Question about Sewing Machines
How do I thread my elnita 250 sewing machine?
Threading
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
  • 8 Answers
SOURCE: Bobbin thread breaks
Make sure your bobbin thread is turning clockwise as it sits in the bobbin case. There is a screw on the outside of the bobbin case you can turn with your thumb slightly to adjust tension. If you dangle the case from the thread and give it a light ****, it should move down slightly when doing so-an indicator of good bobbin tension.
Posted on May 20, 2008
  • 323 Answers
SOURCE: Threading my sewing machine
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Aug 27, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 980 Answers
SOURCE: Threading a HG Palmer Princess sewing machine
I can help you if you can email a picture with your email address, your machine is not a recognised make drivewithken@blueyonder.co.uk
Posted on Oct 25, 2009
My Elnita 245i is squeaking when it goes forward, but not in reverse. Ive oiled inside the needle mechanism and bobbin case areas. No change. It is also breaking top thread after 6 inches
If your machine is mechanical (not computerized), it could very well benefit from a good cleaning and oiling, including the internal mechanical movement. Squeaking could be the feed dogs but could be a multitude of places.
When threading the machine, be sure to ALWAYS raise the presser foot. The fact that the top thread is breaking about 6 inches into the sewing indicates that the thread is catching somewhere. Sometimes, it catches on the thread notch on the thread spool. Other possibilities is that the thread is looped around something, ie the spool pin, a thread guide... Remove the thread entirely from the machine and rethread from the beginning.
Elna Elnita 244 245 Sewing Machine Threading Diagram
This may help you if you decide to try to oil your mechanical machine:
Wheel on right side that controls the needle up and down is very tight...
Feb 07, 2017 | Sewing Machines
I have an old Elnita 130 sewing machine with no manual. How to I thread it? It appears to work but shows signs that I did not thread it correctly.
elna make elinta machine and a 140 is the same threading as a 130
try entering the sites as most I go to require an account ( free) to procedure to read or down load and that process would be better for you
I went google and typed in--user manual for elinta sewing machine model 130-- and the sites show 130, 140 and more so select a site and go from there
thee is also a www.youtube.com>watch that runs for 1.29 and shows how to thread an old elna sewing machine
you might pick up a clue from that film
Dec 16, 2016 | Elna Sewing Machines
How do I thread a elnita 200 sewing machine?
Perhaps this will help:
Elna Elnita 225 Sewing Machine Threading Diagram
HINT: Be sure to raise the presser foot BEFORE threading the upper thread. It releases the upper tension disk so the thread will seat properly. Do this every time the upper is threaded.
Jan 06, 2016 | Sewing Machines
Thread an Elnita Top 300 Sewing Machine
I am NOT familiar with your machine, BUT..... many machines have a threading diagram decal on the INSIDE of the head cover on the left [needle] end of the upper body!
Jan 09, 2015 | Sewing Machines
Elnita
The top thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
8. Try a different spool or cone of thread
Jul 08, 2013 | Sewing Machines
How do i thread an elnita 200 sewing machine
were do i get a shuttle and bobbin from for my elnita 140 sewing machine
Apr 12, 2013 | Sewing Machines
How do you thread an Elnita 140 sewing machine that is really old but can still work?
It's easy! Start from the thread holder at the top and go left - hook it under the hook which is behind the round disc that the bobbin winds around, then forward down thru the tension, then under the straight metal bit that's below and slightly to the left of the tension, then up into the hook (slide it behind and then slide forward into the hook), then back down and flip it into the small hook (which is just under the 'straight metal bit' mentioned above) and thru the needle! :-) Hope that helps. The machine might be an oldie but it's a goodie! cheers Lynda
Apr 02, 2010 | White Sewing 1888 Mechanical Sewing...
Sewing Machines Logo
223 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
