Question about Vivitar MAGNACAM Binocular
Can take photo but it is not what was in the sights- how to fix
When taking a photo only a small part of it is shown
seems to need adjusting-how to adjust the sights
  • Anonymous Jan 19, 2009
    what i see thru the viewfinder is not what the photo shows afer downloading.....the actual photo is a larger small portion of what i was actually looking at......how am i supposed to know what i am actually
    taking a picture of?
  • TeacherVA Jan 24, 2009
    I have the same problem. I have the manual, and a copy of it is found on the software that came with the camera. Neither explains how to set the camera, and what the setting options mean. Does anyone know if setting the high or low definition modes would affect that?
  • 90 Answers
Does the bonoculars have a users manual? If not, you can download a users manual, by Googling "users manual" and a bunch of sites will come up to check out users manuals for various products.
Posted on Jan 20, 2009
Nikon Coolpix S32 watreproof camera doesn't focusing properly
You have to know if the FOCUS is the issue or SHUTTER SPEED. In most cases with most CoolPix Cameras if the Image is not in focus (When you push shutter down HALFWAY) the Focus Rectangle will not be GREEN... If it RED it cannot focus. If every time you take a photo the focus area is red then it is not focusing. Small Coolpix cameras have difficulty focusing in low light.
Low light can make a hand held image look blurry because of hand shake. If the light is so low it wants to take a long exposure. This works with a tripod, but not with a hand held photo. With most of these small cameras you can take 1 second night photos with a tripod. They would look horrible handheld.
Typically on the Coolpix cameras you can set the FOCUS mode. It is usually shown with a FLOWER for MACRO... You get AF / FLOWER / MOUNTAIN / MANUAL (may not have this)
Plase make sure your FOCUS MODE is in AF AF is the ONLY Mode where the camera will focus CLOSE and FAR... Light is not your problem..... It seems it is your FOCUS MODE.
Jan 21, 2017 | Nikon Coolpix S32 White 13.2 Megapixel...
Aker swrilbath tub want change jet colors
Jet Trim in your jetted bath tub have to be matched up by sight.
Click on the link below to find the brand name of your bathtub, then click on the name.
http://uspartscenter.com/bath-search.aspx
Match up each item in your tub to what is shown online.
If you are unable to match the pieces up to what is shown online to what you have in your tub you may email us photos and we will match them up for you.
send photos to: sales@uspartscenter.com
Rod Kidman
US Parts Center
We locate the "seemingly" impossible...
Ph: 888-521-6183
Fax: 801-417-8027
Apr 06, 2013 | Whirlpool Royal A101A-R Bath Tub
My 20mm sight fell apart, how do i fix it
Sight??? If the small finderscope feel apart you can buy another one of better quality here:
http://www.telescope.com/Accessories/Telescope-Finder-Scopes/pc/3/49.uts
If you mean the eyepiece fell apart then the same Company shown above (Orion) also sells eyepieces.
www.telescopeman.org
www.telescopeman.info
www.telescopeman.us
Aug 09, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Photo result of my camera webcam eeepc 1005ha is too dark. Preview is ok but when I take the picture it's too dark. how can I fix this?
one solution,it might seem obvious is rather than adjust the pc's settings which are only variable by a certain small amount without losing resolution is--yes--!!--make sure you have better lighting when the picture is taken,,these cameras certainly dont like artificial light much--a specialist photography lighting might work better.
Nov 01, 2009 | ASUS Eee PC 1000HA Notebook
I am trying to bore sight a rifle with a center point 4x16x40 and i run out of adjustment to get the lazer to align with the cross hairs
When bore sighting you need to adjust in small steps and "TAP" the bore or the main body of your scope to cause a golt, as when shooting your gun it will kick and cause the scope cross hairs to take their set.  Tap it with a med sized screw driver handle. Make a small adjustment and tap it, adjust and tap.
Sep 23, 2009 | Centerpoint Technologies CenterPoint...
Side to side adjustment loose on 94 winchester
Remove the rear sight the receiver should be dove tail cut.Take a small hammer and tap the edges then you will have to tap the sight back in.This is how I fix then in shop,Good luck!
Sep 14, 2009 | Sport & Outdoor - Others
Windage and elevation adjustment all over the place
Sounds like you want to "re-sight" in your rifle. Make sure mounts are okay and tight. Look down barrel and then thru scope and eyeball windage and elevation adjustments so the scope seems to be fairly in line.
Clean barrel if it needs it.
For basic sight in, start at 25 yards with a large(3 to 4 feet) cardboard or wood backdrop around target (bullseye). Fire at target. Once done, look through scope and position rifle such that the shot mark you created is dead zero. Hold rifle very steady and you or buddy move windage and elevation adjustments until scope moves dead zero back toward original target (bullseye). Fine tune from there. Air cool rifle between rounds. Once dead eye, fire another round or two to check grouping. Check your ballistics (sometimes on ammo box) to see how height at 25 yards affects your desired dead on target (100 yards, 150 yards, 250 yards etc.). Adjust accordingly. Example: you may need to sight in at an inch high at 25 yards, depending on your dead on target distance..
Always remove sling from barrel when sighting in.
Try to sight in at similar temperature as you intended shooting temperatures, if possible.
If not black powder, avoid cleaning barrel between sight in and hunt/competition unless you note bad buildup inside.
If you change ammo, understand that that may affect performance. Once a preferred ammo is found, some even try to buy a decent quantity with the same lot number on the boxes if storage allows for such.
May 02, 2009 | Optics
Cannon A530 View screen has gone blank
Usually this is beacause you press the button "visible", all camera have this button to choose the visible model of the LED, you can turn off it to save power to take more photos by view sight from the small sight window above the screen.
bp-511
Feb 11, 2009 | Cannon Cameras
Dell W1700 picture went out. Still have audio.
I have just did this here is the solution for you:
MoniServ, Inc.
http://www.moniserv.com
Tools:
Philips screw driver
Small Flat screwdriver
that’s all!
Preparation:
Make sure your desk is clean and you also need a piece of soft clothes because you need
to place your LCD Monitor face down.
How to open the back cover:
First, remove all screws on the back cover, then, use a small flat head screw driver to
push down
the plastic Clip inside the LCD Monitor star at the bottom of monitor. Then you can easily
separate the front bezel and back cover like the photos shown below.
Backlight Inverter Installation Procedures for Dell W1700
Place the Monitor
Face Down
Push This Plastic Button
Down and Remove
Swivel Base as shown
on Next Photo
Remove these
screws
Star at the bottom of monitor as
shown on photo.
Use a small flat head screw drive
to push down the plastic clip.
Do it one side at the time as
shown on next 2 photos
When you have unlocked all 4 sides of plastic clips, Place the monitor face down again
as shown on photo
Slowly tilt
upward from
left side of
back cover
Disconnect this cable and
remove back cover
Remove two
screws and Pull
out this small
circuit board
Disconnect Speaker
cable and remove
the tapes
Disconnect
Backlight cables.
Remove these screws
on the both side of
Panel
Caution!!!
Slowly tilt upward the chassis and disconnect the flat cable
between Chassis and Panel As shown on next 2 photos.
Holding the chassis upward and
Use small flat head screw drive
to unlock this plastic clip
Slowly pull it out
Remove defective inverter board and replace with our New Substitute Board
(T501045.00MSS) and re-install all disassembly components back. Now your LCD
Monitor working again.
MoniServ Substitute Board is available at
http://www.lcdpart.com/Products/t50104500mss.html
Backlight Inverter board.
Photo Shown with our Substitute Board
Remove 4
screws and
disconnect
this cable
Nov 29, 2008 | Dell W1700 17 in. HD-Ready LCD Television
Vivitar MAGNACAM Binocular Logo
235 people viewed this question
Top Vivitar Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Are you a Vivitar Optic Expert? Answer questions, earn points and help others
