Question about Holmes Products HM5601-UC 1.8 Gallon Humidifier
Holmes hm5601 humidifier stopped working - Holmes Products HM5601-UC 1.8 Gallon Humidifier
4 Suggested Answers
SOURCE: need a manual for Holmes
I have a manual for the Holmes Model HM5601. If you contact me I can make a copy & mail
it to you.
My email is jadamson7@cogeco.ca
Dave
Posted on Jan 09, 2009
SOURCE: reset light on holmes product hls5000 humidifier
turn knob to reset....leave 15 minutes and then turn on
Posted on Feb 03, 2009
SOURCE: humidifier doesn't stop
I had the same problem if you dissasemble the unit you will probably find a capacitor between two blue wires has blown out
Posted on Jun 04, 2009
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
Need new rubber tank gasket for Holmes humidifier Model HM4600
after scouring the INTERNET AND FINDING PLENTY OF SITES THAT WOULD SELL ME THE WHOLE CAP FOR 24.00. I MAD MINE USING SOMETHING FROM ace hardware THAT COST 2.50 Small suction cups with the hook [CDBL-7500S11] PART NUMBER 7500 .CAN BE MODIFIED INTO MAKING YOUR OWN GASKET. IT WORKED FOR ME ..REMOVE HOOK FROM SMALL SUCTION CUP. cut off nib with sharp pair of scissors. THEN DRILL HOLE THROUGH CENTER OF CUP WITH 7/64 DRILL BIT. re insert plunger part of cap through cap with spring and re- attach suction cup instead of gasket. MINE WORKS FINE ON A HOLMES 3700
woodinvirginia
Jan 23, 2011 | Holmes Products HM4600-U 11 Gallon...
I HAVE A HM 5700 HUMIDFIER AND NEED A NEW CAP FOR THE TANK CAN YOU HELP ?
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 06, 2011 | Holmes Products Warm Mist HM5700...
No mist!
unfortunately on a cool mist unit the mist shouldn't show up. on most units that's what it does. the warm mist units show the mist.. the best way to tell is if you put your hand over the spout that the mist is suppose to come out of for about 2 minutes and you pull it away and it feel clammy then it's working. if your hand is still dry please let me know and i'll see what else i can do for you.
Feb 26, 2009 | Holmes Products HM500-UC 1 Gallon...
Where can I buy a WMF50 filter for my Holmes warm mist Humidifier in St, Catharines Ontario Canada Dave
I found that Home Depot had 9 left in the store and that they will not carry them any more so
we bought the last 9 and hope they will last for a while and then may have to contact you again
to find out where else to look.
Thank You
Dave Adamson
Jan 07, 2009 | Holmes Products HM5601-UC 1.8 Gallon...
Reset light on holmes product hls5000 humidifier
Jan 03, 2009 | Holmes Products Halls HLS5000-U Humidifier
Need a manual for Holmes Model HM5601.
it to you.
Dave
Dec 10, 2008 | Holmes Products HM5601-UC 1.8 Gallon...
Holmes HM5601 quit working
I had the same problem with my Holmes HM5601 humidifer unit - right out of the box. I almost returned the unit to the store, but was able to figure-out the problem. Not enough water had been filling the heating section (where that black knob-like protrusion is) and the lack of enough water had caused the unit to shut-off soon after plugging it in. The problem is in valve at the bottom of the water tank! The valve is a factory defect. It needs to open more when you sit the water tank onto the base so water fills the reservoir. I had solved the problem by going to the hardware store and purchasing some small, rubber pads or feet. These rubber pads are the type used to place under things where you want to protect a table-top from being scratched or you want the item not to slide too easily on a table-top. These rubber feet or pads have an adhesive on the bottom of them. Find the size that matches the diameter of the valve stem on the bottom of the water tank. Once installed, the valve should open and close with your finger without the rubber pad interferring with the operation of the valve. The pad, if installed properly, makes contact with the water reservoir base when you placed the water tank down onto that base. The valve open a bit more allowing water to pass-thru and fill the water reservoir. Water fills the heating section as needed and the unit runs perfectly after! The round rubber pad I had used was about an 1/8 inch thick and 1/2 inch in diameter.
Nov 30, 2008 | Humidifiers
Humidifier doesn't stop
Mar 30, 2008 | Holmes Products Cool Mist HM3500...
Holmes Products HM5601-UC 1.8 Gallon Humidifier Logo
75 people viewed this question
Top Holmes Products Humidifiers Experts
cwradio73
Ben Eng
Level 1 Expert
Matthew Wyatt
Level 1 Expert
Are you a Holmes Products Humidifier Expert? Answer questions, earn points and help others
