Question about Whirlpool AWM6120 Front Load Washer
Whirlpool awm8121 - spin cycle high pitch sound/scretch
Hello, we have a whirlpool awm8121, its great, except for a super high pitch lound noise its had since we purchased it new. seems that it starts off as it winds up to its final spin and as it hits the breaking the speed of light it also gathers up noise and pitch. similar sound liek jet engine at airport. I assume it has something to do with the spin cycle (duh) but wondered if this was a common sound and do most people just ignore it - or if there is something that can be done to dull the noise. thanks, Mike
  • 5,911 Answers
Front loaders are great for savings on water and electricity. Most of these machines only use about 5 to 7 gallons (US) of water and spin with a velocity anywhere between 1300 to 1800 rpms. This also saves on dry times because your clothes are virtually spun dry. Why am I telling you all this? People buy them with good intentions, but the common complaint I hear is that they are noisy. It is this spin velocity that contributes to that noise. You need to make sure that the foundation under the washer is stable. If your washer is located in a mobile home, upstairs laundry room, home with a crawl space, etc., sometimes these floors have a tendency to flex as the washer spins. If the floor flexes (even a little) the washer will vibrate and make noise. An easy fix to help redistribute to weight of the washer is to place a sheet of thick (at least 3/4" in the US) plywood under the washer to help reinforce the floor. This must be screwed down or affixed in such a way that it does not move. This will take care of any vibrating issues. Now, if your problem is strictly with noise from the machine, some of that is normal I'm afraid to say. However, if it sounds REALLY loud (like a rumble) this is a symptom of a rear bearing that is going bad. If that is the case, the entire back shell of the wash tub has to be replaced in order to replace the bearing as they are molded into the plastic. This can be an expensive repair job if you decide to pursue this option. Let me know if any of this helps. Kinda hard for me to diagnose without being there to hear it.
Posted on Jun 24, 2007
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
No spin cycle
have you tried unblocking the inlet and outlet pipes under the drum
Apr 25, 2009 | Whirlpool AWM6120 Front Load Washer
High pitched screeching noise when in spin cycle
Sounds like the belt is worn and might need to be replaced. Let me know if I can do anything else. thankyou for asking.
Mar 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
AWM8121 Drain/Spin cycle stops
it seems to point to blockage in drainage pipe from drum likely to be a lost sock remove pipe and check
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
High Pitch sound during spin cycle
sometimes the high pitch will come from rear bearing open door pull up on basket see how far it moves up down also ck the pump for thngs in it
Feb 24, 2008 | GE WPXH214A Front Load Washer
Whining noise, only in rinse and spin cycle, sounds awful.
Check the pump to make sure there isn't something stuck in it.
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool AWM6120 Front Load Washer Logo
420 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
