Xerox 5150 Color Copier. Older machine Xerox is not making parts for any more. Am finding other machines and making one good one for now. Have problems with a 2" x 1/2" inch black line that is printing on page which is on operators side. Looking for knowledge on why and how to remedy.
  • 22 Answers
SOURCE: Brother IntelliFax 4100 sending solid black pages
There are two possible solutions. Is the machine sitting on top of metal? The machine will send black pages when there is static charge. You can put a rubber mat under the machine or use a static guard. The second solution is to put the machine in maintenance and reset the scanner. Unplug the machine, put your finger on the menu key first and then re-plug the line while holding the menu key, in about 30 seconds all the lights will flash and the display will say maintenance. Release the menu Key and press 55 and this will reset the scanner; if scanner error comes up the machine will need to be serviced. Press stop and then 99 this will exit you out of maintenance. If the machine does not have an error try making a copy of blank sheet of paper and see if there is any improvement. As a routine clean the scanner glass with soft lint free cloth and isopropyl alcohol also.
Posted on Oct 05, 2007
SOURCE: problem with images
I found this by searching on the 2050c. I read this and it did not help much but I got to thinking the scanning was done by a narrow slit and my verical lines running the lengh the image had to be dirt on the slit.
I got some very good quality color printer paper not real heavy maybe even 20lb and ran about a hundred pages throught the scanner. Slowly the lines faded to white even at 800x.
I did take a slightly damp soft cloth and wipe the area where I thought the slit might be. We have 2 of these scanners and the other had a faint line too and while I was on a roll I ran pages through it.
Maybe this would work for you. In any event it almost has to be something on the scanning part.
Posted on Feb 05, 2008
bowdo
  • 78 Answers
It sounds like the CIS (scanner) has failed in both machines. Its no generally not a common problem. I would change one every six months if I was lucky.
It may point to something in your environment. I have have seen rust build up on the contacts of the scanner cause this problem. So if you have high moisture or are close to the ocean this maybe a problem.
Posted on Feb 14, 2008
Inky
  • 691 Answers
SOURCE: ricoh aficio 1515f printing dark line down left side
If the print can be rubbed off then this suggests the fuser unit is not working correctly. It could be that the thermistor is covered with toner and making the machine think the fuser is hot enough when it's not.
The black line could also be caused by the fuser if one of the pick off fingers is coated with toner or has worn into the Teflon of the roller.
Does the machine show the lines when you print a page from memory - such as a counter or config page? If not, this would suggest the optical path is dirty. Try cleaning the glass and look at the mirrors inside the scanner to see if they are dirty/dusty.
Posted on Feb 18, 2008
checkitright
  • 1362 Answers
SOURCE: when the fax machine prints
1-take out cartridge and clean the inside , there may be toner on the lamps
2-take a look at the drum(shiny cylinder) does it have black rings?? replace
3-does it have scratches or grooves? replace
3-could be the lamps (long thin strip of lights) some of the lights are bad
Posted on Aug 11, 2008
Will not print in color
You can find answers to your Xerox questions at www.xerox.com/support
If the machine will copy in color it should print in color.
After verifying that it will copy in color, verify your driver is capable of being switched from black and white to color. If there are no color settings then you have the wrong driver. The link above will take you to the support page where you can download new drivers.
Mar 26, 2013 | XEROX MULTIFUNCTIONS Xerox Phaser...
Need owners manual for xerox workcentre 5135/5150
http://www.support.xerox.com/support/workcentre-5135-5150/documentation/enus.html
this is a mid-size office machine that has the manuals broken down it to specific areas of the device. you can find what you need right here.
Sep 30, 2011 | Office Equipment & Supplies
Hello, we have a Xerox Workcentre 7545, the waste toner cartridge needs replacing but we don't have the part yet. Can I manually empty the cartridge in the meantime so we can still use the machine? ...
If you can remove the waste toner cartridge go ahead and empty it out manually. Make sure that it is completly clean out. I use compressed air to flush out any residue.
Sep 22, 2011 | Xerox WorkCentre M-24 Color Copier
WorkCentre M24 is ticking me the error code 010-398
You have a bad fuser fan. Xerox part number 127K29340. Located on the back of the machine. Very common problem. Look up on google a business called the parts drop.
They will have it.
Mar 10, 2011 | Xerox WorkCentre M-24 Color Copier
Please i need technical help and be able to speak to a live perosn via phone to help with a xerox workcentre 24 color machine. will pay a fee of course. Does anyone have the XEROX software to tell the...
You have to have a fully configured laptop with several levels of Xerox software.
Once that is accessed though you can change those numbers to max them out for the life of the machine.
Where do you live? Maybe I can find someone to do it for you.
Aug 02, 2010 | Xerox WorkCentre M-24 Color Copier
Xerox XC830 Copier--Paper jams as it is leaving the copier
Inside the copier on the rear side where the gears are you'll find the gear on the fixing roller is broken. You can call Sharp instead of Xerox because there are usually cheaper. The supplies are not interchangeable, but the parts are.
Good luck
Apr 03, 2009 | Xerox DocuColor 12 Color Copier
Xerox Docucolor 12 copier doesn't print when sending to FieryEX12
There is no 1 part that deals with this issue i'm afraid. The copy from the glass uses all the boards in the same path that a print uses. It definately rules out the machine fault. I would guess that the machine isn't set up properly to receive these fierys. Just make sure all connections are secure, if not try other cables.
Jan 18, 2009 | Xerox DocuColor 12 Color Copier
Paper jam, cannot reset, no paper visible.
you probably ripped off a sensor or 2 call me 310-930-6348
Jan 02, 2009 | Office Equipment & Supplies
Xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
185 people viewed this question
k24674
jasbo
jasbo
