Question about Sewing Machines
Kamik champlain zipper broken
So how do I get a zipper replaced or repaired on this boot
  • Sewing Machines Master
  • 1,564 Answers
You may be able to fix it.... if it is just separated work the zipper head all the way down then use a pair of pliers gently squeeze the zipper head, top to bottom. Then run the zipper.
If the zipper is missing teeth or is unsewn ... take it to a shoe repair place and get it fixed or replaced.
Posted on Jan 01, 2013
Testimonial: "Thank you very much. I took it to a shoe repairperson and the zipper cannot be replaced without compromising its waterproofing. So we are bypassing that with a securing velcro strip. Should work fine since I'm after functionality and not looks. Thanks again! Brent"
I need a zipper foot for my Pfaff 1047. Where cn I find one?
Pfaff - Zipper Foot for IDT™ System (1)
www.pfaff.com/en-GB/Accessories/Zipper-Foot-for-IDT-System
The Zipper Foot is the most important zipper tool and will help you stitch the zipper perfectly in place. When attaching any zipper, it is important to sew right next ...
Pfaff - Invisible Zipper Foot
www.pfaff.com/Accessories/Invisible-Zipper-Foot Invisible zippers are the least noticeable of all zippers. As the name implies, the zipper is hidden in a seam, becoming virtually invisible. This makes it a popular ...
Pfaff 1047 Sewing Machine Parts - Sewing Parts Online
www.sewingpartsonline.com > Pfaff Parts Rating: 4.8 - ‎91,711 votes
Results 16 - 30 of 77 - An Online Pfaff Parts Superstore, We also supply 1047 manuals, presser feet and accessories. Fast, free shipping over $75. zipper foot for my Pfaff 1047 Google Search
Feb 27, 2017 | PfaFF Sewing Machines
I need the tags that fit on the zippers on the outside of my luggage. Two were somehow lost or fell off on a recent trip.
Very difficult to replace zipper tabs. Usually, I end up replacing the entire zipper on garments. Another issue for luggage.
Jan 31, 2017 | Sewing Machines
Pfaff Expresions 3.0. Using my zipper foot with 3 teeth. But can not get the needle to position to sew close to zipper
Um, not sure what presser foot you are using--there are several.
If it is the invisible zipper foot, there is a groove in the bottom of the presser foot that straddles one strip of zipper teeth which positions it close to the needle. Zipper foot #4 snaps to either side to enable the needle to be close to the zipper teeth. The Narrow Adjustable Zipper/Straight Stitch and the Non-Stick Zipper Feet are moveable left or right.
Pfaff Presser Feet
Oct 01, 2016 | PfaFF Sewing Machines
How do you replace a complete zipper and what do you need
Bring your garment to the sewing store. Find a replacement zipper like the one on your garment and make sure the replacement zipper is long enough (ask a clerk for assistance).
Then when you get it home, you will need to carefully remove the broken zipper by cutting the thread stitching that holds the zipper in place. Use a thread nipper or seam ripper but be careful to not cut the fabric. When you get the threads cut, you should be able to remove the broken zipper. Line up the replacement zipper in the open seam, pin in place and stitch.
Dec 06, 2015 | Sewing Machines
How do you fix it (Zipper)
Looks like the tab has actually come off the zipper. If so, the tab stop is most likely the culprit and is either damaged or missing. The only way I've found to really repair a zipper is to replace the complete zipper.
Need replaced zipper on handbag since purchased never used now discovered broken zipper
Try a local shoe repair shop or a dry cleaners that does alterations.
May 21, 2014 | Sewing Machines
The zipper on my colin stuart galdorater sandel is broken
Take the sandals to Victoria's Secret and explain the problem. There may be a way to get the damaged sandal repaired
Mar 07, 2013 | Sewing Machines
How to replace Luggage zipper slider
you'll need an industrial post bed machine for that. Or you could take it to the local shoe repair guy and see if he is willing to repair it for you.
Aug 30, 2012 | Sewing Machines
My 8280 modle singer: I sewed a zipper for a shirt, but the needle hit the hard part of the zipper, so the needle broken, when I replaced a new needle, but found that that machine stuck, even I push the...
If you are not able to free this easily, you really should consider taking it to a service technician to look at it in case you do more damage to the needle bar and elsewhere trying to fix it yourself.
Sep 07, 2009 | Singer 8280 Mechanical Sewing Machine
How to use a zipper foot please? I have lost instructions and have no idea which is the zipper foot or how to use it can you help please.
  1. Step 1 To prepare the fabric for a centered zipper application, use the standard presser foot to baste the opening of the fabric shut using 5/8 inch seam allowance. Press the seam allowance open. Place the zipper teeth side down on the seam allowance and pin the zipper to the seam allowance only.
  2. Step 2 Release the standard presser foot from your machine. There may be a button or lever behind the foot that you need to press. Put the standard foot in its holder or someplace where it won’t get lost.
  3. Step 3 Decide which side of the machine you want to attach the zipper foot to. Zipper feet are asymmetrical, with one side that’s wider than the other. You’ll want to put the narrow side toward the zipper teeth, and the wider side away from the zipper teeth.
  4. Step 4 Attach the zipper foot to the sewing machine. You may need to line up the bar on the zipper foot with the presser foot holder, then lower the presser foot by lowering the lever. Raise the presser foot and make sure the zipper foot is securely attached.
  5. Step 5 Place the prepared fabric with the pinned zipper in the sewing machine. Lower the needle into the zipper tape and the seam allowance only, then lower the zipper foot. Stitch the zipper tape to the seam allowance. To sew the other side of the zipper to the seam allowance, remove the zipper foot from the sewing machine and install it on the other side of the presser foot holder.
  6. Step 6 Topstitch the outside of the fabric to each side of the zipper tape, making sure that the zipper foot is on the appropriate side of the machine for each side. Remove the basting with a seam ripper.
Jun 19, 2009 | Janome Harmony 2039 Mechanical Sewing...
Sewing Machines Logo
101 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
