Question about Janome 1017 Mechanical Sewing Machine
My machine keeps jamming
I start sewing but then it just jams.
  • Anonymous May 25, 2009
    It is the same problem
    Problem Solver:
  • 16 Answers
Check to make sure it is threaded through all of the threading points and that it is seated in the tension (Hold the thread from pulling off the spool and pull a little Just before you thread the needle to make sure thread is seated in the tension disc). Check the bobbin and make sure it is seated properly. There is only one way for the bobbin to go in the bobbin casing, check manual. If threaded properly, tighten the tension. It should work fine.
Posted on Aug 11, 2009
Machine is jamming. Top thread broke so re threaded and re did the bobbin,but it is still jamming every time i try to sew
just found this on the internet...
Fabric jamming in your machine may be caused by the feed dogs. The feed dogs are those tiny teeth along the sewing machineunderneath the presser foot as those teeth pull the fabric through when the needle is making stitches.24 Feb 2016
Why Does My Sewing Machine Keep Jamming?•Sewing Made Simple
sewingmadesimple.net/why-does-my-sewing-machine-keep-jamming/..
or go to this link..
sewing machine is jamming Google Search
Oct 27, 2017 | Sewing Machines
Threading the machine
You said it jams when you start to sew. Please clarify. how and where does it jam?
Make sure you threaded the machine with the foot in the UP position. Make sure your bobbin is in the case correctly and is spinning in the correct position when you pull on the thread.
When starting to sew, grasp the top and bottom threads and gently tug, then hold it down to the surface of the machine as you begin the seam.
Jul 14, 2012 | Necchi 3537 Mechanical Sewing Machine
Keeps getting jammed
Give these solutions a try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin as there could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
* When you start to sew a seam, Hold the upper and bobbin thread tails back and out of the way as you sew your first couple of stitches. This will keep them from getting jammed in your machine.
I hope this helps.
Dec 29, 2009 | Sewing Machines
Jammed spool pin on a Brother CE5000 PRW sewing machine
Try a little oil and let it set befor pulling.
Nov 03, 2009 | Yamata FY101-1A
Sewing machine jams
does it jam up on the top or bottom?? if it shows on top it is the bottom thread if it jams on the bottom it is the top thread
Oct 12, 2009 | Husqvarna Viking 1
My sewing machine keeps getting jammed when sewing. the top stitch keeps getting tangled in with the bobbin thread and jamming up the machine.
Here are a couple of things to try.
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
caught in your machine.
I hope this helps.
Sep 11, 2009 | Singer 5160 Mechanical Sewing Machine
Singer 7470 jams and buzzes
To learn how to solve bobbin jam and select the correct needle, I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional step-by-step repair guide written by an expert. Besides Singer sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Dec 22, 2008 | SINGER 7470 Sewing Machine
Bobbin case case keeps jamming
I am having somewhat the same problem with the exception that my needle did not break. I've cleaned and oil, but the bobbin case and projection positioned spring is not communicating to allow sewing to continue. The thread keeps jamming and the bobbin raises up the plate. So, what else am I to do?
Apr 02, 2008 | Singer 2662
Janome 1017 Mechanical Sewing Machine Logo
233 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
