Sankey air condition erorr E4 - Heating & Cooling
My portable goldstar airconditioner is showing E4 .What does this mean
E4 is a Display panel communication error.
Might have been something as simple as a Power Surge.
Power unit off for 30 minutes and then restart.
~Eddy
Air Conditioning Repair Tamarac FL
Jun 14, 2017 | Goldstar Heating & Cooling
I need to buy the compressor card for sankey air conditioner split model 12inv31
Most local home improvement stores do not carry AC components. I would try 1-800-269-2609 or google places in your area that sell AC parts. It could also be that it needs a cleaning. Can you provide any other details? I hope I can help.
Jul 28, 2016 | Heating & Cooling
Error code e4 unit airconditioner
Not sure about E4 , but 4 blinks or flashes usually means the compressor isn't starting properly. It could be a faulty start capacitor or wiring or faulty indoor PCB (Board)
Oct 18, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
Error e4
someone activated 4 zone reset thermostat
Jul 11, 2013 | Coleman York Control Board 03101237000...
E4 error on Yamatsu S-24H air conditioner ?
E4Fault indoor coil sensor (open or closed). Replace it.
Dec 14, 2010 | DeLonghi PAC85 Portable Air Conditioner
I have waves split air condition its cooling is good but some time in the display e4 is coming and that time my ac is not giving cold air what is this.tell me some one.
The e4 that displays on your air condition come up simply because there is an error during the operation of the system. E4 means Error 4 which is a code that is interpreted as low pressure switch.
E4 simply means there is low pressure switch, the pressure switch turns on automatically inside the air condition, so when you turn it on sometimes the switch jams and does not open so the air condition will be on but would not get cold because the switch jammed and it displays an error signal to let you know there is a problem in the system.
Take care
Jul 09, 2010 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
