Question about Kodak EasyShare Z1015 IS Digital Camera
Can't charge the battery in kodak z1015 and no other batteries work
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, It would be almost impossible to have several batteries that were all bad !!! sounds like a serious problem with the camera and not the batteries.
Regards, Russell
Posted on Jan 24, 2013
  • 370 Answers
SOURCE: Kodak Z1015
Please change the memory Card and Check .....
Posted on Oct 14, 2008
SOURCE: how can i tell if i need to charge my battery for kodak m1063
a lil battery sym ol will start flashing in the lower right corner
Posted on Jul 03, 2009
leepania
  • 1099 Answers
SOURCE: My Kodak digital camera's shutter is stuck on open
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera.
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Without the memory card,turn on your camera.
4. Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Dec 03, 2009
Testimonial: "I didn't expect an answer so quick! I will try all your suggestions. Thank you so much!"
leepania
  • 1099 Answers
SOURCE: My Kodak m863 won't turn on. I've gotten a new
There is no firmware available online for this camera model. Therefor you do need to set up a "repair" with KODAK directly.
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
Posted on Jan 07, 2010
SOURCE: kodak easyshare md41 will not charge battery while
Can the kodak md41 be charged by a laptop through a USB cable?
Posted on Apr 19, 2010
Kodak easyshare won't work unless plugged into charger
Hello Pam, You have either a faulty contact for the battery or your battery is suffering from age. After time these camera batteries lose their capacity. Try a new fully charged battery.
Best Regards, Russell
Jan 11, 2013 | Kodak EASYSHARE M340 Digital Camera
Z1015 won't charge battery internally. this battery was working
Hello, Is the battery in the camera or in the charger ?? Don't quite understand the question. You wrote "received correct wall charger AC/DC ?" was that a question concerning the new charger ? it sounds like your not quite sure about the charger.
Dec 31, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Cant charge batteries for camera
If you are talking about more than one battery, it is the charger. If just one, check using a couple of piece of wire and a torch bulb to see if the charger works by connecting them to the terminals. This is a bit gash, it would be best if you know someone with an electrical tester
May 21, 2012 | Kodak EasyShare Z1015 IS Digital Camera
Memory card not recognized, lense won't retract, menu doesn't work
I put in sd card and it says processing and does nothing wont even go off you have to open the battery place but it will take pic with no sd card in it on the internal memory
Jul 17, 2011 | Kodak EasyShare Z1015 IS Digital Camera
I put away my Kodak z1015 camera with a battery in it. Didn't use it for months. Now I cannot remove the battery. I know how to do it, it just won't come out. I don't have the wire to...
I've just had a look at the instructions, you can download from here if you need them:-
www.kodak.com/global/plugins/.../manuals/.../Z1015_exUG_GLB_en.pdf
According to the set up page, there's a small lug which keeps the battery in place, can this be pressed back with your thumb nail and if so does it release the battery?
Can you get the battery to rock back and forth?
If not, then something has gooed it into place, I can only suggest either tweezers, thin nosed pliers or even, a narrow / flat bladed knife to just slide down the side of the battery (not too far) an just try to prise it loose.
Jun 25, 2011 | Cameras
Flash was not working
try resetting the camera, either through the menu, or by taking the batteries out for 5-10 minutes. if it persist then replace the battery.if the flash does not work after replacement connect your camera to a computer using a usb cable ,go to kodak site for a firmware upgrade for your camera model,this is expected to improve the performance of the camera flash .hope this helps
Jan 12, 2010 | Kodak EasyShare Z1015 IS Digital Camera
It wont turn on ,it is charged , went on yesterday ?????
The problem you describe is frequently due to corrosion on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe the ends of the batteries and replace them in the camera. This clears up the problem about 90% of the time -- I hope it works for you.
Sep 09, 2009 | Kodak EasyShare Z1015 IS Digital Camera
Kodak Z1015
Oct 14, 2008 | Kodak EasyShare Z1015 IS Digital Camera
Kodak EasyShare Z1015 IS Digital Camera Logo
57 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
