Question about JVC AV-48WP30 48" Rear Projection Television
JVC I-ART 48 inch color issue
The colors as well as the brightness of the picture on my JVC I-art 48 inch rear projection have degraded, the picture is still clear but everything seems to have a greenish tint or red depending on how I try to ajust it. The brightness also look less that what it use to be. I had the convergence ship replace last year. the Tv is about 6 years old. Which component is not working prorely and what can I do to fix it
Thank you
  • Anonymous Jan 26, 2009
    red outline around everthing
    red outline everything
  • 9 Answers
SOURCE: JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Posted on Aug 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: I ART PRO JVC 56
You will need to replace the convergence iCs there are two of them they are both STK392-110 Ics you will also need the JVC convergence resistor kit. You can get the ICs and resistor kit at the following link and they provide free instalation instructions with pictures. Heres the link.
http://servicemanuals.vstore.ca/
Posted on Jul 27, 2008
Slinteriors
  • 8617 Answers
SOURCE: re: I art jvc
you can get the convergence repair kit to fix your model JVc at the following link look under the convergence repair kit category, they provide free step by step instructions with pictures so you can easially do the repair yourself. heres the link.
Posted on Aug 14, 2008
  • 59 Answers
SOURCE: jvc i art pro doe not turn on
The clicking sound is the TV trying to restart itself. It generally attempts this several times before giving up. The blinking code indicates the type of error (error codes are documented in the manual for the TV). The most likely cause is a burned out bulb, but could be something else.
If it is a bulb, it is usually replaceable without a service technician, and at a cost far less than $450.
Good luck.
Posted on Jun 18, 2009
  • 90 Answers
SOURCE: red convergence will not line up on my jvc 56 inch
You need to pull the front grill cover/panel off the front of the tv. Remove screws (4) from back that hold it on, also 2 small ones behind front video input door. Then remove access panel. The ckt board closest to you is the convergence amplifier board. You should replace both amplifiers (stk392-110 or 120) and any burnt/open resistors you find near the amps.(use the same value resistors as the corresponding resistors in the blue amp ckt)
Posted on Jul 08, 2009
The color is kinda faded an blurry (sorta) its a 50 inch JVC projection TV..... i have tried to go into the menu screen an change the color the brightness an all that but when i do it doesnt change it...
Well, the bulbs can be up to 260 dollars per lamp, depending on the TV and if the bulbs are separate.It's not very hard to change them out if you have a little experience in taking those types of items apart, but I would definitely look into it.
Apr 05, 2011 | JVC AV-48WP30 48" Rear Projection...
I HAVE A 48 JVC I ART PRO AND IT SEEING DOBLE.
Thats caused by failed convergence ICs and resistors. You can get the JVC AV48wp74 -AV65WP74 cnvergence repair kit from <A href="http://www.tvrepairworld.com">www.tvrepairworld.com</A> the kit contains the ICs , Resistoirs and the cd with repair instructions.
Aug 25, 2010 | JVC AV-56WP74 56" Rear Projection...
JVC-AV48WPT74 picture colors are distorted, looks like 3-D image
The convergence ICs and feed resistors need to be replaced. You can get the repair kit for your specific model at the following link. The convergence repair kit contains the replacement parts and the step by step repair proceedure on CD. Very easy repair. Just look under the JVC repair kit category
http://www.tvrepairworld.com/
Jul 12, 2009 | JVC AV-48WP74 48" Rear Projection...
Jvc i art pro doe not turn on
Good luck.
Jun 18, 2009 | JVC AV-56WP74 56" Rear Projection...
String Art 2
It is failure of convergence out ICs and subject part needs to be replaced, TV has 2 ICs and both will be replaced.
If you are tech person or know TV repair, let me know to provide you more info or call local TV tech to fix it.
Feb 14, 2009 | Sony KP-65WS500 65" Rear Projection...
Tv screen
this is your convergence amp
for cheep repair call
719 687 6997
Nov 11, 2008 | JVC AV-48WP30 48" Rear Projection...
Re: I art jvc
Aug 14, 2008 | JVC AV-48WP74 48" Rear Projection...
Tv set 48 inches projector..[jvc]
replace 2 X convergence ICs and align. Maybe burnt resistors as well.
easyab@hotmail.com
Calgary
http://calgaryconvergencerepair.weebly.com/convergence-repair-explanation.html
Jun 16, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
354 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
