Question about Toshiba Satellite A205-S4617 Notebook
What is the polarity of a Toshiba Satellite A205-S5864?
Center positive
Posted on Dec 31, 2012
  • 106 Answers
SOURCE: Toshiba Satellite A205-S4777 Camera help
sounds like the camera wires are broken. you would have to take apart the screen portion of the laptop to see if it is connected still. you would then have to splice the wires together if they are broken/damaged
Posted on May 23, 2008
SOURCE: Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Posted on Jul 26, 2008
Rick60639
  • 29 Answers
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Posted on Dec 01, 2008
  • 104 Answers
SOURCE: Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Posted on Aug 01, 2009
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Posted on Aug 19, 2009
Will a toshiba satellite a205-s5864 turn on without a battery while plugged in?
With the battery unplugged and power cable connected to the laptop, then yes, however, it will shutdown straight away if you accidently disconnected the power cable from the laptop
Jan 05, 2015 | Computers & Internet
When restoring toshiba L355D-S7901 what does "error 10-FA11-045D" mean? i get that code when its creating the crc files. how can i fix this?
Read this forum:
http://www.howtogeek.com/forum/topic/recovery-error-on-toshiba-satellite-a205-s5864?replies=21
Jun 20, 2011 | Computers & Internet
How to disable SATA on Toshiba satellite A205
Why would you want to disable it? Chances are it is a SATA HDD installed.
Apr 22, 2010 | Toshiba Satellite A205-S5812 Notebook
Satellite a205 died. will not power up at all. 2
Go to the Toshiba web site. They often extend the warranty on laptops with common problems.
Jan 09, 2010 | Toshiba Satellite A205-S4617 Notebook
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Have no lan drivers
Hi there!
Drivers for the Toshiba Satellite A205-S4617 are available from Toshiba here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1700051&rpn=PSAF0U&modelFilter=A205-S4617&selCategory=3&selFamily=1073768663&selModel=1700051|PSAF0U#
If this is not your model, then please specify your exact model number and I will try to find you the appropriate drivers.
Feb 17, 2009 | Toshiba Satellite A205-S4617 Notebook
Need The drivers for Toshiba satellite A205-s5804
Try here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1909174&rpn=PSAF3U&modelFilter=A205-S5804&selCategory=3&selFamily=1073768663&selModel=1909174|PSAF3U
Feb 06, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Jan 29, 2009 | Toshiba Satellite A205-S4617 Notebook
Spilled milk onto keyboard of toshiba satellite A205-S5800
Well ..Spilling anything on a laptop or any computer component is always a no-no situation. I couldn't tell you what you may have "broke" but I highly doubt that it was just a "fuse"
Nov 18, 2008 | Toshiba Satellite A205-S4617 Notebook
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
