Question about WELLY 2006 Ford Explorer Eddie Bauer White Diecast Model 118 Die Cast Car
06 ford explorer heat want get hot - WELLY 2006 Ford Explorer Eddie Bauer White Diecast Model 118 Die Cast Car
    Genius:
  • 1,669 Answers
Is your antifreeze/water level up to level? Does the switch on the heater hose under the hood move when you move the heater lever in the cab back and forth? Is the heater fan working at all speeds? Check it out!
Posted on Dec 31, 2012
06 ford explorer, zone a/c but only hot air in the front, a/c works fine in the rear zone. Compressor and freon are fine. What do I do?
Blend door operation may be failed. Check for vacuum leaks, check valve failed, door actuator failed.
Jun 28, 2015 | Ford Cars & Trucks
I have a 2005 ford explore my truck is over heating from the rear of the vehicle.anyone have any ideas on what is causing this
over heating from the rear of the vehicle. Can You Plz Explain this ?as ther are a couple of things to get hot in the Rear of You're vehicle
Mar 09, 2015 | 2005 Ford Explorer
NO HEAT
my 2006 ford explor is getting hot but no heat and the cicuration is poor it goes too blocks and red lines
Nov 14, 2013 | 2006 Ford Explorer
2005 ford explorer heat dosnt work
pull back the carpet on the passenger side and check for moisture, if it is wet your heatercore is bad. if no moisture and both hoses going to your heater core are hot it is possible the cable operated door is failing to open. this link should help in both cases http://www.autozone.com/autozone/repairguides/Lincoln-Aviator-Ford-Explorer-Exp-Sport-Exp-Sport-Trac-Mercury-Mountaineer-2000-2005/Heater-Core/Removal-Installation/_/P-0996b43f802e40b6
Nov 06, 2012 | 2005 Ford Explorer
I have an 2002 ford explorer Lost heat just cold air from vents
check raqd level before you do anything else,then if thats ok and hot water in the feed pipes ,then you have a problem with the flaps on the heatert unit ,if so check the vacumn feed pipe from the engine in case its split of broke off
Dec 02, 2009 | 2002 Ford Explorer
Can not turn on my heat..ford explorer
you may have abad hot /cold blend door acuator.its bolted to air box. also make sure both heater hoses going to heater core are hot,if only one is hot and the other is luke warm or cold then you may have a clogged heater core,remove hoses (@ core) and flush with water hose go both ways a couple of times. good luck hope this helps.
Oct 06, 2009 | 2002 Ford Explorer
Cooling system in my 1993 Ford Explorer over heats
change the water pump and check for a blockage in the waterjacket
Mar 09, 2009 | 1993 Ford Explorer Limited
99 Ford Explorer---Heater problem--No hot air?
heater control valve..heater core clogged ..circulation to heater control valve weak restricted or closed..do a radiator flush and fill thoroughly backflushing the heater lines with heater open all the way...if no smell or leaks inside cabin passenger area or losing coolant you should fix teh problem... other issue could be control head not opening blend doors properly
Jan 13, 2009 | 1999 Ford Explorer
Heating control for a 2004 ford explorer
I have a 2004 ford explorer the heat is not working.
Oct 25, 2008 | 2004 Ford Explorer
WELLY 2006 Ford Explorer Eddie Bauer White Diecast Model 118 Die Cast Car Logo
50 people viewed this question
Top WELLY Toys Experts
xkikbxr
Todd Arndt
Todd Arndt
RSole
Are you a WELLY Toy Expert? Answer questions, earn points and help others
