Question about GE DWSR463EGWW Electric Dryer
My dryer starts, runs a few minutes, doesn't heat up and shuts itself off
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 16 Answers
Check your sensors on the heater unit, there are two or more, simply us a meter and make sure power is on both sides of the sensor, if not then that specific sensor is bad and you should replace it, pull the sensor and tie the two wire together to see if it will heat, if it does replace the sensor they are cheap and will keep you from burning down the house
Posted on Jan 01, 2013
  • 1073 Answers
SOURCE: Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Posted on Jun 11, 2008
SOURCE: Runs for 5 minutes then shuts off.
please contact the service authority because this is beyond your limit. to solve your problem, the back panel has to remove and only the service engineer knows the skill.......................sorry friend!
Posted on May 14, 2009
mreid542
  • 166 Answers
SOURCE: Heat shuts off after a few minutes
The model number listed above appears to be for an electric dryer.
Feel the top of the dryer right next to the backsplash. If this area in the middle gets extremely hot to the touch, then you have a vent problem. Check to make sure that your vent hose is not crimped or blocked in some way. don't use plastic vent hose.
Posted on Nov 15, 2009
  • 85 Answers
SOURCE: It starts and runs fine, heats up, but after 2-4
bad thermostat
Posted on Oct 19, 2010
Macmarkus
  • 2605 Answers
SOURCE: My G.E. gas dryer model
Hello, welcome to FixYa.
I'll start by saying your post indicates it is obviously a GE gas dryer and
you mentioned you do get heat intermittently, and the drum does turn correct ?
If this is a symptom where the unit at first begins to heat but the flame drops out in a matter of seconds or minutes I would be looking at the air flow (which you have done) or burner coils.
Once you've gain access to the coils you'll need to remove the wire harness and check the continuity.
Here's the tricky part though...many times they will ohm out ok when cool (not operating) yet as soon as there is current passing through the coil it "opens". The wire inside the coils is so fine that often it only takes a small current to "open" the circuit, thus after running for a period the valve closes and flame drops out.
Most times it will only be one coil that fails but it is good practice to replace them both, many places used to sell them in a kit so double check with your supplier.
As far as what part you may need and how to get it. There are a couple of places I prefer, on-line at "searspartsdirect.com" or "repairclinic.com".
This kit in the link I've attached it contains both the two wire and three wire solenoids. One solenoid is the primary and one is the safety. Both have to operate for the gas valve to open. Usually, one of them burns out as I said but you should always replace them as a set.
**unplug the appliance and turn off the gas supply before attempting any service...safety first**
The most common is part number 3449 at "repairclinic" as this link should provide you.
http://www.repairclinic.com/PartDetail/Gas-Valve-Solenoid-Set/5303931775/3449
Let me know how you make out or if you require further assistance and I'll do whatever I can. Thank you for your patience while I was away for a while. Good luck.
Regards,
Macmarkus :)
Posted on Jun 16, 2011
MY DRYER SERIAL NUMBER X073808040 STOPS AFTER 20 MINUTES
Kenmore Dryer - heats & runs but stops mid-cycle - Ask Me Help Desk
https://www.askmehelpdesk.com/.../kenmore-dryer-heats-runs-but-stops-...
Kenmore Dryer - heats & runs but stops mid-cycle. Asked Aug 30, 2006, 12:25 PM - 10 Answers .... Unfortunately it shuts off after a few minutes, I'll estimate about 5.After waiting about 30 minutes, ... New Member. Jun 16, 2010, 09:20 AM ...
Sep 15, 2015 | Dryers
Maytag dryer stops after few minutes
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle.
Feb 21, 2015 | Maytag Dryers
Dryer problem
You really should post your make and model number and any error messages you get if any , I would guess the heat sensor or timer. Here is a website where professional appliance repairmen will answer your questions. Hope that helps you.
http://forum.appliancepartspros.com/dryer-repair/112843-dryer-shuts-off-after-getting-too-hot.html
Jun 09, 2013 | Dryers
Hotpoint Condenser Dryer Shuts Off After 5 Minutes
what is your model number is then we can get started then okay
Feb 01, 2013 | Dryers
Bosch Axxis WTE86300US turns itself off after ten minutes, won't turn back on for a few minutes after that
I would bet you have a bad sensor. There are a couple of sensors that monitor heat. When it gets too hot they shut it down as a safety precaution. Once it is cool enough it will start up again.
Sep 26, 2012 | Bosch Dryers
Dryer won't continue to heat and doesn't shut off.
The coils on the gas assembly get IFFY with age. They work a little then get hot and quit. My Video
Jul 08, 2012 | Dryers
My dryer is getting so hot that it is shutting itself off mid cycle. I can restart but it only runs a short time....gets really hot and shuts off again!!
Check your entire vent tubing from the outside vent to the line coming out of the back of the dryer.
Overheating indicates low air discharge flow. The air in the dryer must move out quickly so the heat doesn't build up too much.
Try that & post back.
Gary
Sep 15, 2011 | Kenmore 600 6965 Electric Dryer
Dryer runs for about 5 minutes then shuts off the clothes are hot
Your vent may be obstructed causing the dryer to trip, once it cools down it will reset itself. The way to see if thats the problem is to disconnect the vent and run the machine, if it doesn't shut off, you will need to clear the vent.
May 13, 2011 | Kenmore Elite HE4 Electric Dryer
GE DWSR463EGWW Electric Dryer Logo
115 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
