Question about Tunturi Exercise & Fitness
Motor control board for t40 tunturi treadmill
jgwhomeequip
  • 1902 Answers
SOURCE: proform treadmill 580si motor is not working
Recheck your wiring and check your ground. If all that checks out then triple check your control board. Also the motor SHOULD have a reset button make sure that the button is not out and it is fully pushed in
Posted on Feb 19, 2009
maxtreadmill
  • 832 Answers
SOURCE: Motor Controller Board Schematic
If you are the original owner the parts in residential settings is lifetime so call body-solid @ 1-800-556-3113 ext 520
Posted on Mar 02, 2010
maxtreadmill
  • 832 Answers
SOURCE: hi i have a code E7 that show on my upper board in
Pull the connector off the incline motor off then connect (usually red and black thick leads) your multi - meter then select ohm X1 you should get a reading about 1.7 ohms. then check if the motor see if it is stuck. Then wrap a peice of cloth around the incline screw and with a pair of vise grip gently apply enough pressure to see if you can unstick that screw, reset your power and if the error code clears up, if not the VR control in the motor can be defective and you must rplace the motor.
If the reading show open I would suspect the motor is bad then again replace of the motor.
Posted on Apr 09, 2010
maxtreadmill
  • 832 Answers
SOURCE: my tunturi treadmill 661f is showing E1 on the
E1 error code : Unplug unit remove motor shroud and check the distance between the speed sensor and the flywheel and ensure that the speed sensor is properly attached to the motor frame. Check also speed sensor connections.
Unplug the electrical cord from the wall outlet and from the treadmill, wait 1 minute and turn the power switch on again. If treadmill recovers to normal operation, you may continue to use the treadmill.
Check the motor brushes either they worn or not sitting properly
Posted on May 17, 2010
Testimonial: "very helpful thanks saved me lots of money "
  • 33 Answers
SOURCE: I have a Tunturi j770 treadmill with error code E1...
Your problem could be that a magnet has fallen off. Here's an illustrated guide that should make fixing it easy: http://fixmytreadmill.blogspot.com/2010/10/how-to-fix-treadmill-e1-error.html
Good luck.
Posted on Oct 09, 2010
Put a Tunturi t60 control motor board back together
What do you want to know .
Send a pic if u like and I will tell you how .
Darren
May 14, 2015 | Tunturi T60 Folding Treadmill
Treadmill will not start. no power to the control panel. but it does have a steady beeping sound
Check for dust or debris on a sensor. If all clean, possibly broken wire to a sensor.
May 27, 2014 | Tunturi T40 Folding Treadmill
T40 treadmill 5 yrs old , been working okay until few days ago. The treadmill moves a cm. & power circuit trips at the mains. I live in UK. Please help.
please a) see the video and lube the rollers bearing too very IMPORTANT
b)if after you did the problem persis, is time to replace the Old board deck by new ones
c) However test the main motor see my personal TIPS for motor help.see the input voltage for motor, if there ARE the motor need repair
d) test the output board, for input voltage motor, if there ARE not the board is faulty, replace see the block diagram.+w.diagram too
God bless you1_18_2013_4_12_50_pm.gif1_18_2013_4_13_45_pm.gif1_18_2013_4_14_22_pm.jpg
Jan 18, 2013 | Tunturi T40 Folding Treadmill
I have a tunturi t40 treadmill an error code e7 appears And it cuts out after 5 seconds have tried to calibrate the elevation motor but it won't stay at 9 mm gap when it powers up the gap closes
please test the 2 alternatives for error 7. God bless you
see the diagram attached.
ERROR CODE # 7
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jan 08, 2013 | Tunturi T40 Folding Treadmill
Tunturi t7 showing error 20 !
this means the treadmills power reading when the treadmill was operating at speeds of 1 miles per hour or less . Excessive amount of power is being demanded from the motor controller for an excessive period of time
Causes:treadmill user (especially a heavier user) is standing on the drive belt.
the drive belt too is badly worn.
brush motor faulty
SCR motor cotroller lekay or shorted drive motor or capacitor
IN short RUN the sotware calibration for diagnostic.
Remedies:Lube the deck belt, determine using AC ammeter for the amount of use the current being drawn by the readmill.Replace the drive motor brushes.or replce the motor controller board. see the block diagram
God bless you
Oct 11, 2012 | Tunturi T70 Treadmill
Tunturi t7 showing error 20.
Try to RUN the sotware calibration for diagnostics.
This means user is heavy standing in the drive belt.
Causes: drive belt is worn, brusher motor faulty, motor faulty, motor controller board faulty
Remedies: use AC. clamp for drawn currente entering to the treadmill. Repair brusher and motor. Replace motor controller board.
God bless you.
Hi, We have had our treadmill for about 3 weeks. For the past few days, when we start it up, after about 15 seconds of running on it, it stops and Error 1 shows up on the screen. It is a t40 model. ...
error 1 is a fairyl universal code for treadmills that means your control board has gone bad. Here is a list of things that will cause this to occur:
1. Improper lubrication of belt/deck (too much friction and amperage draw)
2. electrical variance (example: going from US 110 to foreign 220)
3. potentiometer on control board may be set too low (usually blue box with turnable dial) - to change this you would have to turn the dial ever so slightly and test after each movement until the belt starts to run on its own without the error.
other than the above issues you would have to replace the motor control board
Aug 05, 2010 | Tunturi T40 Folding Treadmill
Exercise & Fitness Logo
91 people viewed this question
Top Tunturi Exercise & Fitness Experts
gbob59
Jeremiah Meyer
Jeremiah Meyer
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
