Question about Huffy Cycling
I need to raise the handlebar height on my 26" bike.
There are so many screws and the owner's manual doesn't give me instructions on which screw needs to be loosened to raise it!!! Its a coaster brake model - - any ideas?
    Scholar:
  • 141 Answers
On the neck, the bolt would be at the top, dead center, screwed down inside the neck. Loosen it about 5 full revolutions. Then take a hammer and tap it back down. Lift the handlebar to desired height, and hold it there 'til tight. Also while it's a little loose turn it clockwise/counter clockwise, to make the bar straight (while holding the front wheel) before fully tightening. Then your done! Glad to help. Best wishes to you.
Posted on Jan 22, 2009
How do you change the height of the saddle and handles?
There are adjusting pinch-bolts and screws & nuts on the bicycle for you to loosen where the seat rod and the handlebar shaft attach to the bike.
Older bikes took tools, some newer ones have "quick-release" locks you can do with you fingers alone.
God bless your efforts.
Jul 31, 2017 | Cycling
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
How to raise handlebar
Open the Allen screw in the center of the handlebar stem by about 2-3 turns, then wiggle left and right until you have the proper height, retighten screw
Mar 12, 2015 | Mongoose 2008 Teocali Comp Mountain Bike
Aseemble a coaster brake on a bicycle
Ken, Check the attached links,instruction and guides on removal and install coaster brake. Good luck
Coaster Hub Overhaul Pedal Brake Hub
How To Install Cog On Coaster Brake Hub
Bicycle Coaster Brake Repair and Service
Oct 01, 2014 | Husky 26"" x 2.125 Industrial Chrome...
I have a 20" inch girls kent trouble bike. How do I take the rear wheel off?
remove the coaster brake lever bolt. This is small bolt that holds the coaster brake lever to the left side chain stay. There will probably be a strap wrapped around the chain stay with bolt going through the strap and the lever. This usually requires a 10mm wrench (sometimes it is 8mm) for the nut and a Phillips or flat head screw driver (some times it's another 10mm bolt head).
The axle nuts are usually 15mm nuts. Loosen these (they usually don't need to be removed all the way) and push the wheel forward to put some slack in the chain. Lift the chain off the rear cog and you will be able to pull the wheel out of the drop outs.
To install, slide the wheel into the dropouts, put the chain back on the cog, pull back on the wheel and tighten the nuts finger tight. Reinstall the bolt through the coaster brake lever and then tighten the axle nuts, pull back on the wheel while tightening the nuts so the chain is tight. Then tighten up the coaster brake lever bolt. (if you tighten the axle nuts first, you won't be able to move the coaster brake lever into place to get the bolt in)
Aug 18, 2014 | Cycling
When using the drywall screwgun the drill bit comes out and sticks in the screw after every time I drive in a screw. Why doesn't the bit stay in place in the drill? Why does it come out and stick to...
Because the tip is brand new or you don't have a magnetic ti. Try tilting the gun a little sideways before you pull it away from the screw. Sorta like tilting a sweating glass a little bit before you lift it off of a coaster so that the coaster doesn't stick to the bottom of the glass.
Jim
Jul 26, 2011 | Bosch SG45 4500 Rpm Drywall Screwgun
I need to heighten handlebars
In the center right below the handlebars is and allen head screw. You will need an allen wrench, loosen the screw by turning it counter clockwise. Lift-up on the handlebars and adjust to the desired height and re-tighten the hex screw. Be carefull not to raise up beyond the lower adjoining yoke line on the goose neck.
Jul 11, 2011 | Specialized CrossTrail
Own a Realm bicycle about two years old. Want to raise handle bars. Doesn't look like there is a post to do so. How do I raise
http://www.sheldonbrown.com/handsup.html
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchsed the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Jul 08, 2011 | Cycling
How do i raise the handlebars on the sorrento? I love this bike but my man parts go numb because I have to lean over so far due to the seat height level I require as I am 6' 3" Please help!
Jun 28, 2011 | Diamondback Sorrento 26" Mountain Bike
How do you raise the handlebars for the animator first bike by Giant bikes?
David-
To raise or lower the handlebars, first loosen the hex screw on the top of the stem. One or two turns is all that will be necessary. Next, you will need to stand in front of the bike with the front wheel between your legs to brace it, and give the handlebars a forceful twist to the left or right. This action will break the friction of the handlebar stem and the headtube (the headtube is part of the frame where the front forks and the handlebar stem meet...). With the handlebars loosened you can adjust the handlbars up or down. Keep in mind that the stem has only a specific amount of adjustment available...there is a limit to how far it can be extended up, as indicated by a line marked on the stem shaft. Once adjusted to the desired height, check that the handlebars and front fork and wheel are aligned. Tighten the screw in the top of the stem and you're done!
Hope this helps.
DIYpro
May 03, 2011 | Cycling
Cycling Logo
1,511 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
