Question about Ubisoft Just Dance 4 Wii
When i insert just dance 4 disc, i click on start and then is black screen, all the controllers turn off at once
And after that, i CAN NOT play any games! PLEASE HELP!
Connect my microsoft life cam to my computer
Usually all the webcams are plug and play, so you can simply connect the webcam and start using it, else follow the below mentioned steps: 1. Insert the installation disc into the disc drive of the computer. The setup program should automatically run, but if it does not, browse to "My Computer" (click on "Start", then "My Computer"), and double-click on the disc drive.
2. Follow the prompts to install the driver and included software.
3. Insert the USB cable that is connected to the webcam to an open USB port on the computer. The setup program should prompt the user when the webcam should be connected.
4. Follow the prompts to complete installation. Once the Installation is over, open the software and start using it.
Sep 11, 2011 | Computers & Internet
Wired 360 pad isn't working
I had same problem..if u have a dance pad with foam inserts....take out the insert and try to start up without them....the problem we had is one of the inserts was putting pressure on one of the buttons preventing xbox from reading pad...if u don't have inserts one of your buttons is sticking...give it a shake and try again....we fixed ours by simply rearranging the inserts...hope this was helpful
Jun 12, 2009 | Konami Dance Revolution DDR Original Dance...
Won't play dvd' freezes black screen same when i turn games off
you need a firmware update
as your firmware is damaged.
dont worry. this will just take a bit long time but once you start system uppdate it will automatically
download the firmware and update it.
May 11, 2009 | Sony Playstation 3 (PS3) Console
Black screen
you can have problems with your disk if it is pirated
Mar 02, 2009 | Konami Dance Dance Revolution SuperNOVA 2
Gamecube controller
Verify with this
http://reviews.ebay.com/How-to-Use-Gamecube-or-Classic-Controllers-on-Your-Wii_W0QQugidZ10000000004820119
Have you started a gamecube game by inserting the disc ?I'm guessing once the game starts the controller will work.
Feb 25, 2009 | Konami Dance Dance Revolution Hottest...
My new xbox just got it for christmas is freezing
Right, lay your Xbox360 down dont keep it upright, try installing COD4 to your hard drive then once installed go into you game library and click on cod4 and click play from hard drive ( and if you dont know how to install games to the hard drive make sure your xbox isnt on automatic start when a disc is inserted and put the disc in and when it says play cod4 press Y and then click install to hard drive) hope this helped....
Feb 07, 2009 | Microsoft Xbox 360 Console
Games Won't Load
Why don't you just take it to Best Buy or where ever you got it from and then exchange it or you could return it and git your $ back!!!!!!!and rate this Fix Ya please!!!!!
Dec 25, 2007 | Nintendo Wii Console
Panasonic DVD-S47
If you still have a warranty on the Dvd recorder send it in for Repair.It's either a Factory Defect or a sort in the control switch.
Dec 21, 2007 | Samsung DVDR120 DVD Recorder
Disk format
1) Turn on machine
2) Open Tray
3) With tray still open hold the reset until the tray closes.
4) Tap the reset once.
if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
Appears a blue screen and lost all controls
Sounds like a thermal related problem (it's getting too hot). There's not alot you can do since it's likely a design flaw that is at the circuit level.
Sep 21, 2007 | Delphi MV10021 Car DVD Player
Ubisoft Just Dance 4 Wii Logo
80 people viewed this question
Top Ubisoft Video Game Consoles & Games Experts
Mishan Kasiparsad
Kyle
Kyle
Level 1 Expert
Mushtaq Mahomed
Mushtaq Mahomed
Are you an Ubisoft Video Game Console and Game Expert? Answer questions, earn points and help others
