Question about Royal 1610X Heavy Duty 10-12 Sheet Commercial Grade Micro Cut Confetti-Cut Continuous Form 16" Crosscut Shredder w/ Bin Full Size Cabinet 29122X
Need wheels for 1610x royal paper shredder
Wheels needed
SOURCE: Paper will not feed into machine
Most likely the sensor in the insertion area is not recognizing a paper when you try to insert it to be shredded.
Try to clean out the gears, and oil the grinders.
Clean around the insertion area to remove any debris from around the sensor. (Be sure to turn it off/unplug it first!).
If you can remove the shredder head/grinders from the body of the shredder box, turn it upside down and clean it that way as well.
Sometimes the little pieces of paper get clogged up inside the gears.
I got some of the dust spray with the straw...inserted the straw deep into the shredder grinder/gears and sprayed.  I got tons of stuff out.
My motor/grinder worked perfect after I did all this.
Posted on Oct 30, 2007
SOURCE: royal 160MX paper shredder
Great site for all Royal Shredders gears & parts.
http://www.geocities.com/jayrespler2/index.html
Posted on Nov 10, 2008
  • 3 Answers
SOURCE: Gears won't pull paper through
Posted on Nov 29, 2008
SOURCE: Need part for royal shredder model sc800
Here's what I found, but good luck...... I've been on hold for 20 minutes now....
http://www.royalsupplies.com/contact-us.html
Spare Parts: 800-222-2310
Posted on Mar 21, 2009
  • 45 Answers
SOURCE: Royal 15mx only works in reverse after clearing jammed paper
try resetting the shreddar, unplugging it waiting for about 20 seconds and then plugging back in. Check to make sure there is no paper or paper clips stuck in the shreddar, make sure the unit is properly mounted on bin, the overheat light isn't on is it? if none of this helps and you have a warranty on your shreddar now would be a good time ot call them as you might have a hardware problem.
Posted on Apr 16, 2009
Won't shut off
You have an optic sensor that is blocked or shorted. If you take it apart you should be able to identify the problem. It is up by where the paper feeds in.
Jan 08, 2013 | Royal 1610X Shredder
How do open the machine to add the lubricant?
Best way to lubricate is just to put the oil in an "S" pattern on a sheet of paper and shred just that one sheet. My have to do that a few times if its never been lubricated.
Jun 27, 2011 | Royal 1610X Shredder
I purchased the Royal crosscut shredder 2 months ago, and recently put some papers in to shred. Nowhere near the 12 pages it said I could. However, there is paper stuck in the slot that didn't go...
"Manual does not tell me what my warranty is, and the people here who service say I need that info."
I am assuming it is the Royal 1610X Heavy Duty 12 Sheet Commercial Crosscut Shredder
You purchased an expensive shredder and it should have a warranty to match.
Frankly, I would not waste any time worrying what the service people say.
The warranty period on such machines should be written on the purchase receipt, and the retailer is responsible for making sure this warranty is honoured.
Unless of course you bought it on eBay.
I would try to just return it and get my money back, or at the least get a replacement.
Good luck.
May 11, 2011 | Royal Office Equipment & Supplies
After a power surge, my royal 1610x shredder won't turn on. i thought it might be a blown fuse so I tried to remove the top cover per dissassembly procedure on page 9 of the service manual. However, the...
The last one I took apart you had to approach it from the bottom. Remove the lower bin, then start working on screws on the bottom of the shredder. The top part should then come off so you can get to the fuse.
Mar 25, 2011 | Royal 1280MX Shredder
How do I oil my royal crosscut shredder 1610X
To oil your shredder, squirt some shredder oil onto a piece of paper (don't completely soak the paper) that you wish to shred & feed this paper through your shredder.
Feb 10, 2011 | Royal VF1000MX Shredder
Where can I find an owner's manual for my Royal 1610X shredder?
I dont believe Royal provide one on line for download so I would suggest you contact them at 1-800-524-0799 to see if there is one they can possibly send you.
Jan 25, 2011 | Royal 1610X Shredder
I want to remove the cover to clean the mechanical
Remove the waste bin..inside there will be 4 screws holding the cutting head onto the container..remove those then you can lift the cutting head off the container.
Turn the cutting head over and remove the screws you see..normally 4~6 and the top will then lift off to allow access to the inside of the machine.
May 11, 2010 | Royal 1610X Shredder
Paper will not feed in Royal 1610X Shredder
UNPLUG unit then
take it apart and clean the cutters somethings jammed in there
Jan 14, 2009 | Tech Solution TS-4500 Shredder
Power won't come on
Try to open the shredder with a screw driver, but be very careful not to break or move anything important. Remove any paper that may be in there. If its the gears inside that are not working, you can use some oil as a lubricant to fix it up.
Aug 26, 2007 | Royal 1610X Shredder
Royal 1610X Heavy Duty 10-12 Sheet Commercial Grade Micro Cut Confetti-Cut Continuous Form 16" Crosscut Shredder w/ Bin Full Size Cabinet 29122X Logo
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
