Question about Samsung At&t Sgh-a847 Rugby 2 Rugged 3g Camera Gsm Used Cell Phone No Contract
My samsung rugby 2 wont charge how do i fix this?
I love this phone it works just fine but my charger won't work when its plugged into an outlet or my computer please help! Thanks! :D
SOURCE: my samsung blackjack 2 will
If the Red Led stays turned on it is as simple as this.....the solder connecting your power on button to the system board in your phone has worn off..... you must pop the power button at the top of your phone off and you will be able to see where the soldering paste has simply worn off. At my job I have a soldering machine so it was not problem for me. I simply took pasted it back to the board with tin.....now this may require some work. just pop off the top section of you phone with a flathead screw driver and pop out the power button. look closely and you should be able to see where the botton has lifted from the little greenish system board..... Find someone to solder it, put it back together and it works like new.........SEE YA
Posted on Nov 18, 2008
GrinningFool
  • 625 Answers
SOURCE: Samsung charging problem
If very well could be the charging port. Have you tried a different charger?
If it is the charger port, You have 3 options.
1. get it repaired, warrant if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay2.gif.
For more information and links to the parts check the following link below.
Samsung SGH-D900 charging problem repair
Posted on Aug 18, 2009
  • 29 Answers
SOURCE: samsung SGH E840 won't charge with charger
I just have the same issue and unfortunately I can see the phone's plug it's messed up. I can see a pin inside came of the connector and it's pushed all the way in the back. Used original Samsung charger only!!<!-- from fixya rte -->
Posted on Aug 15, 2010
  • 15 Answers
SOURCE: My SCH-a930 won't charge.
Try using rubbing alcohol to clean the battery or where the charger goes in the phone. If you have a car charger then try using it. If that works and the wall charger still don't then it is probably the charger and needs to be replaced. The phone may have a short in it for where the charger goes. Or it could be the battery. But if the battery is charged or still holding charge it more than likely is the charger itself or a short in the phone.
Posted on Jun 28, 2011
gregloechel
  • 283 Answers
SOURCE: my samsung sgh i717 won't connect to my computer
Not shore but i think Samsung changed something. Try putting the Kies app on the phone that may work better. Cheer..
Posted on Mar 29, 2013
Wont charge
Battery could be bad. They do wear out.
Jul 12, 2017 | Samsung Tablets & eReaders
Tip
How do you fix your phone if it wont charge? ...
All you need to do is shut down your device, remove the battery if possible and use something small, such as a toothpick, to 'lever up' the little tab inside the USB port on your smartphone or tablet. Do so very carefully and gently, then reinsert your battery and plug it in again.
or this.
  1. Turn the phone off.
  2. Remove the battery.
  3. Wait 10 seconds.
  4. Plug in the charger.
  5. Insert the battery.
  6. Turn on the phone.
How to fix phone that won charge properly AndroidPIT
SOLVED Why won my Samsung Galaxy II charge Samsung Galaxy II
How to fix phone that wont charge
How to fix Samsung Galaxy S6 that not charging Troubleshooting Guide
Why is my Samsung charger not working Google Search
on Dec 12, 2017 | Samsung Cell Phones
Not powering on
I'll assume that you've had the phone for a while, and that this isn't something that happened out of the box. One of two things are the most likely. First, your charger didn't charge the phone, allowing the battery to go stone cold dead. If you know someone with a Samsung charger, try charging the Rugby II overnight, and see if it works after that. If it does, you will need to replace your charger. The second likelihood is that the battery has gone bad, or is just old. The only fix for that is to replace the battery. A less likely third option is that the phone was damaged somehow. Try the first two, and then check with your phone vendor. Hope this helps!
Nov 05, 2013 | Samsung SGH Cell Phones
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Htc droid incredible 2 won't charge
FOr changing the charging port you have to take it to an authorized service center. it could be a software issue also.
Dec 08, 2017 | HTC Droid Incredible 2
Once i plug in my charger its wont charge!
Turn it off, & keep it off for a while. It's happened to me as well. Turn it back on & plug the charger in.
Dec 16, 2011 | Sanyo SCP-2700 Cell Phone
My SCH-a930 won't charge. I still have battery life, and the phone works fine, but the phone won't charge. I have tried multiple wall outlets. Does anyone know how to fix this? Thanks!
Please, try using another charger with the phone.
If the problem continues, get a screw driver, unscrew the phone and bring the charging port out. The charging port is at the tail end of the phone.
Clean the surface of the panel where the charging port contact the panel with a spirit and allow it to dry for 30 minute. Couple back the phone and i am sure the charging phone will work fine.
Regards
Jun 28, 2011 | Samsung SCH-a930 Cellular Phone
My samsung gt 15500 won't charge up. It was working fine 2 days ago and yesterday i brought the usb lead to work with me to charge it with my computer. Nothing happened when i plugged it in so i...
If the phone was totally dead before it refused to charge initially, then the refusal to charge is due to the fact that there was no residual charge left to bring it to a charge, because the battery completely died.
To fix it, kick start the charging process.
Remove the battery, and using a universal charger (desktop charger) charge the battery for say 10 minutes, before re- inserting the battery to the phone and continuing with the normal charging process.
If this does not work out, then problem is with the charging port. It has to be replaced. This can be done by nearby local phone repairers.
Hope it helps?
Success.
May 12, 2011 | Cell Phones
My samsung rant wont charge. it charged yesterday but today after plugging it into the charger the Samsung name lights up and then it says "low battery please charge" but it wont charge, i did drop it in...
Phone not charging.
Hello, when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Aug 10, 2010 | Cell Phones
Samsung At&t Sgh-a847 Rugby 2 Rugged 3g Camera Gsm Used Cell Phone No Contract Logo
320 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
