Question about Remote Start System
My viper remrank it and it did with jumper cablesote does not work, i replaced the car battery and used the starter to
It just stopped working.now i had to jump start my truck and the starter remote worked when i had the jumper cables attatched, but did not work when i unhooked the cables. strange.
  • Viper Master
  • 625 Answers
Strange, indeed. Sounds like a power issue.
Posted on Mar 03, 2014
  • 899 Answers
SOURCE: viper remote stopped working 791xv
I have the same remote and it comes disconnected in the battery section from the battery hitting it and then the commands and speaker stop working
as shown here
Posted on Apr 05, 2009
  • 24 Answers
SOURCE: Replaced the battery in my car need to reset my viper alarm
Alarms are not supposed to shut down the engine while you are driving if it was installed properly. Could be another installed accessory or the car itself has a problem. If it was in anti-hijack mode, you would receive a warning like honking horn. You may have to visit a repair shop and maybe your local Viper dealer to have them take a look. DC
Posted on Nov 04, 2009
  • 151 Answers
SOURCE: my viper remote starter cranks engine but car
Did you connect the tach wire of the unit to your car? if not you need to refer to your documentation to turn on or off the tachless operation for the unit to work correctly.
Posted on Jan 13, 2010
MECP Guy
  • 344 Answers
SOURCE: viper remote car starter 479V
press and hold the ( P ) button until one long beep is heard, you now have 5sec to push the lock button to turn on or off the vibrate, wait another 5sec and it will automaticaly exit programming
Posted on Jan 28, 2010
Testimonial: "One word,AWSOME!"
logosc75
  • 625 Answers
SOURCE: my remote starter for my viper 5900 2 way trans
Try reprogramming the remote. Open the door, turn ignition on, press and release valet switch one time, then press and hold valet switch while pressing lock button on remote.You should hear a confirmation chirp from the alarm. Release both buttons.Turn off ignition. test.
Posted on Oct 03, 2010
Viper 5101 1-way remote won't work after replacing battery
Replacement battery could be defective installed incorrectly
Jul 04, 2016 | 5101 LE 1 Way Car Remote Starter System
My 97 saturn sl2 will not start
You'll need to crawl under the car and check for power on the small terminal of the stater with the key in the crank position. Knowing if you have power there will help to give you a direction to go in. If you don't have a test light or a multi meter, you can jump the large wire at the starter to the small wi at the stater with the key in the off position. If the starter works than you'll need to focus on wiring. If the starter doesn't work replace it.
Nov 29, 2012 | 1997 Saturn SL
The battery on my viper 5501 ran down. I plugged it in to recharge and now it won't work. The back-up key fob does work. how can i reset it? thanks very much.
Are you talking about the Remote LCD key fob itself? If you are then you need to replace the battery. Search on ebay. Hopefully this helps.
Jul 06, 2010 | 5501 LC3 SST LCD 2 Way Car Remote Starter...
I bought a used dodge pickup equiped with a viper remote system,it worked fine until the last few days now Iam unable to start the vehicle with the key and keep it running.I took out the battery from...
On many of the Viper models, the symptom you are describing is because the remote battery is low. The remote can't be too far from the vehicle. If it is, the system see it as you forgot about the vehicle being remote started, and shuts it back down. A weak battery creates a weak signal and makes the unit 'think' you are far away. The Viper website has instructions on how to disable the whole system, there are many different versions, so find the box and get the model number from it, you will need that to get any further.
Jun 02, 2017 | Viper Televison & Video
Battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Oct 23, 2009 | Viper Vehicle Parts & Accessories
Viper Remote Start, Jeep Grande Cherokee, Going crazy!
no - unfortunately "any mechanic" does not have the training to troubleshoot an alarm system, and a dealership does not work on anything aftermarket.
Your best bet is to visit DEI (Directed Electronics Inc.) website and find an authorized dealer near you... most likely a car audio shop.
Best Buy usually hires newbies as installers and they dont have much experience... Look for an independant shop.
CLICK HERE to go to the Viper Site. (Find a Store is at the top of the page)
The brain module cannot be repaired - the ignition and starter relays are integrated on the controller board. Since it is 2 years old - there may not be a replacement part available.
Good Luck!!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 06, 2009 | Viper Security and Remote Start System...
Can't start car even if i try the jumper cable.........
If you have a multimeter, connect it to your battery, and select an appropriate DC voltage range. On my multimeter, I use the 20volt setting.
If your battery shows 12-13.8 volts, then it is not the issue. If your battery voltage is low, then you will probably need a new battery. A flat battery can also indicate that the alternator is not recharging your battery properly, but it could also just mean that your battery is old and needs replacing.
If your engine wont turn over, and if your battery is good, it could be a faulty starter motor.
Those jump start packs need to be charged often, or the battery inside them can stop working. It is possible that your jump starter pack is also broken.
Try jump starting the car from another vehicle, with jumper leads. If you know your battery is dead, you could also just replace it with another one.
Apr 19, 2009 | 2003 BMW 325
Car won't stay running after using Viper 150ESP car starter
you may have hurt the alternator when jumping check that
Apr 07, 2009 | Remote Start System
Remote Start System  Logo
54 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
Tre Elkins
Shehu Pro
Shehu Pro
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
