Question about Dryers
My 110.66652500 must have the 4" diameter extension at the base in the back to go through my doorway. How do I take that part off ?
  • Dryers Master
  • 3,289 Answers
All right, here's what I'd do.Consider which of these two might work for you.
1) Remove the trim around the door frame and then remove that part of the door frame to allow youself the extra inches to slide the dryer through.
If you are quite handy, you might even make a few small cuts with a saw to widen the door space, and put it all back together.
2) Cut off the sheet metal extension about 1 inch from the "elbow".
Save your cut off piece, and put it back together with a sheet metal sleeve, that you can make from some scrap.
Use the drill I see you have to make several small screw holes in both the piece on the back of the machine and the piece you cut off.
Think in terms a cast on a broken arm for the picture in your mind.
Maybe even do both.
Be blessed.
Posted on Jan 24, 2013
How do I pull apart st3352 treadmill to fit through doorway?
tip it on its side and put the handles through first and then maneuver the base through after
tip it back right side up when in the next room
May 31, 2016 | Exercise & Fitness
My air med us8000 massage chair will not fit through the doorway. Can the unit be made to remain reclined after shut off or can the arms be removed?
Most large recliners have removable backs. You must lift the rear shirt and look for the release latches. There will probably be an electrical connector or two as well if the device is a massage chair. Once you remove the back, then you can turn the chair on its side and then it should fit through most doorways.
Jan 02, 2016 | Furniture
How do I move my Proform Treadmill to another room without taking it apart completely. It will not fit thru the doorway and too heavy to lift alone.
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I hope this helps. I am not sure what model you have but i have the 525x. To move it I make sure the incline is set to zero, list the track/running section and lock it into place with the locking pin located on one of the handles. The Proform i have has attached wheels so i lean it back and get it close to the door standing straight up. Once there I turn the treadmill slightly and get one side through the doorway then I pull it halfway through the doorway. If its a tile, wood or linoleum floor make sure to put a rug under the treadmill to protect the floor. It will also helo it slide through the doorway easier. Then tuun the treadmill slightly the other way and get the other half through the door. Once there i tilt it back on its wheels and move it where i want it.
Jun 18, 2010 | Proform Crosswalk 500 Treadmill
I have a sharp microwave-convection model #r-7a85. how many watts this oven needs or have thank you
800 or 1000 are standard wattages. It should say on the plate on the inside 'doorway' of your oven - that is where I find that info on my sharp microwave. It could be on the back but, like I say, normally inside the 'doorway' to the oven
Dec 27, 2009 | Sharp R-7A85 Microwave Oven
Westinghouse 64832 pole lantern specs
A standard lamp post is 3 inches diameter. The base of the lantern slips over the post. It's inside diameter is slightly larger than 3 inches and a screw is used to tighten the base against the post.
Nov 07, 2009 | Westinghouse Electric Westinghouse 64832...
Get Life Fitness 9700 generation treadmill through doorway
You need to remove the upper console arms/assembly - unbolt the five or six large bolts holding the frame to the base (you will need to remove the motor hood) and unplug the cable from the circuit board that goes up inside the arm to the console (make sure the power is unplugged!) use a 3/4'' ring spanner or socket.
Sep 01, 2009 | Life Fitness 9700 Next Generation...
My GE instajack is not working. It had a greeen signal, now it has a red signal.
Most likely, the extension unit cannot communicate with the
indicator light is solid base unit for one of the following reasons:
red • Base unit has yet to be installed. Install base unit. (Refer to
the Set Up section.)
• Extension is too far from the base unit. Relocate either the
base or extension unit to another electrical outlet. If
indicator light on extension
unit remains solid red, reprogram the link code on extension
unit
Follow these steps:
• Press and hold the button on the right side of the base
unit until the indicator light changes to solid red.
(Approximately five seconds.)
• Release the button, then the indicator light will blink orange.
This creates a new link code and places the base unit into
program mode.
• Follow steps (2) and (3) in the Additional Extension Units
section for all extension units.
• Press and release the button on the base unit to take it out of
program mode. The indicator light will change from flashing
orange to solid green.
Oct 10, 2008 | Computers & Internet
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
Just bought an additional handset for GE 27951 expandable 6.0 DECT Cordless. I press and hold the Page button for 5 seconds but the new handset will not register. Error keeps occurring "no base."
This exact thing happened to me. Same model number. No matter what I did, the new handsets would not register.
The solution? Reset the entire system:
1. On the BASE - Unplug from wall both power and phone line. Unplug battery from base handset.
2. ON the Extension phone - unplug from wall and unplug battery from handset.
3. Wait AT LEAST 5 minutes.
4. Plug back in BASE power.
5. Plug back in BASE phone line.
6. Plug back in EXTENSION handset battery. Don't plug in BASE handset yet.
7. Follow steps to program EXTENSION. When successful:
8. Plug back in BASE handset battery.
Apr 02, 2008 | Lands Phones
Dryers Logo
150 people viewed this question
Top Dryers Experts
