Question about Toshiba Satellite A105-S4004 Notebook
Boot problem - with XP and 2000
I have a problem with a driver @ PC startup..
Sometimes my PC boots properly and sometimes : "After ..booting the monitor doesn't display the desktop.. instead it looses display..the green LED turns Orange'
When i repair my installation using the 2000 fast repair.. it repairs some driver that loads @ d startup and then i am able to boot into 2000...problem gets solved...
this problem occured with Windows XP also but since there was no option to fast repair the boot ..XP always started the entire setup again... repeated setups also do not solve the problem....so i tried to test using windows 2000 professional...
I have come to know that somhow .... a boot fie gets corrupted .. (!!!) so that i have to fix it at every boot.... why it is happening?
now tell me how this will fix up.. 1. my graphics driver is not corrupt since after fixing install it works fine........2. RAM is not faulty....ihave tested it...3. I have a P3 800Mhz 256MB RAM 82810E board..
    Genius:
  • Toshiba Master
  • 1,102 Answers
Whn you ran with xp did you have AC power plugged in
Posted on Feb 15, 2009
I have a HP XW4100 with Windows 2000 and want to upgrade to XP SP3. I purchased a XP OS Disc from Microcenter as well as 2GB of extra memory. Memory install went fine. When I try to load XP, the machine...
When your computer is starting up there should be a button to specify a boot device. In most cases this will be F8, F10, F11 or F12.. make sure you watch the startup for details. Also.. keep an eye on it while it's starting up because sometimes a small message will appear saying:
"Press any key to boot from CD.."
in which case you need to quickly respond by pressing any key. This message only appears for a few seconds so make sure to watch for it!
Mar 30, 2011 | HP XW4100 GCR-8483B 48X IDE Crbn CD-Rom
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
Have another computer dell desktop not this one,it boots up and shows windows xp logo and then the screen goes completely black and cannot get into any thing
Possibly it is a video driver problem. Try entering boot menu by pressing the F8 key at startup, and first of all try with "Boot in last known working configuration". If it doesn't solve the problem, retry booting in safe mode and change the video resolution to 640x480 VGA. This will look horrible, but if it lets you reboot and login as Administrator in normal mode, you will be able to reinstall the video drivers from Dell (either the CD-ROM or the web site). At that point you will be able to raise the resolution again.
If it still doesn't work you might need a recovery install of XP, which sometimes messes with some programs' configuration.
Oct 28, 2009 | Dell Dimension 3100 PC Desktop
I have a dell D820 which will not switch on today, sometimes it gets to the windows XP page sometimes the initial dell page. Other times nothing at all. All worked well last night
immediately run a diagnostics for the hdd alone power on laptop then keep tapping F12 then run the diagnostics. if no errors found then.
try this. power on laptop then keep tapping on F8 to boot options then select last known good configuration. if same problem then boot in F8 then safe mode if still the same problem. use now the OS disc to do startup repair. Boot F12 then select DVD drive in booting make sure the OS media is already on the driver. then just select repair computer then make startup repair. if all fails this might end up reinstalling OS as clean installation.
Oct 21, 2009 | Dell Latitude D820 Notebook
Amazing Boot problem !!
stick another card , agp pci or whatever you can get easiest in a slot . if it works....hmm bad onboard video. if not could be mb , motherboard , over heating or cpu. are fans spinning full speed ? reboot then go into bios, usually del key. and check motherboard temp. after failure.
Jan 18, 2009 | Computers & Internet
XP INSTALLATION
All you have to do is to access the BIOS then set the option of first boot device as CD then the second boot device as HDD or hard disk. When you turn on your HP you should see the option to go to the BIOS Setup sometimes its F2 or F12 or Del Depending on the type of motherboard you have on your laptop. Once you set it to boot from CD , when you startup your computer you should see press any key to boot from CD just press any key and it will boot. After the installation change back the first boot device.
If you have any other questions do message me back.
Nov 07, 2008 | Computers & Internet
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Boot up problem
you need to press f9 while its loading then go to command prompt, you want to then type in command bootrec.exe
then bootrec/fixboot and ten bootrec/fixmbr ....sometimes its just bootup and other times it will be drivers or dhll files causeing your computer to not want to boot, if you have vista you can press the f9 at startup and go throught the recovery wizard there are plenty of options there, i tend to have the same problems, but sometimes if i have something hooked into my usb ports it causes the boot up problem, so i unhook everything and reboot and it works.
if you need any more information you can message me at vmhreha@aol.com i have a ton more options you can do if this one i just gave you doesnt work.
May 15, 2008 | Toshiba Satellite A100-S2311TD Notebook
Open Questions:
See all Toshiba Satellite A105-S4004 Notebook Questions
Toshiba Satellite A105-S4004 Notebook Logo
77 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
