Question about Samsung SW62ASP Top Load Washer
Won't rinse on cold only hot
Will only fill for rinse on hot my husband double checked hoses and taps all is good there
    Scholar:
  • 133 Answers
Are the pipes on the wrong way around?
Posted on Jan 01, 2013
EW1200 is rinsing in hot water how do we change that
Hot wash, hot rinse is for 'whites'. Cold wash, cold rinse is for 'colors'. Warm wash, cold or warm rinse is for 'permanent press'. Check your settings to see if you have these options. Double check the hoses, put the machine on cold fill and feel the hoses.
Has someone worked on the machine and possibly put the wires on the solenoids wrong? Easy mistake to make.
Mar 10, 2012 | Electrolux EW1200i Front Load Washer /...
DOES MY WIXL143S INDESIT USE HOT OR COLD MAINS
That's easy to tell- if it has 2 inlet pipe/hose connections at the back (as opposed to the outlet pipe which is permanently connected to the washer and hooks over the outlet drain) then it is a hot and cold fill. If there is only one inlet pipe it is cold fill only. Either type HAS to have a cold fill supply- to lower the temperature of the hot water for cool washes AND for rinsing which is normally cold water only.
If you have only a cold water tap/fawcet available for the washer and it is a hot and cold fill you will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end (internal thread) screws into the cold water supply and the hot and cold washer pipes screw into the double end (external threads). The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
Hope this has clarified!
John C
Oct 29, 2011 | Indesit W 123 Front Load Washer
Washer will not fill on cold water at the start of any cycle but will fill on the rinse cycle every cycle. Is this a timer problem?
This sounds like a hot AND cold fill washer? If so ->
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 23, 2011 | Maytag Atlantis MAV7000
Wf7604naw problem is flashes d4 water not going into machine to wash cycle but will rinse no problem can i do anythin myself just wont let me do any program on any wash flashes d4 water getting in to rinse
From what you say it appears that there is a problem with the hot water supply- if yours is hot and cold fill. Rinses use only cold water normally. The following I pre-typed to cover hot and cold fill problems!
John C
Oct 14, 2011 | Samsung Washing Machines
My washing machine won't fill with water, water is going into the powder drawer but won't fill up the clothes barrel, I have checked the filter at the front and have done this many times so there...
Although you say that there is enough water for the dispenser it is well worth carrying out the following, especially because of the 'clicking' ;-0)
John C
Sep 18, 2011 | Washing Machines
My washing machine starts to fill, but then stops filling after approx. 5 seconds. I have found that if I fill it manually, it will do a full wash cycle. (including rinse).
John C
Sep 12, 2011 | Washing Machines
Bosh classic 1200 won't fill with water,
John C
Jul 22, 2011 | Washing Machines
HOTPOINT ULTIMA WD71..WHEN THE MACHINE IS SWITCHED ON TO A WASH PROGRAM IT WORKS FINE FILLING WITH HOT WATER THEN STARTS ITS CYCLE. WHEN THE MACHINE REACHES THE RINSE1 CYCLE IT STOPS WITH A E10 ERROR CODE....
Following is pre-typed, saves time - in your case just refer to 'cold' please ;-0)
John C
Jul 16, 2011 | Hotpoint Ultima WF860 Front Load Washer
My washer won't fill water to wash or rinse
John C
Jul 13, 2011 | Washing Machines
I have a Fisher and Paykal MW512. When starting the machine on cold cycle the water only comes out in dribbles. On a hot cycle the it will fill but when it gets to the rinse it will not fill with water. Is...
had similar issue - cold water wouldn't come thorugh to fill the drum but the hot would. (changed the hot water hose to the cold water tap as an interim fix). father and husband managed to get the lid off the machine (screwdriver prising involved to flip the lid off the tabs near the front of the machine) then they were able to get in and have a look. ended up being a solanoid (spelling?) that had died. basically this part has magnetic parts to open/close the valve and the magnets had died or something. part replaced -- cost about $65. machine working fine now. hope that helps and made sense!
Apr 06, 2011 | Fisher and Paykel Fisher & Paykel Washer
Samsung SW62ASP Top Load Washer Logo
35 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
