Question about Rheem EcoSense by 7.4 GPM Tankless Water Heater Natural Gas High Altitude
How do I flush this unit
I was told to run vinegar through it to descale it. How do I do that?
  • Rheem Master
  • 5,245 Answers
1) Copy following link for steps showing how to run white vinegar through Rheem tanklessx heat exchanger to partially remove scale that coats heat exchanger and reduces unit efficiency and causes error code IL:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#de-lime
2) Tankless are prone to scale inside heat exchanger and require yearly deliming to mitigate effects. Do the required yearly maintenance to avoid common error codes.
3) Expected cost of maintenance and repair is more expensive than estimated $1-8 monthly energy-bill savings from owning tankless.
Posted on Dec 31, 2012
Descale a showerhead
  1. What to do
    1. Unscrew the head of the shower from the hose. This may be quite stiff. ...
    2. If it is possible, unscrew the rose attachment from the shower head. ...
    3. Soak the parts in the descaling agent or white vinegar overnight. ...
    4. Reassemble the parts, checking that the rubber washer for the hose is in place.
Descaling shower head
Jul 21, 2015 | Water Water Heaters
Is white vinegar a god descaler for the heat exchanger?
white vinegar is good for that, but make sure you have all the equipment that you need to do this. Go to http://waterheatertimer.org/troubleshoot-bosch-tankless-water-heater.html. that will give you all the info un need
Mar 16, 2015 | Water Heaters
Fill tank& descale keep flashing.
Fill the reservoir with white vinegar and run a cycle. Discard the vinegar and repeat the process a second time. that should remove the scale and reset the flashing light.
May 19, 2014 | Bosch TAS2002GB Tassimo T20 Hot Beverage...
Descaling bosch 125hx ng
no you do not, but it is a good idea to take the hydrogenerator apart and remove the waterwheel inside to protect it from damage(if you have anything that gets shot through the pump)
Connections are 1/2 inch.
Dec 09, 2013 | Bosch AquaStar Natural Gas Tankless Water...
Powerstar ae125 runs hot then cold in shower
Increase your flow, sounds like you are right at your activation rate.
1 way is to turn down the temp on the machine, so you dont have to mix in so much cold at your shower. Check to see if your mixing valve is bad, or your showerhead has restriction/scale built up in it.The other way is to turn on your lavatory fixture full hot before showering(which will keep hot water flowing through the machine as you adjust your temp to be comfortable.
Nov 24, 2013 | Bosch PowerStar AE115 Tankless Water...
Descaling instructions bosh filtrino fast cup
It took me ages to get his to work - seems that on the THD2023GB (Black) Filtrino, you push and hold the temp. set button for 10 seconds to get he descale programme running.
Sep 30, 2012 | Bosch Thd2021gb Filtrino Fast Cup Hot...
I have a Rinnai R75LS and have it hooked up to clean with vinegar. However the R75LS will not allow the vinegar to flow through. I have watched videos etc. and seem to be unable to get the vinegar to...
I'm assuming you heater will let water flow through and it's not completely blocked with scale. There is a motorised valve that needs to be open. Start with the heater connected normally and run a hot tap. While it is firing turn off the power, this will leave the valve in it's open state.Now connect up your heater to the vinegar supply; do not turn the power back on.
Sep 16, 2010 | Rinnai Webstone The isolator EXP tankless...
Sediment in lines -Bosch Tankless Water heater
I would recommend a simple sediment filter housing be installed on the main water line coming into the house. Material cost about $100. Have a plumber install a bypass loop so you can just shut off 2 valves when you need to change it. I always install one with any tankless heater as cheap insurance against such a problem. As far as adding something to clean the lines I would refer to the manufacturer's instructions and use only what they recommend in order to preserve your warranty. For a solar water heater I prefer Velux.
Please rate if this helps-
Mar 28, 2009 | Bosch & Tankless LP Hot Water Heater
Rheem EcoSense by  7.4 GPM Tankless Water Heater Natural Gas High Altitude Logo
150 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
