Question about Kitchen Ranges
I have a Kenmore Model 665.75844 Sens-A-Clean Self-Cleaning Gas Range which has been starting to give us problems with the oven not staying lit past the first heating cycle.
I have a Kenmore Model 665.75844 Sens-A-Clean Self-Cleaning Gas Range which we have owned since new and is in very good condition. However, as of late it has been starting to give us problems with the oven not staying lit past the first heating cycle intermittently. I have attempted to clean the sensor in the oven as well as running the self cleaning feature without success as the problem reappears from time to time. Just the other day in fact we started the oven up for a pizza and preheated the unit to 425 degrees which was achieved only to find that when we checked the pizza 10 mins. later the oven had kicked out the burner which could not be recycled on again. FYI-the timer feature was not in play for any of the early kick out of the burner. Could this be a bad sensor or possibly a bad control board? Any help would be appreciated...
  • 1 more comment
  • Mike in MKE Jan 02, 2013
    The actual model and serial numbers for this range from the sticker inside of the drawer are:
    Model: 665-75844001
    Serial: RK3110513
watugot
  • 290 Answers
SOURCE: Kenmore range stopped working after self clean cycle
It will help to know the model number from the oven, but F2 usually indicates a failed temperature sensor on most ovens. If this is the case on yours, it will have to be replaced for the oven to operate again.
Post back with the number and I will see if I can help.Thanks/Mike
Posted on Dec 24, 2007
SOURCE: After running self cleaning cycle, oven won't heat.
I own a similar range. As you can imagine I was dismayed to find out that my $6000 heap can't run a clean cycle, unless of course you just don't want to use your oven again. let me give you a tip something WILL break on your oven every time you use the self cleaning "feature".
The first time I used the self cleaning feature the board burnt up, I asumed hat this was a fluke. The second time the pvertemp sensor burnt out. The next few times that I was brave enough to try it the overtemp sensor triggered this is what I hope has gone wrong with yours since while it's not easy or convenient to fix it is free. If you pull out your range and remove the backsplash and then the rear panel there should be a breaker with a button you can push to reset. On mine it is located near the top of the oven compartment on the left side near the middle. I hope that works for you and you will soon learn as I have after doing this a few times that the self cleaning cycle is just not worth it. It willdo this every time and it really is just easier to use easy off and clean the oven by hand. I realize that is not what you had in mind doing when you bought a luxury Item like a 36" thermador range, but I hope you don't have to hate yours as much as I hate mine.
Posted on Oct 28, 2008
SOURCE: Kenmore gas range--oven won't come on
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Posted on Jun 16, 2009
emissionwiz
  • 76846 Answers
SOURCE: ge self cleaning oven wont shut off
replace the oven control circuit board.
Posted on Jun 21, 2009
SOURCE: whirlpool accubake oven will not heat after self clean cycle
I had the exact same thing...thermostat..
Posted on Jul 11, 2009
How do I clean Kenmore electric range model; 36393091300 .No manual for this self cleaning range.
Hi,Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Aug 24, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore gas range model # 7907578890. I pushed the clean button to clean the oven, door locked and cleaning started briefly then stopped. Door stayed locked. Now oven won't respond to any buttons...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jan 18, 2011 | Kenmore Ovens
My electric range sens-a-clean button will turn on and then start? comes up and i hit start. then E1 F5 comes up. the door will not lock nor will it start cleaning. none of the other buttons will work...
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
Nov 26, 2010 | Kenmore Kitchen Ranges
I hit the select clean button on my kenmore gas self cleaning range by accident and now i cant cook on it
heatman101
Sep 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
How do I clean my amana gas self cleaning oven
I have an Amana self-cleaning oven, Model AGR5715QDQ. I can't find my manual - how do I start the process of cleaning? Elizabeth
Nov 22, 2009 | Amana AGDS902 Gas Kitchen Range
Did self clean now oven does not work
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jul 16, 2009 | Kenmore 36665 / 36669 Gas Kitchen Range
Kenmore Self-cleaning Gas Range 665.75012
I have the same problem with the same exact model. Any helpful troubleshooting tips would be much appreciated. I'm not sure if this is a heat sensor problem or a problem with the control board.
Anyone have any ideas?
Nov 08, 2008 | Kenmore 96422 / 96424 / 96429 Electric...
Nov 15, 2007 | Kitchen Ranges
Self cleaning oven directions
Press the self-clean button.  The panel becomes blank(---), then press the up arrow( ^ ).  The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning.  Good luck, ya'll!
Oct 24, 2006 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchen Ranges Logo
56 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
