when we try to print nothing is printed. There are no error messages on anything either....the paper just comes out blank. We also tried changing the ink...
Try reseating both ends of the printer cable.
Assure that there is nothing in the cartridge carriage to block the contacts and/or cause a seating issue.
Jidza
Jan 20, 2009 | Lexmark X5150 All-In-One InkJet Printer
Changing cartridge
Just above where you feed the paper there is a door - open it, wait for the ink cartriges to stop moving, to your right - remove and replace in the same way the cartrige you're replacing.
Jan 09, 2009 | HP Photosmart 4180 All-in-One Printer
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Apr 04, 2008 | Canon FAX-JX200
HP Photosmart 2575 All-In-One InkJet Printer Logo
75 people viewed this question
Ben Johnson
