Question about 1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch
97 chevy 2500 truck; 350 vortex; trouble starting
Acts like not getting fuel, checked fuel pressure, it is good. changed fuel filter. will start but cuts out and dies. when turn key off then turn back on will then start.
    Habit-Forming:
  • 73 Answers
Seem like your fuel pump can't keep up the pressure when engine is started. If you have a pressure regulator that isn't into the pump assembly i would change it if not then your going to need a new fuel pump assembly.
Posted on Mar 08, 2014
jpk528
  • 95 Answers
SOURCE: 97 chevy suburban wont start
try putting a dab of solder on each one of the contacts on the fuel pump relay. i had a similiar situation where the relay contacts in the fuse box got strectched out over time so i put a dab of solder on each terminal to beef the contacts up and it worked perfectly. i think this will work because if the mechanic put a wire jumper in the contacts then electrical it is fine.
Posted on Feb 17, 2009
Danno5691
  • 17 Answers
SOURCE: engine dies after starting and running
I had a wiring harness that grounded out my computer on the exact same truck, fortunatly mine fell under warrenty. Fixed a bare spot in the harness, it was a hot wire feeding the computer.
Hope this helps.
Dan
Posted on Apr 25, 2009
XSdB
  • 80 Answers
SOURCE: Truck runs good than next day doesnt want to start, runs rough !
Change the plugs, and plug wires first before suspecting coils. Then if no change, suspect coils, and if still no change, suspect a fuel injector. If you have a check engine light lit, you may be able to get a code from the diag computer (can be read for free from autozone I think) that tells you the exact cylinder that's misfiring. Then you can narrow your suspected choices down and focus on that cyninder for the coil and injector.
Posted on Jun 17, 2009
arauzvictor1
  • 466 Answers
SOURCE: 1997 k1500 chevy 4x4 5.7
You have to check when the engine is stopped if it is missing spark or fuel because the engine is stopped for lack of spark or fuel to be able to verify that a better diagnosis. Thank you
Posted on Aug 02, 2009
  • 19 Answers
SOURCE: 97 Chevy Truck starts and idles rough and then shuts down
Sounds like you're loading up with fuel. I'd check the fuel pressure regulator. Some engines are set up with a regulator inside the intake plenum, which requires plenum removal.
Posted on Oct 01, 2009
98 Chevy 2500 350 vortex won't start it will hit but won't start put cam sensor and coil and changed the spider to a used one was taking out of running truck crank sensor 72lb of fuel pressure
I own a '97 GMC Safari, I don't know if yours has the same connector to the fuel pump, but mine has a round electrical plug just in front of the gas tank that has given me a lot of trouble. The fuel pump starts, comes up to pressure, then the vibration of the engine starting causes the plug to lose a connection, and the engine then dies. I pull on the plug, and it runs normally. If you have that plug, pull it apart and pay close attention to the center pin.
Feb 08, 2016 | Cars & Trucks
2000 chevy ck 2500 5.7L 4x4
Get a fuel pressure gauge and measure on the fuel supply line on the rear of the inlet manifold. In my experience you need close to 4Bar while cranking. Priming pressure should be about 4.4Bar. This test will eliminate a variety of possible problems. I have had a variety of problems and found this very helpful.
May 14, 2010 | 1997 Chevrolet C/K 2500
Is Check engine light on..?
Your problem sound like a fuel pressure related .If you have a fuel pressure tester, check the fuel pressure dont't drop. (key on engine off)
Mar 24, 2010 | 1997 Chevrolet C/K 2500
1998 Chevy tahoe Hard to start when cold
replace your MAP sensor(manifold absolute pressure) the map sensor is the computer for your fuel pressure regulator telling how much pressure. Unless your tahoe runs like **** going up hill than it inevitably your fuel pump
Feb 17, 2009 | 1999 Chevrolet C/K 2500
1997 Chevy Express 2500
try to spray a little fuel into the throttle body or carb and see if it starts and runs if it does check your filters and spider injectors also it wouldnt hurt to check your hall effect sensor
Jan 17, 2009 | 1997 Chevrolet Express
1999 chevy blazer fuel problem
probably not fuel filter . probably going to have to remove the upper intake and replace the fuel injector spider(fuel inj assebly) if it is droping fuel pressure it is leaking into the upper manifold
Nov 29, 2008 | 1999 Chevrolet Blazer
Hard start
Its your fuel pump.I had the same plomblem not too long ago.I was spraying either in to start it.I have a 97 chevy truck witch requires 65 psi to start and 55 to run properly.You need to find out much psi you need to start it.You can probaly look in your manual or just make a few calls.My truck had 55 psi and it ran fine i just had to get it running first.Good luck.I wonder if that fuel pressure regulator was a waste of time like it was for me.
Nov 13, 2008 | 1997 Chevrolet K1500
1995-1997 Chevy 1500 Truck Ignition Starter Alarm Switch Logo
97 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
