Question about Atari Video Game Consoles & Games
I just purchased a new in box Atari 5200 4 controller system. I have hooked the cable to the switchbox and then connected the coax coming out of the switchbox to the ant. in on the tv - but all I get is a black screen - something is happening as it goes from snow to black, it just doesn't have any sound or video. Do the new tv's have something in them that won't play the video or sound?
    Master:
  • Atari Master
  • 330 Answers
Best way is to hook it to vcr the vcr will help with the video and sound to work
Posted on Feb 10, 2015
ROBOTKING
  • 14 Answers
SOURCE: how to hook up an atari 5200
THERE ARE 2 TYPES OF 5200 SYSTEMS, THE FIRST HAS A COMBINATION A/C R/F BOX. OTHERWISE YOU MAY JUST NEED AN ADAPTER TO CONVERT THE RCA END TO CABLE TYPE SCREW ON TO YOUR TV CABLE IN. SEE MY STORE ON EBAY dixneatoldthings for that piece
Posted on Sep 30, 2007
kman203
  • 99 Answers
SOURCE: XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Posted on Mar 21, 2008
RescueTechLA
  • 2653 Answers
SOURCE: my tv get snow when i try to play a game
Try using another TV. If you don't get the same problem then it's the TV and not the PS3. You might also want to try changing the display settings so that you're using the correct outputs.
Posted on Feb 20, 2009
SOURCE: PS3 flashes white snow for only 1-2 sec. during gameplay. Is there a fix?
I also have the same problem. Just bought my PS3 today and have found that it flashes to static for a few milliseconds at any given time. I know it isn't my TV and I also know that there is nothing wrong with the console. I put it down to the HDMI cable - I chose an exceedingly long one that spans 5 meters. Personally, I think that the output voltages from the PS3's HDMI jack are lower than those found on other devices - so I presume that long cables with high resistances (in other words, cables that are fairly long and very cheap) are the cause of signal loss. Try a shorter, higher quality cable. I am going to return the one that I bought and buy a shorter one tommorow.
Posted on Mar 07, 2009
NES Gamer
  • 19 Answers
SOURCE: connecting intec gamecube screen
The Intec Gamecube screen requires both a 12 volt DC input and the AV input. The larger connection is the AV cable which plugs into the back of the Gamecube console. The smaller round cable is the 12 volt DC input cable that goes to the power source for your screen. The solution is to either get the original splitter cable that splits the DC power to the screen and the Gamecube, or use separate 12 v DC inputs for each device. These original Intec splitter cables are rare and are not cheap, and the only place I have found them for sale is at the NES Repair Shop:
http://nesrepairshop.com/online_shopping/index.php?productID=645
The only other solution is having separate 12 v input cables for the screen and the Gamecube. And finding the right size (very small) is also a task.
Posted on Sep 19, 2009
Does the Atari 5200 have the same controller as the Atari 2600?
It does use a slightly different controller. The joystick that comes with the Atari 5200 has 360 degrees of control while the Atari 2600 controler only give you 8 ways of motion. Teh 5200 also has a number pad and buttons for start, pause and reset.
Dec 16, 2013 | Video Game Consoles & Games
How to hook up my atari
It hooks up to the coaxial jack on the back of the tv ( antenna jack )
you will also have to get a Manual TV/Game Switch Box with Coaxial Output or a 300 to 75 OHM matching transformer or a coaxial (f-type) to female rca adapter. You can also just splice a coax cable to the Atari. There are also a converter box that will convert a coaxial input to RCA output ( Yellow,red,white) cabels
Dec 27, 2012 | Atari 2600 Console
I have recently purchased an atari 2600 that came with no rf cable. I understand that using the female phono to male f adapter will work to hook it up, but this leaves me needing to buy the phono cord...
Yes, I know this works because I have done it. I believe both types of cable are the same impedence but different ends so any combination should work. Cheers.
May 14, 2011 | Atari 2600 Console
What do i need to buy to get it to work on my new tv
How to Connect Your Old Videogame System rca_cable.jpgIf you've just dug your old videogame system out of the attic, you might not remember exactly how to connect it. They're not quite like modern game systems, and may require something extra to connect it to that brand new TV you have. To the left is the cable you should see attached to your videogame system. It is typically called RCA, and you will have to use some sort of adapter before you connect it to your TV. While it looks like it should fit into one of the composite jacks (and it will actually fit), that will not work because the audio and video signals are being carried in the same cable. In order to use the composite jacks on your TV, you will have to separate the audio and video signals somehow (described below). The following instructions are relevant to most vintage videogame and computer systems that connect to a television. Specifically, the Atari 2600, 5200, and 7800. However, if you have the 4-port (four joystick ports) version of the 5200, you need a special switchbox. Try eBay or Best Electronics (catalog item) for this proprietary switchbox. If you have the 2-port version of the 5200, you can use the methods described below. coax_jack.jpg composite_jack.jpg Coaxial CompositeThe first thing you need to do is figure out what type of connection you're going to make. Look at the back of your TV and compare to the pictures to the left. It's much easier to connect to a coaxial jack, and this is what most people will do. Composite will give you better audio and video quality, but you must perform a hardware modification.
Coaxial
Coaxial (F-type) to Female RCA Adapter
Radio Shack part #278-276
Manual TV/Game Switchbox with Coaxial Output
300 to 75 Ohm Matching Transformer
Coaxial is by far the easiest way to connect your old game system, and the method most people will use. This is the 'cable ready' input that is found on every TV made today (and for some time now). If you don't at least have this connection, you have our sympathy. There are several methods you can use for this connection.
The best way is to get a Coaxial to RCA adapter (left). It is cheaper, smaller, and provides a better signal than the traditional TV/Game switchbox. This is a small plug that will cost you about $3 at Radio Shack. It is called a "Gold-Plated Phono-to-F Adapter" and the Radio Shack part number is 278-276. Just connect it to the RCA cable of the game system, then plug the other end into the coaxial ("cable") jack on the TV. Set the TV to the channel that the game system is set to (usually 2-4), and your're ready.
If you still have an old TV/Game switchbox and you don't want to buy something new, you can use that. You can also purchase these at Radio Shack for about $5, but if you're going to go buy something we recommend the adapter described above. Some TV switchboxes have built-in coaxial output, some do not. If yours does not, you will need to buy a 300 to 75 Ohm matching transformer (again, about $2 at Radio Shack). If you you do have coaxial output on your switchbox, just plug the game system's RCA cable into the switchbox, connect the switchbox to your TV's coaxial ("Cable In") jack, and push the switch to "Game" or "Computer". Note - you cannot use the 'automatic switching' boxes that newer game systems like the NES use - the signal in most old systems is not strong enough to trigger the automatic switching, so be sure you buy a manual switchbox.
Most new TV/Game switchboxes will allow you to connect your Cable TV and Videogame system at the same time, but the picture is often less than ideal. We recomend a coaxial selector - this will allow you to choose between inputs (game, cable, whataver) at the touch of a button. We found this one at Parts Express for about $6.
av_switchbox.jpg AV Switchbox
Composite composite_jack.jpgAny way you slice it, generating composite output takes more work. How much more depends upon exactly what you want to do. To get true composite signals, you will need to be handy with a soldering iron and modify your Atari 2600 internally. If you've never soldered anything before, it might be a little tricky, but it's worth it for the clean signals! You may also notice that modern equipment has left and right audio jacks - this is for stereo sound, but you can't get stereo sound from your 2600 unless you make further hardware modifications. So if you make the mod, you'll just have one audio cable in use. vcr_composite.jpgNow if you don't want to do that, but you're using a monitor or tv without a coaxial input (for example, a Commodore monitor), there are other options. You will still have to convert the signal to coaxial first (see Coaxial section). Then, if you have a VCR handy, you can run the coaxial connection into the VCR, and then use the composite outputs from the VCR. This will not give you the true signal clarity of composite audio/video, but it will allow you make that composite connection. If you don't have an extra VCR for this, you can probably go buy a junker at the local thrift store - the tape mechanism doesn't need to work, just the demodulator. Demodulator's rarely go bad on VCR's, they're usually thrown out because of the tape mechanism. Speaking of demodulators, you can simply use one of these instead of taking up all that space with a VCR. Unfortunately, these are much more expensive ($100+) and you're not likely to find one in a thrift. Unless you're going to make a hardware modication, we really recommend using a straight coaxial connection, because going through a VCR/demodulator defeats the purpose of a composite connection.
Feb 15, 2011 | Atari Video Game Consoles & Games
ATARI 2600
Honestly, good luck.
But...
Someone's already tried it:  http://www.geocities.com/atari7800mod/hookup.html
I'd love to hear if you get this to work.
Apr 01, 2009 | Atari 2600 Console
Set up
The specs I am reading online are saying that it has digital coax connection. If your hooking up hd cable or hd satellite box some of those have a digital coax output on them. If your hd cable/satellite box only has optical out the system you have says it comes with a optical to coax converter which is pretty cool. So you should definately be able to hook up that sound system to your cable/sat box digitally for best sound. The only other way would be to run stereo red,white cables from your cable/sat box to your stereo as a last resort.
Nov 09, 2008 | Philips LX3950W System
Atari 2600 Jr. Video Issue
You can't run a 2600 on composite. Even though the connector looks the same it isn't. You need a RF modulator to seperate the signals and you need an old school one that has a manual switch on it. Check at Radio Shack they carry things like that.
Modulators with AV jacks like I use for watching my DVD on when I only have a coax on my television won't work becuase the atari line doesn't separate the signal outside the box by audio and video. That wasn't something being done 30 years ago. In fact it wasn't being done until NES came out.
If Radio Shack doesn't carry it you can probably find one on E-Bay.
You can always find classic Atari 2600 games for your PC. I know I play the Activision Games that way from time to time.
Good luck on that.
Jun 17, 2008 | Atari 2600 Console
Hooking up to digital cable box
Darth,
There are 2 ways you can accomplish this.First is the least quality which is via coax.What you want to do is connect the cable service coming from the wall to the input on your cable box.Then the TV output on the cable box goes to the input on your surround sound then the coax goes from the surround sound to the coax input on the TV.The second is to Connect using the RCA AV1 input.what you want to do is look at the back of the digital cable box and locate the OUTPUTS for the RCA jacks(or AV output)connect RCA cables (yellow red white) to the 1st INPUT on your surround sound.depending on models you should have a couple of different INPUTS for a signal.Choose one and plug it in.After that take a second pair of RCA cables and connect them to video OUTPUT on the surround sound and connect them to your AV1 OUTPUT on your TV.With the original remote for your TV,NOT the cable universal one,Look for an INPUT button on the remote.Some are called input some are called SOURCE,TV/VIDEO basically it tells the TV what signal source to look at on the back of the TV.If you dont have the remote put the TV on channel 3 then press the channel down button and when the TV gets to channel 1 press it again and it should start cycling through the AV inputs,choose AV1.
Once you have done this you have correctly
hooked everything up,BUT Like I said depending on the model of surround sound you are going to have to CHOOSE or physically select or "tell" the surround sound receiver which input to RECEIVE the sound through.In general the INPUT on the back of the surround sound will be labeled with something like Video IN,VCR IN, DVD IN and so forth.Make sure the surround sound is selected to Receive the sound coming from the digital box.Sometimes there is a dial on the front of the surround sound that allows you to select which INPUT on on the back becomes active .make sure that what you have selected matches what you have your cable box is connected to.Hope this helps!
Nov 03, 2007 | Pioneer HTD-510 System
How to hook up an atari 5200
Sep 30, 2007 | Atari 7800 Console
Video Game Consoles & Games Logo
83 people viewed this question
Top Atari Video Game Consoles & Games Experts
Hanzu
Reggie brown
MegaByteMe
MegaByteMe
Are you an Atari Video Game Console and Game Expert? Answer questions, earn points and help others
