Question about Pelonis Disc Furnace Heater
Temp control does not seem to work on my pelonis disk heater
Heater run at the same temp no matter where thermostat is set. ALWAYS RUNNING.
4 Suggested Answers
Buffalo12980
  • 625 Answers
SOURCE: Pelonis Safe-T-Furnace
you try taking it apart to see what's bound up?
Posted on Oct 15, 2007
  • 3 Answers
SOURCE: I need a new thermostst and on off switch for a pelonis wm-ho202C
Try http://www.pelonis.com/parts.htm
Posted on Feb 23, 2009
MNfisherman
  • 11896 Answers
SOURCE: looking for manual FOR PELONIS HEATER MODEL#
You can find your manual here:
http://www.pelonis.com/oilfill.htm
And for electric type you can get it here:
http://homeappliance.manualsonline.com/manuals/mfg/pelonis/hb211.html
Posted on May 15, 2009
My rooftop a/c seems to work fine. The problem I have is when fan is set on lo and when temp reaches s/p fan shuts off The fan always stayed running in the past. Would this be a thermostat problem?
You really don't want the fan running constantly. This increases humidity. How are you controlling the fan speed on the tstat?? What are model numbers??
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 08, 2017 | Heating & Cooling
Is there a way to test the control board?
You need to check element itself to see if it is grounded. That would make it stay on and overheat.
Mar 30, 2016 | Dryers
My electric oven and grill will not work
It could be the thermostat is defect, an overheat protection is defect and does not close while the temperature is low enough. or the heater is defect.
When the heater and grill are separated, please try the grill. If it does not work I think the thermostat is defect. Most of the time there is no extra fuse in the oven.
When the oven is working on 2 or 3 separate groups, please check if one of the mains fuses has tripped.
Oct 15, 2014 | Ovens
Furnace in mobile home has a few problems
Sounds like fan & limit control
If temp on limit reaches max temp what happens gas valve deenergized,as MTR continues to run begins to lower temp. Thus reenergizing valve
Check filters,MTR speed for heating
Feb 03, 2014 | Coleman Heating & Cooling
I have a Pelonis oil-filled electric radiator heater that will not turn on even when plugged in to a good outlet. The switch seemed a little erratic but worked but when I bumped into it this morning i
Unplug it, then open it and inspect for a loose wiring connection. If that doesn't help, then jumper across the tip-over switch to see if the switch is bad.
Jan 25, 2014 | Pelonis Disc Furnace Heater
I don't understand what the controls do pelonis oil filled radiator
I would try the thermostat one by turning it up to a higher heat. I feel the other one may heat on high but would not shut off. You would have to do it manually.
Sep 23, 2017 | Pelonis WM-HO202C Oil Filled Radiator...
I have a white Rodgers ac thermostat and the temperature in my apartment stays on 88 no matter how low I set the temp. If I turn it off, of course it gets even hotter. This started happening when I pressed...
I'm not quite sure I understand what you have done but, make sure your compresor(outside is running and, that you don't have the thermostat set to "fan". You want the display to show "cool" and then adjust your temp. It sounds like you have the system set to fan and not cool. Provide me with a model number and I will see about getting you a manual.
Jun 04, 2011 | White Rodgers 0754-1 Electric Water Heater...
Pelonis model HO157C0110 will not turn on
Bypass the 3 way (hi, med, low) switch, unfortunately it'll always be in the high position when you do this. I have done this with one of my heaters and as long as the thermostat is working properly then it will work as it should on the high setting. I took the extra step of connecting the LED light to the bypass so I know when its on.
Just remember to turn it off you'll need to unplug it.
Oct 12, 2008 | Heating & Cooling
Sep 30, 2007 | Pelonis WM--HC482B Compact Heater
Pelonis Disc Furnace Heater Logo
82 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
