Question about Water Heaters
Very minimal hot water being produced from my water heater
Lately, my hot water heater is not producing very much hot water. Also, my pilot has started going out frequently. It relights w/no problem, but seems to go out. It is a 40 gal. gas hot water heater.
  • Water Heaters Master
  • 5,245 Answers
1) Clean air intake, and do required yearly maintenance.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Gas control valve thermostat could be going bad, causing disruption of gas to pilot, and uneven heating of water.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
3) Without knowing brand and model number that shows on label on side of tank, it is difficult to add specifics.
Posted on Dec 31, 2012
  • 297 Answers
SOURCE: I have a 6 gal Atwood hot water heater. I can
Kenny did you change the thermo coupler?
Posted on Jul 14, 2009
SOURCE: Rheem 40 gallon gas hot water heater, pilot light
To make a short story long (I need to include all details, sry)…
I got up one morning and realized that we did not have hot water. I re-lit the pilot light and as soon as the burner went out from heating the water up, the pilot light would go out. After reading several posts regarding this issue, it seemed apparent that the thermo-coupler was the problem. Since I am a little bit handy around the house and very tight when it comes to opening my wallet, I bought the device from Lowe’s ($8.98) that was recommended by my online advisors and after a few googles, figured out how to change it. No help. The pilot light still goes out.
I gave up and went to Home Depot to purchase and schedule the installation of a new hot water heater.
STICKER SHOCK
A new Direct Vent type water heater costs around $800 with an additional $450 for “special” installation. Add a few fees to that and the grand total came to about $1450.
I felt like I had no choice since my wife and 2 daughters refused to live their life without hot water and I had no clue about how to fix the dam thing.
The plumber assigned to the installation stopped by to evaluate the site conditions and quickly noted to me that the 8 year old water heater tank was in good condition and that the gas controller was probably faulty, which could be purchased online from the manufacturer. I quickly cancelled the Home Depot order and purchased the controller for about $120 after shipping and tax. Immediately after the installation it seemed that the problem had been solved. A few days later the pilot light went out.
I called the plumber and explained the situation and he recommended that I purchase another controller because the one that was shipped to me was probably bad. I searched around town and found a plumbing supply company that had the correct model in stock. Two days later the pilot light was out. I cleaned up the controller and returned it to the store and asked the plumber to please schedule a visit to repair this dam thing.
When the plumber arrived, he hooked up a gauge in several locations and confirmed that the correct amount of gas (cfm) was being delivered to the controller, pilot light and burner. He then proceeded to remove the fire box to make sure that the igniter, thermo-coupler and pilot tip were set properly. He inspected the pilot light tip and said that he found the problem. Using about a 1/64” tip drill (can be purchased at a welding supply store), he cleaned the tiny hole that releases gas to the pilot light. I felt a sigh of relief because I was certain that the problem had been solved. $65 dollars (plumber’s fee for an hour of work) and 4 days later the pilot light went out.
I called the plumber and he said that the controller that I purchased online must be bad. Too embarrassed to return to the first plumbing supply store, I found another one in a different town that had the correct model in stock. Three days after changing the controller the pilot light went out. I returned the controller and a six pack later I decided to do some extensive googling.
The key term here is “DIRECT VENT”. This seems to be a very common problem with direct vent water heaters and I was about to find out the reason for this phenomenon. I read a post by an individual who wrote that if the vent becomes detached that the inflow of air can become contaminated and extinguish the pilot light. I decided that before I spent any more money on a plumber that I was going to take the vent apart and find out what makes it tick.
My direct vent system has 2 parts to the venting, an inner pipe (3” nominal diameter) that serves as the exhaust and the outer pipe (5” nominal diameter) that serves as the internal flow of air which supplies the pilot light and burner with oxygen. On the outside of the house a vent hood helps to segregate the two by extending the exhaust about 3” beyond the intake. I looked into the hood at the end of the pipes and discovered that the internal pipe which consisted of a 2 piece slip joint had come loose from the elbow that sets on top of the water heater. This slip joint pipe was not attached at any point with screws or clamps and was loosely setting over the elbow on one end and into the hood on the other end, allowing it to detach. Apparently, when atmospheric conditions were right, the burner idled down from heating up the water and extinguished the pilot light because the intake was saturated with CO2 from the connection failure.
I purchased a section of 3” pipe that was long enough to be installed in one piece. I connected it to the elbow using a stainless steel hose clamp. I had to disassemble the pipe 3 times to make adjustments to the length and position before I got it right, but I should not have any more problems with the pilot light.
The problem here is time. It takes a lot of time to get this right. When the plumbing contractors installed this unit during the construction of the house, there was no one around to make sure that they got it right. It is probably common to use a 2 piece slip joint type connection, but I feel like it should be attached with screws or clamps. In my opinion it is not rigid enough and can detach easily, especially if it is not installed properly. A one piece connection that is attached at one end with a hose clamp and then held in place at the other end by the hood is fool proof.
Posted on Sep 27, 2009
  • 744 Answers
SOURCE: pilot light on water heater goes out frequently
Check the following:
See if your heater has a pilot gas adjustment valve. It should be on the gas control valve somewhere. Not all heaters have these. It will be a screw on the valve that can be turned.
Make sure the thermocouple sensing bulb is squarely in the pilot flame and also check that the fitting where the other end of the thermocouple connects to the main gas valve is tight.
Check the pilot gas orifice (where the pilot gas comes out) for carbon build up - you may need to remove the pilot gas line and thermocouple assembly to get to this. This problem is pretty common.
Check the gas pressure to the heater. Run the hot water in the dwelling until the hot water heater starts. Check the flame on the main burner and see what color it is - it should be blue with possibly some yellow-tipped flames. If not, there could be a problem with the gas pressure at the heater or venting. If the heater has a gas pressure regulator, it may be out of adjustment or defective.
Finally, and this isn't very common, the pilot light can be extinguished if there is a draft problem, usually associated with an issue with the flue pipe venting system for the heater or another nearby gas consuming appliance.
Posted on Dec 31, 2009
Testimonial: "thank you. will try these suggestions tomorrow. really appreciate it."
kel1guy2002
  • 3740 Answers
SOURCE: pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Posted on Jan 23, 2010
Testimonial: "exactly what I wanted yo know. thank you"
heatman101
  • 43501 Answers
SOURCE: Pilot will not relight properly
The thermocouple needs to be replaced. That is what keeps the pilot light lit. The thermocouple is the little metal probe that sticks up into the pilot flame. Very easy to replace.
heatman101
Posted on Mar 26, 2010
Water heater pilot light keeps goin out when i release gas valve button during pilot lighting process.. Ive repeated 5 times waitin 10mins in between but the samething keeps happening.... Any...
There is usually a thermocouple switch which produces a minute current to keep the pilot flame switched on after the button is released. You would need to have a gas plumber look at it. Col
Jan 25, 2018 | Water Water Heaters
Pilot light lights but goes out when i turn valve to on
Near the pilot there should be a small metal bulb at the end of what looks like a wire which leads back to the control valve. It's called a thermocouple and it produces a small electrical current when heated. Non-electric heating units have a similar device which does the same job using pressure produced by heating a fluid within the bulb but for our purposes here the difference between the two doesn't matter. The function of the thermocouple is to hold the gas valve open for normal operation of the pilot. If the pilot flame goes out the thermocouple cools and disables the valve so that when the thermostat calls for heat, the gas will not be released if there is no pilot to light the burner. Check to make sure the bulb is being heated by the pilot flame, it may need to be repositioned or the pilot may need to be cleaned of carbon buildup to make it produce an adequate flame. If the thermocouple is close enough to an adequate pilot flame and still you cannot sustain the pilot flame when going from "pilot" to "on" position, the thermocouple is probably the problem so replace it. If the problem still exists, assuming you have already made certain that you have an adequate fuel supply, the problem is in the burner control valve. Changing that is something you should consider leaving to a qualified service person.
Jun 30, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
Pilot will light after 30 seconds when you try to move knob to on position the pilot goes out and heater won't ignite.
You need to replace the thermocouple.
When you light the pilot it is supose to heat the thermocouple.
the thermocouple produces a small electric current which allows the gas valve to open and keep the pilot going. and allowing the main burner to come on.
Jun 21, 2011 | RTO Atwood Water Heater - 6 Gal LP
Pilot hard to lite when lites stays on about 15 minutes goes out this is on reliance gas hot water heater 101
The thermocouple has gone bad or in this case is going bad to the point that it is useless.
The thermocouple is the pilot's, well, co-pilot! It is the electronic device that senses if the pilot flame is hot enough to ignite natural gas or propane fuel to the burner. If the thermocouple thinks it's safe, then it keeps open the main gas valve located in the pilot assembly. If the thermocouple does not sense enough heat from the pilot flame (such as when the pilot is out), then the thermocouple shuts off the gas valve to the burners.
How the Thermocouple Works
So what is this thing and how does it work? Well the thermocouple (technically called a thermocouple junction) is a device that contains two metal wires welded at the ends and placed inside a protective metal case. The thermocouple sensor is found at the business end of the pilot flame and is designed to be placed in the hottest part of the flame. The other end is connected to the pilot valve body. As the thermocouple heats up, it produces a small amount of electricity and when it gets hot enough from the pilot, send a signal to open the gas valve by using a solenoid operated by a 24 volt transformer. The thermocouple calls the shots, and by converting heat to an electrical signal, it allows the gas valve to open or close. Once the gas valve is open, gas is then constantly supplied to the pilot and as required for the gas burners (as called for by the thermostat). If the pilot goes out, then the thermocouple gets cold and produces no electric signal to open the gas valve's solenoid and the gas valve shuts off the gas supply to the pilot and burners. Neat huh?
Feb 04, 2011 | RTO W4 A.O Smith Gas Hot Water Heater...
Bosch aquastar Aq125-hx does not produce hot water. Pilot is ok. Gas and Flame heat is ok. water pressure is ok. Just no hot water getting to the faucets. Help.
That particular tankless water heater has hydro-generated ignition. In order for it to function, it requires a certain water pressure and velocity. You can try turning on the hot water in two location in your house to see if that gets it started. If it does, try getting a higher flow shower head, or removing the limiters in your faucets.
Jan 07, 2011 | Bosch AquaStar Indoor Natural Gas Tankless...
Limited hot water output
are both heating element getting electricity?  Are they both good?  Are the temp settings on both the same?
Mar 15, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water Heater will not stay lit.
Sounds like you are getting a downdraft . Or a delayed ignition What type of water heater is it ? One that stores hot water like a 30 Gal natural gas or LPG water heater? Tankless don't use standing pilot. Where is the heater? In a closet or a utility room. Whats the condition of the flue pipe. How many bends how long is the run? In other words Please have a licensed plumber check it out because you are dealing with an appliance that produces a poisonous Gas called CO (Carbon Monoxide) It's colorless, odorless, and it kills. And it don't care who.
Jan 09, 2009 | Rheem Tankless water heater for 1-2...
Noritz tankless water heater not producing hot water
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
Jan 04, 2009 | Noritz 6.9 Gallon Residential Direct Vent...
Water Heaters Logo
123 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
