Question about Magnavox "32MD350B/F7 32-Inch 720p LCD HDTV with Built in DVD player, Black"
Tv will not power after lightining - Magnavox "32MD350B/F7 32-Inch 720p LCD HDTV with Built in DVD player, Black"
  • Magnavox Master
  • 933 Answers
When you plug in the set, does the power indicator turn on?
Posted on Feb 15, 2013
Will not turn on?
the lightining battery is not working very well. You should exchange it, so the TV power could get to the Tv and let it Work.
Feb 28, 2008 | RCA F36685 36" TV
Lighting strike 42 inch phillps tv mill not turn on
I would first look at the power supply board. it might be a removable fuse. unplug the TV first, remove the back of TV check the area to where the power cord comes into the TV. it should be real close to the power supply board.I have had a couple of quick fixes by just replacing the fuse. (that means it did it's job) if that doesn't fix it try to get the part # from the power supply board and check with Shop Jimmy.com for replacement board. (easy fix) take pictures of the back of TV with cover off and of the power supply board before u do anything. Leave the old board in place till the new one comes in. that way you won't forget where the cables went etc. Just be careful cause the dead board can still hold a charge so handle with care.
Sep 21, 2014 | Philips 42PFL5603D 42 in. LCD HDTV
My tv is lg 32LK330, on power on the tv shows LG logo screen ( startup screen) and tv turns off and this happens in cyclic order. there was lightin the night before
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary
Aug 31, 2014 | Televison & Video
Fault with main board. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too will be necessary.
Lightining sign on dash mean
If the red light dims severely or goes out when you try to start it you have a flat battery, highly likely if that red symbol has been on while the motor has been running because the alternator hasn't been charging. It could mean you have a broken drive belt but that would also mean no power steering, AC or coolant pump drive so that would have been obvious fairly quickly.
Jun 02, 2012 | 2006 Jeep Grand Cherokee
Need service code for rca proj tv mod d52w2o
thank you for your follow-up on my request. i simply needed the service code access for the set i named. i found it elsewhere- just hold down vol. down-channel down for 8 seconds until set powers up. i needed to access the dynamic digital convergence-had to perform complete convergence. lightining strike had apparently erased settings.
Jun 25, 2008 | Televison & Video
Unit will not power on
IT NEEDS TO REPAIR BADLY.CHECK FUSE AND REPLACE IT W/THE SAME VALUE IF IT IS BLOWN.AND THEN TRY TO TURN IT ON AFTER YOU CLOSE THE T.V. SET
Jun 10, 2008 | Sanyo DS31590 31" TV
Screen dont work
proabably it,s because you left it on for long time , or the image power saver is wrecked and damaged after a storng lightinning , and if you have cleaned ther tv screen with a wet wiper it causes that to happen
May 11, 2008 | RCA P52937 52" Rear Projection Television
I have sony Kv -35 tv struck by lightining and stop working ,is ther a fix
depends. I have seen Boards getting completely destroyed by lightnining, and I have boards where the damage is very minimal.
Only a good Technician can assess.
I Suggest that you get a good service guy to have an initial look.
Mar 15, 2008 | Sony KV-35V35 TV
Magnavox "32MD350B/F7 32-Inch 720p LCD HDTV with Built in DVD player, Black" Logo
90 people viewed this question
Top Magnavox Televison & Video Experts
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
