Question about Plumbing
Floor Jack will not raise
Hey Chris, I have been reading your post and it sounds like you know what you are talking about. I too have a floor jack that will not pick up one wheel of my truck, but it will go up with no load. I filled it with hydraulic oil, but as far as bleeding, I am not familiar as to how to do this if that is the problem. This jack is only a couple years old at best. I just bought it from a guy hoping I could fix it. The model number is 480578. Is this something I could rebuild myself and where would I get the parts. I thank You very much in advance and hope you and your family have a safe and warm new year. My email is douglascsower@yahoo.com and I would appreciate any info you could offer,
Doug
  • 15,935 Answers
If the jack goes up without load, there are 1 or 2 problems.
The piston seal has become damaged
Relief valve has debris preventing it from closing.
Both items are serviceable by stripping it down.
Take notes on dis-assembly if you are not experienced in hydraulic repair.
More than likely, the piston has a cup type seal. Inspect the inner o-ring by running it through 2 pinched fingers to locate a tear, split or other damage. it should feel smooth.
Parts can be matched at a local hydraulic parts shop. ie Vickers Parker, Rexroth.
If the relief poppet is not seating, it can allow fluid to bypass the check, and you will not build up enough pressure too.
In any case, a total rebuild should be done, as it may be a combination of problems.
Strip it down as far as you can, and clean everything with a good electrical degreaser and air.
Use vaccuum grease to lubricate the seals and o-reings on re-assembly.
If you need additional help, please repost!
Thanks for using FixYa - a FixYa rating is appreciated.
Posted on Jan 29, 2009
How do I change my sub frame on a 2002 hyundai Santa fe
You're talking about the engine cradle? Install an engine/transmission support. Raise the vehicle and put it on jack stands. Locate a floor jack under the sub frame. Disconnect the engine mount and transmission mount bolts. Then lower the sub frame.
Jun 26, 2017 | Hyundai Cars & Trucks
How to you replace the transmission mount?
Center the floor jack's armature under the transmission pan of the transmission.Use a ratchet and open-end wrenches to loosen the transmission mount bolts. Raise the floor jack until the bolts of the rubber, shock-absorbing mounts can be removed with the mounts. Use the floor jack to lift the transmission high enough off the cross member to insert the new rubber mounts. Insert a transmission mount bolt from the bottom and lower the floor jack until the transmission is seated on top of the rubber shock absorber of the mount. Repeat the process for the other transmission bolt.Here you can find more quality auto parts http://www.carpartswarehouse.com/otherautoparts.html
Aug 17, 2011 | Oldsmobile Cutlass Ciera Cars & Trucks
I want to know how many engine mounts a 1997 sl2 saturn uses and if there is a diagram where I can see their locations in the car. Tanks
4 total. Two on the passenger side (upper and lower) and two on the driver's side, upper and lower. The "dog bone" type strut mount is the same for either side.
Jul 04, 2011 | Saturn SL2 Cars & Trucks
My mechanic tells me my motor mounts need replacing.there are two on top and one underneath. how can i do this by myself
YOU NEED TO SUPPORT THE ENGINE TO REMOVE ENGINE MOUNTS. I USED A LARGE FLOOR JACK WITH A PIECE OF WOOD ON JACK SADDLE.WITH WOOD ON SADDLE PLACE JACK UNDER ENGINE OIL PAN SLIGHTLY RAISE ENGINE WITH FLOOR JACK JUST ENOUGH TO TAKE WEIGHT OFF THE ENGINE MOUNTS THEN REMOVE ENGINE MOUNT.
Jun 27, 2011 | Buick Regal Cars & Trucks
I dont know how to change the drivers side transmission mount on my 99 alero what would be the best way
YOU NEED TO SUPPORT ENGINE TO REMOVE TRANSAXLE BRACE.YOU CAN USE FLOOR JACK WITH A PIECE OF WOOD ON JACK SADDLE.YOU NEED TO REMOVE WHEEL OR TIRE SPLASH SHIELD TO REMOVE THE TRANSAXLE BRACE PLACE FLOOR JACK WITH A PIECE OF WOOD IN JACK SADDLE PLACE JACK UNDER THE ENGINE OIL PAN.SLIGHTLY RAISE JACK A LITTLE JUST ENOUGH TAKE PRESSURE OFF THE TRANSAXLE TO REMOVE TRANSAXLE BRACE.DONT RAISE FLOOR JACK UP TOO MUCH UNDER THE ENGINE OIL PAN BECAUSE YOU COULD DAMAGE OIL PAN AND OIL PUMP.
Jun 25, 2011 | 1999 Oldsmobile Alero
Replace serpentine belt
TO REPLACE DRIVE BELT FOR THE 2.0L AND 2.2L ENGINES ROTATE TENSIONER CLOCKWISE USING A WRENCH OR SOCKET USE 19M WRENCH FOR 2.0L ENGINE. USE SIZE 15M WRENCH ON THE 2.2L ENGINE. AND THE 3.1 ENGINE USE A 1/2 INCH BREAKER BAR. IF DRIVE BELT HARD TO GET TO YOU HAVE TO SUPPORT ENGINE WEIGHT USE A HOIST OR FLOOR JACK UNDER THE OIL PAN WITH PIECE WOOD ON JACK SADDLE.SLIGHTLY RAISE FLOOR JACK A LITTLE TO SUPPORT ENGINE TO REMOVE TOP ENGINE MOUNT TO REMOVE DRIVE BELT.DONT DONT OVER JACK ENGINE DAMAGE OIL PAN AND OIL PUMP.JUST RAISE FLOOR JACK SLIGHTLY JUST ENOUGH TO HOLD ENGINE WHEN YOU REMOVE TOP ENGINE MOUNT.
Jan 12, 2011 | 1992 Chevrolet Cavalier
I need to replace broken lugnuts
How to Replace Wheel Lug Nuts
(DIY Complexity: Easy / Time: 1.5 hours)
Parts:
1. Lug Nut
Tools:
1. Floor Jack
2. Jack Stand Set
3. Ball Peen Hammer
4. Tire Iron
5. Socket Set
Steps:
Step 1 Secure the vehicle on a solid level surface to ensure that it does not roll or lean when raised.
o Tip: Safety Tip:Always wear safety glasses when working on your vehicle. Wear other personal protective equipment (PPE) when necessary, for example latex gloves or safety shoes.
Step 2 Break the lug nuts loose but do not remove. Using a floor jack, raise up the front of the vehicle.
o Tip: Using an aftermarket floor jack, instead of the original equipment (OE) jack, can make the job easier and safer. Verify the condition of the floor jack before use.
Step 3 Secure the vehicle with jack stands on both sides for safety before starting any work. Do not rely on the jack to hold the vehicle up while working.
o Tip: The pinch welds or the frame rails are the two best locations for vehicle support.
Step 4 Remove the lugs nuts. Inspect the threads on the wheel studs.
Step 5 Install the new lug nuts by hand making sure they thread properly.
Step 6 Tighten each lug nut in a star pattern. Lower the vehicle to the ground and torque the lug nuts to the manufacturer’s specifications.
o Tip: Refer to the owner's manual for the exact location on the vehicle.
Step 7 Road test the vehicle to verify lug nut repair.
I really hope help with this (remember comment and rated this post).
May 15, 2010 | 1993 Honda Accord
I have disconnected the starter, but cannot get it down past the differential.
raise the engine alittle with a floor jack. be careful and raise it slow.place floor jack on solid part of the engine or transmission. place a piece of wood between engine or tran to raise it.
Jul 26, 2009 | 1995 Ford Explorer
Floor jack needs sevice or seal replacement
you can do it two ways remove and match up the seals with a local distrubuter or try to find your make and model and order them.check your oil level also and the valve for dropping.
Apr 02, 2009 | Plumbing
Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
Plumbing Logo
1,548 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
