Question about Kodak EasyShare Z1015 IS Digital Camera
Z1015 won't charge battery internally. this battery was working
Just received correct wall charger AC/DC? And cannot tell if battery is charging, won't power on yet
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Best Regards, Russell
Posted on Jan 24, 2013
  • 3 Answers
SOURCE: m753 kodak camera does not come on.
go to the nearest electronic place that sells cameras they will tell you wats wrong
Posted on Dec 07, 2008
SOURCE: how can i tell if i need to charge my battery for kodak m1063
a lil battery sym ol will start flashing in the lower right corner
Posted on Jul 03, 2009
BillB-SA
  • 2761 Answers
SOURCE: my kodak m863 won't charge at all either using the
Fixing your problem could be as simple as cleaning the battery contacts in the camera, or the solution could be a lot more complex and expensive. Here's a link to the Kodak Help Center - it provides a simple Q&A format to diagnose the problem and propose a solution.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
  • 37 Answers
SOURCE: my camera battery ran out and when i plug it in to
yes replace both ,batterry and the charger,thath way youl be shure and the new battery must be charge for 12 hrs ...
and should works fine after ..
hope that will help you
regards Alan..
Posted on May 27, 2010
SOURCE: the camera won.t turn on the battery
I had the same problem with flashing red light on my charging dock (within 10 sec after 2nd green light came on). I did fix it. There is a rust brown securing tab that holds the battery in place. Mine must have a broken spring..... So, I put the battery into my camera, pushed securing tab over the battery and then wedged a toothpick tip to keep battery tab in place. Once back on the charger, I had no more flashing red light. The battery is charging correctly. The problem was that the battery was not held down into place correctly. I now just have to unwedge the toothpick tip to remove the battery...but not really an issue at all as I keep the battery in there all the time. Very easy fix!!!
Others suggested to reseat the plastic dock. But mine was secure. Somewhere there is not a good battery connection that is causing the red flashing light. I am thankful to figure it out. Hope this helps you.
Posted on Oct 12, 2010
I have a nikon coolpix s3200 and it won't charge!
Hi there I was told that jumpear something on the plate to be reset to factory state solutions and hope you tell me if it is true that thanks
Jun 18, 2013 | Cameras
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Dustbuster batteries won't hold a charge.
The AC is not full sine wave. The diode is in the wall adapter
Jan 15, 2013 | Computers & Internet
Eee pc x101 won't charge
You need a new AC charger the wires wear out very often with constant plugging in and out im on my fourth one.Buy the full charger and cable.Ebay less than a tenneerr
Aug 17, 2012 | Asus Notebooks Asus Eee PC X101CH-EU17-BK...
Battery won't charge at all
maybe you have ac or dc adapter problem try to bend the wires back and forth while you're laptop is plugged in, and see if it is charging whenever you move the wires. if not, your whole charger (ac/dc) is damaged/broken or your battery is. if your unit is still under warranty have it replaced instead of spending money for something under warranty.
Feb 09, 2012 | Dell Vostro 3400 14" Laptop (V34004168ABS)...
Any idea where I get a replacement charger for a Metz60CT4
EBay, if that's what you want. The metz "chargers" are just 7 volt ac transformers - they supply 7 volts to the battery pack which has the actual charging circuit in it. I haven't pulled one apart yet, but I'm guessing they're very rudimentary chargers. Depending on what you're using for a battery you might want to use a modern external smart charger. I use $20 AGM batteries from batteries plus (instead of the $80 metz batteries) and use an external charger from WallMart on them. It's quick, lets me see the current charge state, won't overcharge the battery, and works on my car and boat batteries too.
Jan 24, 2012 | Metz Mecablitz 60CT4 TTL Flash
My vector vec157 will not charge on 120 volt. It works on 12 volt
If you light is charging when you use the 12v automotive charger but not when you use your AC power transformer, my thought is that you might have a problem with your AC charger, not with the light itself. I have AC/DC transformers from the 1970s that still work fine, but I have had numerous modern AC/DC transformers burn out on me in recent years.
One easy test is to use a multimeter to measure the output voltage of your wall charger. Place one test lead on each of the charging terminals (i.e., one inside the barrel and one outside the barrel, if you have a standard coaxial charging port) and check the DC reading. If it's zero--or anything less than 12 volts, actually--the charger isn't working correctly. The problem may be a torn or cut wire or something actually inside the transformer.
Replacement chargers can be found at Radio Shack and other stores. You may also be able to score a cheap replacement at a "dollar plus" store or even at a second-hand shop. Make sure that the terminal polarity is correct on your replacement charger or else you'll fry the batteries in your light.
Sep 08, 2011 | Vector 20 Million Power Series Spotlight
Garmin 350 cannot charge and nav at the same time
Your battery is faulty. Did it come with an AC Charger? Ac chargers do a better job than the car Dc which really only manages to maintain a reasonable level of input. i suspect your internal batter is critical and either needs a thorough charge or replacement
Jul 25, 2009 | Garmin Nuvi 350 Car GPS Receiver
New Nuvi 760 that won't work
Using the PC to charge a Nuvi is not the correct way to charge. Use either the AC wall charger or DC car charger. Many PC USB ports can not supply enough current to charge a Nuvi.
- Jim
Dec 12, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
Garmin GPS 200. Does it work on battery too.
Yes, it has an internal lithium-ion battery that needs to be charged with either a DC car charger or AC wall charger. I do not recommend using the USB cable to PC as a means of charging.
- Jim
Nov 29, 2008 | Garmin GPS
Kodak EasyShare Z1015 IS Digital Camera Logo
83 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
