Question about LG LSC26905TT Side by Side Refrigerator
LG LSC26905 hose for the water dispencer
Hose in back of refrigerator leaks water when usin the water dispencer. Where can I get a new hose to fix this problem?
5 Suggested Answers
  • 68 Answers
SOURCE: where is my water filter on lg side by side
It's at the top on the refrigerator side, behind the cover for the light.
Posted on Aug 23, 2009
SOURCE: LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
  1. Remove the ice bin, set it aside (don't forget to deal with the ice melt).
  2. Turn the ice maker off (LG says to unplug the fridge, I didn't).
  3. On the left hand side of the ice tray dumping mechanism there is a screw helping to keep the entire thing suspended from the ceiling of the freezer. Remove that screw- don't worry, the mechanism will stay put for now.
  4. The dumping mechanism can now slide forward- note that you can't completely remove it from the freezer yet, but slide it forward and it will no longer be suspended from the ceiling. Don't let it drop or hang.
  5. You need to disconnect its power supply now. On the left hand side you should see a small bundle of wires coming from the back of the freezer to the dumping mechanism. It connects to the dumping mechanism's set of wires with a pair of white plugs. Pull these plugs apart. You may need to pry the catch on these plugs apart while you pull.
  6. Now you can take the dumping mechanism out of the freezer (and close your freezer).
  7. To remove the ice tray you need to slide the housing that contains the rotating motor out of the housing. This is on the right side of the mechanism. If you have trouble identifying it look at the underside of the entire thing and you'll see a small "test" button. That button is on the motor.
  8. To remove the motor you'll see two catches on the right side- you'll need to pull these catches out without breaking anything. You'll be able to slide the motor down and out when you get it right.
  9. Sliding the motor out lets you get the old ice tray out now. There is probably a set of white wires routed through a little catch on the old ice tray that you'll need to free.
  10. Put the new ice tray back on the motor. You'll need to get the left side secured at the same time you get the motor housing in its catches of the dumping mechanism.
  11. Reroute those white wires back on the new ice tray.
  12. Reconnect the electric wires to the housing.
  13. Slide the entire dumping housing back onto the ceiling of the freezer and screw in on the left side.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
Posted on Aug 28, 2009
jan mczeal
  • 632 Answers
SOURCE: what is the part # for the ice cube motor for lg
Ice maker motor part number 1330390..
Posted on Oct 21, 2009
  • 1891 Answers
SOURCE: How would I replace the water hose on a LG
purchase a 1/4 in line longe enough to do the job . insert in into the water valve and run it to the ice connection . this should correct problem . make sure the connectoins are tight and ck for leaks ..mm
Posted on Jul 22, 2010
I have a LG 26911 TT it does not dispence water but there is water leaking out of the bottom of the freezer door handle
the water comes from the house water through a filter then to the freezer where it is used to make ice and then chilled water goes on to the water dispenser. if you are making ice ok then the little tube that goes to the dispenser is broke or the valve that opens to allow water to fill your glass is broken or plugged up. You will need to disassemble the unit from inside the door... I sudjest taking a lot of pictures as you do the disassembly to aid you in putting it all back together.oh.. perhaps deforsting the fridge first might fix theproblem... if your lucky.
Oct 10, 2014 | LG LRSC26911 Side by Side Refrigerator
Leak in back next to bottom the blue connector
Can you please be more specific and if possible add a picture?
Aug 04, 2013 | LG LSC26905 Side by Side Refrigerator
LG LSC26905 makes ice, but will not dispense through door. Ice backs up on inside of freezer door when attempting to dispense ice (crushed and whole cubes). Water dispenses OK. Any help? Thanks.
Sounds like the flap or door directly above where the cup would be is not opening. Press lever and look up in there, if that is the case there is a problem inside the door.
Sep 17, 2011 | LG LSC26905 Side by Side Refrigerator
Water dispenser and ice wont come out
if it makes ice but will not dispence the look at the electronic p c board as it's prob bad ...
Oct 14, 2010 | LG LSC26905 Side by Side Refrigerator
Lights out and water and ice dispenser not working
You have a bad main board. To replace the board remove the cover on the back to access the board. Be carefull when removing the plugs.
Jan 22, 2010 | LG LSC26905 Side by Side Refrigerator
I changed the water filter and now the water is not working
For LG LSC26905:
If you replaced the water filter cartridge on the dispenser due to a filter replacement indicator appeared on the display, press and hold the lock button more than 3 seconds to reset the filter timer.
Make sure the water supply line is open.
Nov 07, 2009 | LG LSC26905TT Side by Side Refrigerator
Where is my water filter on lg side by side
Aug 11, 2009 | LG LSC26905TT Side by Side Refrigerator
Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Jul 13, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
