Question about Braun Health & Beauty
Fix trimmer on braun series 3 shaver - Braun Health & Beauty
  • 3 Answers
SOURCE: braun 7526 shaver switch
Managed to fix it - actually was a 7680. Only do this if you:
1. have a small screwdriver set
2. are handy putting little delicate plastic pieces and springs together again
3. are prepared to face the possibility that you might break the shaver entirely
4. you are out of warranty so you don't care if you invalidate it
THE PROBLEM is caused by a small flat metal assembly that acts as a spring to hold the blue button in place. That is held by 4 small glue posts. The glue breaks down, the flat spring falls out of place and the blue button is no long in the right place.
TO OPEN UP THE SHAVER
a. gently remove the plastic cover around the electrical socket underneath, using a small flathead screwdriver to pry it open
b. the two metallic sides of the shaver can be pulled away starting at the bottom of the shaver
c. uncrew the four screws on the underside of the shaver
d. remove cutter block, battery/lcd block (make sure you don't lose the grommet around the lcd display
e. pull the spring and little plastic latch off the underside of the switch, make sure you remember how to put it back (took me almost 20 mins to figure out how to get that back afterwards)
f. slide the switch all the way up and pull it off the slide - you might need a little gentle force and a flathead screwdriver to coax it off - be careful you don't break anything here
g. remove the trimmer from the rest of the switch
h. put the blue piece back in place (mine had fallen out), then glue the flat metal spring back in place. I smeared brush-on crazy glue on the flat surfaces to hold it in place, I would imagine a four drops of reasonably strong glue on each of the glue posts would work best. Wait for the glue to dry and achieve strength.
i. slide the trimmer back into place, then the plastic latch and spring - this is the tricky part. Make sure the switch can slide on/off in all positions properly.
j. put the display/battery & cutter block back in place. put the back of the shaver on, hold the shaver together with your fingers and test the switch works in all positions without jamming. If so put the four screws back, followed by the metallic sides followed by the plastic cover of the electrical socket.
GOOD LUCK!!
Posted on Jan 28, 2008
  • 31 Answers
SOURCE: Voltage: own a 220 volt Series 3 330 shaver , now in Canada 110 v
You can try dryer power port, it's 220V, and you have to buy a adapter to replace the port on the wall accord with your Braun, or to buy a transformer (110 - 220).
Posted on Mar 10, 2009
SOURCE: Braun Pulsonic Razor - Pop up trimmer will not retract entirely
I ran into this problem several months ago. I just shook it and forced it until it retracted and never thought anything of it. The trimmer recently broke (still functioned but extended beyond its normal point) and I took it apart. I realized that there were a few broken parts inside (possibly because of my earlier experience). So I removed the few parts and now it still extends to far, but otherwise functions ok if I'm careful.
I would recommend taking yours apart and seeing if you can find any parts floating around which may be causing it to not retract all the way. It may be broken beyond complete repair, but you may be able to get a little more use out of it.
If nothing else, you can order a new casing for it from here
Here are the instructions for taking it apart:
The shaver itself is easy to take apart. The part on the bottom(opposite from the shaver mechanism) pops off with just a slight bit ofprying. Be careful not to break the pins though. Once you have thatoff, the narrow sides pop off pretty easily. Then you can remove the 4screws opening up the interior.
Be careful at this pointbecause there are a lot of parts that may fall out. (Perhaps take apicture as soon as you open it so you know where everything was whenyou opened it). At this point you can try your hand at fixing it (minehad 3 parts broken and loose inside), or you can simply switch it withthe new casing (Which i'm going to do when I get it). Good Luck!
Posted on Mar 31, 2009
Cytherian
  • 124 Answers
SOURCE: Braun cleaner for shaver
Here's a link to download the manual. Good luck!
http://www.manualnguide.com/manual-get/3308/
Posted on Oct 22, 2009
brector3
  • 1623 Answers
SOURCE: Trimmer on Braun Pulsonic shaver won't stay shut?
The trimmer is broken. This is a common problem with this model and only an authorized Braun repair center can help you with this. There is one in Evanston, IL that can accept shavers from all over the US. Their phone number is 847-869-7755
Posted on Aug 21, 2010
Side burn trimmer won't stay closed on 790cc braun razor .
Almost certainly, the trimmer is broken and will need replaced. The part and replacement video instructions can be fount at shaveroutlet.com
Braun Pulsonic and Series 7 Shaver Trimmer Assembly
Jan 22, 2017 | Braun Health & Beauty
How to fix braun series 5 trimmer
Search Results
    Repair your Braun Cruzer 3 Trimmer MacGyver style in 6 ...
    ? 6:36
    https://www.youtube.com/watch?v=ZH1NRbDidRM
    Jul 30, 2012 - Uploaded by Ed el Vise
    My Braun Cruzer 3 Trimmer suddenly stopped working. ... I have replaced screens now on 5 different cell ...
    Braun series 3 razor fix - YouTube
    ? 3:00
    https://www.youtube.com/watch?v=mSdJu_iaEjs
    Oct 16, 2014 - Uploaded by mruberg1
    How to fix the Braun series 3 razor, after the trimmerattachment, falls off, due to sonic weld failures ...
    Braun Series 3 disassembling trymer rozbieranie - YouTube
Jan 18, 2016 | Braun Health & Beauty
How to replace battery braun shaver series 1
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
Nov 16, 2015 | Braun Series 7 9585 Hair Trimmer
Hi, I have a Braun series 3 shaver and sometimes
blades are blunt and the hair gets stuck between the clipper blade and the fixed blade
have them sharpened or replace with new one s
Nov 10, 2017 | Braun 380 Electric Shaver
Can i get a replacement trimmer for braun series 3 390cc 3?
Im looking for the same too. I dont need a new foil or cutter I need a replacement long hair trimmer as mine has snapped off
Apr 30, 2012 | Braun Health & Beauty
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Need braun series 7 blades
The blades come mounted in the screen assembly. You will find this cartridge available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-9000-series-pulsonic-foil-and-cutter-cartridge-p-365.html
Aug 15, 2011 | Braun Series 7 9585 Hair Trimmer
Repair / replace trimmer on braun 9585 shaver
This part is only available from a Braun repair center. You can call a repair center at 847-869-7755
Sep 03, 2010 | Braun Series 7 9585 Hair Trimmer
Braun Pulsonic model 9595. Trimmer will not close properly. Can I repair this myself?
The trimmer is replaceable and can be purchased as an assembly http://buyitnow64.stores.yahoo.net/brshrese7pul.html You will T-6 and T-8 torx drivers to take apart the head end of the shaver. Using these tools, remove the swiveling head, the hold down cover over the motor assembly, and then pop off the drive arm for the trimmer. Now the broken trimmer assembly can be slid out of the end of the shaver by carefully prying between the case where the on/off button is located and the black trimmer assembly base with a small flat blade jeweler's screwdriver. The new trimmer assembly can then be slid into the case and the shaver reassembled. Just be sure the ends of the retraction spring on the new trimmer assembly are installed over the little chrome retaining lugs for them or your trimmer will not fully retract (my trimmer assembly arrived with the spring ends loose and not retained by the lugs).
Mar 29, 2010 | Braun Health & Beauty
Health & Beauty Logo
97 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
