When the STANDBY indicator
flashes
Immediately unplug the power cord
and check the following items.
• If your unit have a voltage selector,
is the voltage selector set to the
correct voltage?
Check the voltage for your region,
then make sure the voltage selector
is set correctly.
• Are the + and - speaker cords shortcircuited?
• Are you using the supplied
speakers?
• Is anything blocking the ventilation
holes on the rear of the unit?
After checking the above items and
fixing any problems, plug in the power
cord again and turn on the unit. If the
STANDBY indicator still flashes, or if
the cause of the problem cannot be
found even after checking all the
above items, consult your dealer.
B+ over voltage protection (OVP), unit goes to the standby mode then
displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
Have you set the output voltage correctly?
