Question about Garden
Oil failure on Ryobi PNC 4545 chainsaw
Regular failure of oil supply on my 4545 chainsaw, Have cleaned out the oil tank with fuel and then refilled wiyh oil, this solved the problem for about 20 minutes and then the problem returned. Anybody know if there's a known problem with this unit or can offer a solution.
  • 1 more comment
  • Ian Fairweather Jan 19, 2009
    Thanks Bill, Your vacuum idea certainly seems to have merit, I'll check that.
    Oil level has always been adequate and cheched on every re fuel, when re filled with oil, (not that it would have gone down much because it isn't using any!) it still doesn't work. I have , after removing all the necessary parts, blown compressed air back through the outlet hole, this worked but again only for a short while.
    I will also check the pick up tube to see if its falling the wrong way, I'll post a response after I check.
    Thanks for your suggestions.
    Ian
  • Anonymous May 09, 2009
    It is nothing to do with vacuume or blocked oilways! we two with the same problem!!!
  • bczerkie May 11, 2010
    If you loosen oil cap / retighten it does it work for another 20 minutes. Possibly forming a vacuum. Actually on the 20 minutes I'm guessing it's normal use, not severe use where you could be out of oil? Is the oil pick-up located on the bottom of the tank? not flipped upward? When it stops oiling, what level is oil at? if you refill it to the top does it work again,( do this at different check time then first one listed) possibly indicating a broken hose which would be in the bend at about half a tank. Age on saw?
    Check these and post. Bill
    Brigadier General:
  • 4,088 Answers
It sounds like you have a contaminated oil source. I'd buy a new bottle, clean the tank again, and see if things improve.
Posted on Jul 09, 2009
Oiler mechanism to bar of ryobi 40cc 10532 18 inch
I get asked this question a lot , im gonna have to make a video on this subject someday .
but here:
1st ck your oil viscosity/SAE it should be 30 and say bar/chain oil
next dump out entire oil tank and wash out with kerosene (you'd be surprised what I seen come out)
then remove bar and chain , locate oil outlet it's in body of saw near adjustment screw , use a small can of air to blow in this port softly , use a touch more of kero to clean this all out , refill tank with proper oil !!!! and run saw (no need to put bar/chain back on yet ) might take several minutes but oil should start to flow out hole !! stop saw and reinstall bar/chain then run again .. fixed !! if no oil comes out ever your oil pump is gonna need some fixing
for a low cost oil I use filtered used motor oil cut down with a dab of kerosene
Jul 07, 2014 | Ryobi Factory Reconditioned 18" 40cc...
Which oil do i use in a ryobi C4620 chainsaw?
Do NOT use lightweight motor oil for that bar! Use only bar/chain oil for it - nearly any brand will do just fine, but it needs to be bar/chain oil. Bar/chain oil is specially formulated to stay on the bar & chain in use - motor oil will fling away & your bar won't get the lubrication it needs.
For fuel mixing, use nearly any brand of 2-cycle oil, which is specially formulated to provide lubrication even when it's mixed into your fuel. Use about 3.2 ounces of 2-cycle oil per every gallon of gasoline - a little more won't hurt (it'll make the saw smoke a little), but never use less. Always shake the gas can just before you refill your saw's tank - shaking helps make sure the oil & gas are well-mixed.
Mar 13, 2013 | Garden
Does it take regular gas, or gas and oil mix? 50 to 1 ?
50:1 mix in the gas tank and bar oil in the oil tank. Fill your oil when you fill the gas. Keep the chain sharp.
Jan 08, 2011 | Ryobi Garden
Bought a Ryobi cs214 at a pawn shop. There is no oil in the holder for smooth running of the machine. Would like to know what kind of oil does the Ryobi CS214 takes.
Just fill the tank with regular bar/chain oil available at home centers, hardware stores, and saw dealers. Don't use old used motor oil or similar. Hope this helps!
Dec 21, 2010 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi chainsaw 4545 automatic chain lubrication not working
That number you provided does not cross to an IPL (exploded parts list) here:
Homelite/Ryobi.com
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches. It is the only illustration I've found that gives any oil line rouling detail.
Oil System Plugged.
A blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). The saw can be operated without the bar and chain to verify oiler operation. Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 27, 2009 | Ryobi Garden
Same problem as olliee69
Bar oil is delivered to the chain threw a port, usually at the top side of the bar. I recommend removing the bar, apply air pressure to the tank that holds the bar oil. It may flush out debris in this port.
Nov 12, 2008 | Garden
Ryobi Chainsaw - PCN 4545
Ryobi boasts a two year warranty. Have you contacted anyone about a warrantied repair?
An IPL (expanded parts list) for your saw with any oil system detail can be found here:
Homelite/Ryobi.com
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Aug 22, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
364 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
