Question about M-Audio MIDI Controller Keyboard
M-Audio KeyRig 49 driver/update for 10.6.8
Doesn't respond anymore, but before it worked perfectly. the lights go on on the keyboard, but garageband doesn't recognize the MIDI
SOURCE: Oxygen 8 Recognized but not working in OSX
i read somewhere, and it worked for me, at least in logic, that when i plugged it into a usb powered hub, it showed up in the audio/midi setup as a keystation and logic accepted its input..... when i had it plugged into the cpu direct (w/o hub) it was useless.... hope this helps....
Posted on Sep 04, 2009
  • 8404 Answers
SOURCE: My USB m-audio keyrig49 stopped working
Check your computer setting - You should check play options or similar. You dont ID the computer nor operating system so it is hard to be more specific.
On my Midi Device with USB connection, I have a choice of Microsoft routine or other routine. When set to Microsoft setting, my midi keyboard works.
I hope this helps you
thanks for your interest in FixYa.com
Please vote
thanks
a
Posted on Dec 04, 2009
SOURCE: Keyrig 49 not recognized by windows 7
Thats why it won't work NO driver Windows 7. The ONLY shot you got, is to install Mode, & set Compatibility Mode for XP SP2 Run as Administrator
Posted on Jan 31, 2010
  • 71 Answers
SOURCE: Will keyrig 49 software work
Yes. Below is a walkthrough on how to do it:
http://forums.m-audio.com/showthread.php?16230-How-to-KeyRig-49-in-Windows-7
Posted on Jan 31, 2011
  • 16 Answers
SOURCE: hi ther i have lost
Go to this link and download the drivers
http://www.m-audio.com/products/en_us/Oxygen49.html
Posted on Mar 13, 2011
Axiom 49 not detected by reason 5
Open preferences. Go to Control Surface tab.
Click Add. Select M-Audio as manufacturer.
Choose Axiom 49
Make sure the ports are set right.
Controls IN Port = Axiom 49 Hypercontrol In
Keyboard Port = Axiom 49 USB A In
Controls OUT Port = Axiom 49 Hypercontrol Out
if it hasn't detected yet then restart Reason.
Make sure the power on the Axiom is on.
If you still have issues the USB port on the Axiom could be bad.
Oct 01, 2017 | M-Audio Axiom 49 49-Key Semi-Weighted USB...
M-audio key rig keys dont work but computer still recognizes it
You will most likely find a setting in the manual.
READ ALL EQUIPMENT MANUALS! You guys never give enough detail, like how old is the unit. What happened just prior to the problem.
These are all standard questions that will always be asked by any Technician or Engineer.
Sep 02, 2012 | M-Audio KeyRig 49
Keyboard problem & it doesn't work prefect
If the keyboard has a round purple connector, power down the computer then unplug and then plug in the keyboard. Power on the computer. If it works your done if it doesn't replace the keyboard. If this is a USB keyboard, with the computer on, unplug and plug in the keyboard if it works great, if it still isn't working replace the keyboard. NOTE if this is a multi functional keyboard (special keys at the top) make sure you install the driver and any software associated with the keyboard.
Jun 11, 2012 | Computers & Internet
Hi My Fn key doesn't work anymore. Any help please ? Thank you.
Welcome to fixya.Try to update the driver for your keyboard,if that doesnt work try to unistall and reinstall the driver on device manager.
Hope this works.:)
Sep 11, 2011 | ASUS 90-A4C1K1000 Keyboard
Cleaned my keyboard and now the usb ports function but the keys have no response . Is this repairable or do I need to purchase a new keyboard ?
Was the keyboard working before you cleaned it? Did you removed the keyboard connector, might just be loose connection. Check the connection again and see if it works. Keyboards faults normally starts with one or few keys not responding properly, and if the entire keyboard doesn't seem to respond then it's most likely faulty.
If this doesn't fix then you need to buy yourself a new keyboard.
hope this helps.
May 03, 2011 | Computers & Internet
Hi ther i have lost my keys for usb m-audio keyrig 49 and the software. can u help...thanks.......
Mar 12, 2011 | M-Audio Mobile USB MIDI Controller
Now I get an anoying delay: every time I press a key it doesn't inmediately play the sound. and i get a buzz sound when i press a key too. my pc is windows 7 inspiron 1545
If this is used to generate sounds using your computer, the problem is most certainly in your computer software. Common causes are antivirus and blockers that insist upon processing every bit of data including that from devices like this. The delay to do so is unacceptable as these anti things use mass amount of computer resources. Also if you have a wireless internet link active, that sucks processing time... Turn all of these computer resource "hogs" off and see if the problem goes away...
Nov 28, 2010 | M-Audio KeyRig 49 49-Note USB Keyboard
Keyrig 49 not recognized by windows 7, and it is supposed to be plug and play, no drivers found on M-Audio's site.
Jan 31, 2010 | M-Audio MIDI Controller Keyboard
M-Audio MIDI Controller Keyboard Logo
266 people viewed this question
Top M-Audio Computers & Internet Experts
Gareth Cockram
Gareth Cockram
mukhtar21 shaikh
mukhtar21 shaikh
Jim Goldsmith
Jim Goldsmith
Are you a M-Audio Computer and Internet Expert? Answer questions, earn points and help others
