Question about Rheem Water Heaters
My Rheemglass Fury is not putting out much hot water
My Rheem Hot water heater is not producing much hot water just recently. It is a 40 gal @36,000 BTUM
    Genius:
  • 1,669 Answers
I believe that there are 2 separate electric heating coils in this unit (unless you are talking about the GAS unit). One of the coils either has a wire broken or the element needs to be replaced!
Posted on Dec 31, 2012
  • Aaron Wakefield Jan 02, 2013
    Yes, it is a "Gas" hot water heater. Do they have 2 heater elements or coils like elect. heaters?
  • Leigh Perlmutter
    Leigh Perlmutter Jan 02, 2013
    Nope! No such thing! There is a burner plate at the bottom of the unit that has holes in it that have jets of burning gas going up to heat the tank. TURN OFF THE GAS and then open the front panel to see the burner unit. You will need some brushes, preferably brass wire types that you can get in a hardware store. Carefully brush the carbon off of the burners. Then go for the igniter, but first TURN OFF THE BREAKER FOR THE IGNITER (if it is electronically self starting) and clean off the contacts with vinegar. If there is a pilot light instead, clean it off carefully with vinegar. Next, wait a few minutes for the igniter or pilot light area to dry then turn on the electric breaker for the igniter and then the gas or just turn on the gas for the electronic igniter and wait for it!!
Relief valve buzzing noise
Add an extrol expansion tank to the piping. You can get one for about thirty dollars from the hardware store.
Apr 06, 2014 | Rheem 82V40-2 Fury Electric Residential...
Can i use a thermal blanket for my Rheem Glasfury 82v40-2 hot water heater
Modern water heaters are well insulated to the point that adding additional insulation is not beneficial. Some units may also suffer from a blanket blocking air vents or causing condensation build up.
Dec 31, 2012 | Rheem 82V40-2 Fury Electric Residential...
Water discoloration. Rhreem serial rh0909ff00279 date 9/2003 model 8v520c 50 gal electric rheemglas fury. prolem occures when we use hot water. tried fixing...backwashed, drained water out completely...
Brown discoloration is evidence of a rusting or corroded steel pipe somewhere in you plumbing system. Trace the water lines back from the faucet and replace all the steel pipe.
White discoloration is minerals that separate out when the water is heated.
You can change the Anode Rod and it should help. It is not an instant fix, the rod will take a week or two to do its job.
If your water heater is still under warranty, call Rheem, they may replace the water heater free.
Sep 07, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
6 yr old electric rheem fury 50 gallon all of a sudden runs out of hot water. Only one shower of hot water now where before atleast two.
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
Mar 25, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Water Heaters Logo
79 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
