Question about GE Spacemaker JVM1640SJ Microwave Oven
Exhaust fan does not have much "sucking" power
I'm thinking about venting the microwave exhaust to vent outside intead of inside. But I put a piece of paper up to the grease screen and it did not stay "sucked up" to the screen---not much pulling power. Is this a problem with the spacemaker fan?
  • Anonymous Feb 11, 2009
    I have the same problem, it does not **** any of the smoke or vapors, we constantly have to open every window in the house to air it out and the windows always have condensation on them.
MicrowaveSvc
  • 9086 Answers
SOURCE: Over Stop Microwave Vent Blower doesn't remove steam
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
The installation instructions are what you need.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
SOURCE: Outside venting GE Profile Spacemaker XL1800
Your vent flap could be taped or it could be faulty installation not allowing the vent to open. If you take the front vent cover off, you should be able to reach in above the fan unit and gently push the vent flap up, it should move freely with no binding. If it doesn't it is taped or blocked. If it is taped, gently putting upward pressure on the flap might release the tape. If that doesn't work the vent installation is blocking the flap. You might have to remove the unit from the wall (two people to do this) or disassemble the vent duct above the microwave and rework the interface for clearance.
hope this helps,
Posted on Oct 07, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Samsung otr microwave vent problem
Please call Samsung's Service Division at 800-932-3837.
If they cannot help you, they should be able to give you another number to call.
Posted on Oct 24, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: VENT NOT SUCKING
I would suggest checking the filters, checking the duct work (including the outdoor vent) and if that doesn't turn up the problem, the hood vent exhaust fan blade assembly may have come loose on the shaft.
You can download GE owner's manuals and installation instructions here to help you verify the filter status and duct work.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 28, 2008
woobie dog
  • 1273 Answers
SOURCE: My Micro vents into the kitchen instead of venting
The fans on an over the stove microwave can be rotated up to 180 degrees depending on how the installer intends to vent the hood. Your fan is pointed forward and venting into the kitchen through a charcoal filter. If you want to vent through the ducting and out of the kitchen, you'll have to drop the microwave down off of the mounting bracket and rotate the fans in the back, pointing the dicsharge upward for a vertical vent, or 180 degrees, if it discharges out the back (wall vent). In both cases, an adapter is necessary, and can be obtained at any hardware store.
Best regards, --W/D--
Posted on Aug 08, 2009
Exhaust fan vent not sucking in smoke
make sure the filters are not clogged with grease and oil. Try removing the filters to see if it works better.
Nov 28, 2015 | In Microwave Ovens
Emerson microwave mwg9115sl over heats then turns back on after 20 minutes
Your magnetron is overheating, which can be caused by:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
The first suspects in my book are fan failure, blocked vents, or bad magnetron.
Jan 10, 2013 | Emerson Microwave Ovens
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Screw/nail in microwave housing loud rattle when exhaust fan is on.
A screw that falls into it from the top should be in the vent fan in the top rear of unit. I think you will have to take the unit down from the wall, at that point, either remove the vent blower fan and shake it out, or turn the whole microwave upside down and it may fall out.
Oct 17, 2017 | Whirlpool GH7208XRS Stainless Steel 1200...
We have a Kenmore builin icrowave with exhaust hood over the range. The exhaust fan appears to recirculate the air into the kitchen and not sending it out. This causes the cooking smell to remain inside...
some fans have a charcoal filter that needs replacing others are supposed to be vented out side by the roof or out the wall to see if the vent is going outside you will have to unmount the unit tak it down and check and see if it is conected to a duct in the celing or through the wall hope this helps
Mar 09, 2011 | Kenmore Microwave Ovens
Oct 23, 2008 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave range hood install -- stud in middle of exhaust
You have a few options, First off, I am assuming that the stud you refer to is an outside wall. Assuming that is true, then you have a few options.... one of them is to cut thru the stud and run the vent out. Even if that stud is on a bearing wall ( meaning it is carrying a roof load above it) ... It is unlikely to pose a problem if that one stud has been compromised with it cut out, If that concerns you.. and you are handy, you can open that area of wall up from the inside and box the area that the vent will be located in with short pieces of 2x4 to the studs on either side of it... Another option is to vent the hood up thru the cabinet above and direct that out slightly offset to the stud in the wall..
One thing I have done is to cut the stud out and then to place a piece of 1/2" plywood in the area that the micro/hood will be located and attach that piece with drywall screws to the studs in the wall.. That piece of plywood will help support the stud you cut when you screw it to the adjacent studs and also act as a place to secure the hood mounting bracket on the wall. Granted, it shifts the hood out from the wall 1/2 " but then you have plenty of surface to secure the plate and don't have to worry about hitting a stud or using wall anchors.. I hope you understand my comments..If not...please respond to this and I will provide additional information to clarify this... Hope this helps !
Aug 13, 2008 | Hotpoint RVM1635 Microwave Oven
Exhaust fan
The fan pulls from the range top and either out those vents on top unless there is a vent in your upper cupboard. Then it is vented outside. Hope this helps.
Jan 07, 2008 | Maytag MMV1153A Microwave Oven
Exhaust problem
you got to have make up air from someplace! the microwave cavity is sealed so microwaves don't leak out. [door seal] why would you have a grease filter on a microwave? is this a combination range vent hood AND a microwave exhaust system?
Dec 29, 2007 | Maytag MMV5165 Microwave Oven
Kenmore microhood
"Microhood" seems to be a slang term for the "microwave hood" (hood fan or exhaust fan) which is normally part of an over-the-range microwave oven or range. But these should be available separately, as I seem to recall. I would contact home centers such as Lowe's, Home Depot (if they still exist), etc., or a local appliance store.
Dec 06, 2006 | Kenmore 62622 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
152 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
