Question about Amana Dryers
My Heavy Duty Amana Dryer Model #LE8207W2 will not heat up
Tumbles but does not heat up
  • Jeanie Jan 01, 2013
    This is complete #. Dryer purchased in 1996. Serial no. S9510042618
  • Charlie Lapinski Feb 08, 2013
    did Shelby Gensamer helped you a lot or not at all
dididsaythat
  • 291 Answers
SOURCE: kenmore heavy duty clothes dryer will not heat
You really need a volt / ohm meter to check for Continuity & Volts Its well worth the investment... $15.00 bucks give or take a few I would check to see if you have 220v to back of dryer where the cord mounts to dryer, If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat. Check themostates & heater for Continuity... Most models, Now have a.. Hi-limit fuses that need to be checked for Continuity
Posted on Oct 08, 2007
IFIXALL
  • 868 Answers
SOURCE: Amana heavy duty clothes dryer,
Belt idler pulley sounds dry, oil all rollers and belt pulley.Please leave a Rating! Thanx!
Posted on Jun 05, 2008
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
protek480
  • 1714 Answers
SOURCE: Amana Heavy Duty Dryer turns on and gets hot but wont turn inside
watch the video
Posted on Jul 10, 2009
  • 2180 Answers
SOURCE: electric dryer won"t heat. Kenmore Heavy Duty 70
are you getting power down to the heater?why did you change all those other parts?you need to unplug the dryer,with a meter read out all the parts you changed out again but first make sure you have 240 volts coming to the machine,you can check it at the cord in the back,touch the white to the red,you should have 110 volts or 120,then go from the white to the black and you should have the same thing,if not the problem is in the house,if it's correct make sure you have power coming down to the heater,you could have a bad timer or a burnt wire,when you check the other parts unplug the dryer and whatever part you check at least one wire has to be removed,do this and you'll find your problem,if you did this first you wouldn't of bought all those parts.let me know what you find
Posted on Nov 05, 2010
Amana heavy duty super capacity dryer heating element location
get the Model # and then go to Repairclinic. com
Jun 28, 2013 | Washing Machines
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
I have a Amana clothes dryer model no NDG78700AWW. The dryer tumbles but it is not producing any heat. Any thoughts on the problem?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 07, 2011 | Amana NDG7800AW Gas Dryer
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
My Amana Heavy Duty Dryer will not heat up. It tumbles but it doesnt warm up. WE have cleaned out the the machine and the vent to the outside.
You didn't state if it is a gas or electric dryer. If gas the igniter element is bad, if electric the heating coils need replaced. Goodluck Google burdfrenzy
Nov 26, 2010 | Amana Dryers
Belt worn out - need to find the model number: amana heavy duty gas dryer - limited edition
you gave the model number it's NDE6800AYW,the belt part number is 33002535 and it's around 25 bucks
Jul 31, 2010 | Amana NDE6800AYW Electric Dryer
My dryer heats up but want dry the clothes...Amana Heavy Duty Electric model number NED5100TQ1
You need to check the exhaust, from the back of the dryer to where it leaves the out side. They sell a brush you may use to clean the pipes, You may also use a vacume. Try it with the hose diconnected from the back for a load. If it does better then, get to cleaning. be sure you check the lint filter. Good luck, and please rate my answer that I can improve them.
Jul 28, 2010 | Amana DLE330RAW Electric Dryer
My Amana heavy duty dryer will not get hot
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 05, 2010 | Amana NDE6800AYW Electric Dryer
Where is the thermostat for my electric Amana dryer LE8207W2
Normally they will be located in the air tube from the blower to the drum, and the heating element will be located in there also.
Sep 26, 2009 | Amana Dryers
Dryers Logo
74 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you an Amana Dryer Expert? Answer questions, earn points and help others
