Panasonic ct-27g23w partial vertical collapse (top and bottom).Already changed ic LA7838 and resoldered joints,problem still persists
4 Suggested Answers
  • 236 Answers
SOURCE: Buzzing sound, no picture on my Panasonic TV
You might have a short causing the set not to start. Probably in the horizontal/high voltage circuit. The buzzing sound that you're hearing is the power supply overloaded. Stargazer
Posted on Apr 23, 2007
  • 556 Answers
SOURCE: tv daigram
http://www.datasheetcatalog.com/datasheets_pdf/L/A/7/8/LA7838.shtml
Posted on Oct 17, 2007
  • 556 Answers
SOURCE: PANASONIC TV
hope this will help
good luck.l
Partial vertical collapse, picture and buzzing sound
Check the solder joints on the vertical IC. If you reflow the joints and the problem persists replace the IC. Buzzing sound may be the flyback or something dealing with high voltage. Take the back of the TV off and see where the sound is coming from and see if you can see anything when you turn the TV on. Stay away from the TV and don't touch anything when turning it on.
Dec 28, 2012 | Panasonic CT-27G23 27" TV
1999 Panasonic CT-3269SW No picture; just a colorful horizontal line through the center of the screen... tilting & tapping used to pop the picture back. No longer responds to this method; just stuck...
Sir the problem of your unit is the thermal intermittent caused by cold solder or dry joints in the solder part of your unit specially the vertical section of your tv.
It is much better if you use a magnifying glass to determine the cold solder joint or dry joints. To fix this just resolder this cold solder using a soldering iron, soldering lead, desoldering pump, Note be sure not to connect separated pin if accidentally connected may caused much damage to the unit hope this help good day and best regards.
Sep 23, 2011 | Televison & Video
Tv on appears black screen with a bright horizonal line in the middle sometimes with voice
You will have to resolder the vertical IC and in most cases replace any capacitor that is near and next to the vertical IC. There may be three capacitors that will be replaced, And while you are in the process of reworking the board inspect for any and all grounds that may need resoldered. You will have to look very close to find these. And you should search the deflection side of the board for two capacitors that have a 160 volt to 250 volts at 1MF, or 2.2 mf or 4.7Mf. By now these little guys are weak and need replaced. Thanks for asking and show a few hands of support!
Jan 27, 2011 | Panasonic CT-32G23 32" TV
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
JVC 31" TV Vertical Screen Jumping
I've heard this is could be a cold solder joint and am looking for advice on which IC to re-solder. 1 whatever you have heard is correct as whenever you smacked the lelt side it works fine. 2 you will have to check loose contact in vertical section. your vertical ic might be located at the left side of the tv. 3 check any connector is loose near vertival section. 4 any preset is loose in vertical section. it is a simple problem if you are not technical person please get it done by tech person. as your tv is old & if it is done by tech person tell him to replace all elrctrolytic capacitors in vertical section. good luck.
Sep 20, 2007 | Televison & Video
Panasonic CT-27624CA TV chassis AP 335
you have problems with Ic vertical la7848 you need resoldering or change
Sep 10, 2007 | Panasonic CT-27SL15 27" TV
Lose vidio
The solder joints on the vertical output IC have come loose. This is very common on those sets. If you do not have any experience resoldering small parts on PC boards, have the IC resoldered by a qualified tech.
Aug 27, 2007 | Panasonic CT-27G13 TV
Panasonic CT-32D11 TV
Your vertical output IC has stopped working. This is usually caused by the solder joints cracking loose and the IC will either short out inside or just stop working. Sometimes a small capacitor next to the IC, called the pump-up cap, will go bad and cause the IC to fail. In any case, the vertical output IC should be resoldered or replaced and all circuits checked by someone experienced in repairing TV's.
Aug 05, 2007 | Panasonic CT-32D11 32" TV
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
