Question about Samsung LN32C450 32 in TV
I have a Samsung TV ln32C 450E1d that I recently replaced the power board. Now the TV comes on but if I turn it off and then try to turn it back on I cannot. I have to wait for some time until I can turn it back on. It is like it has a charge that must degrade before I can turn it back on. Any ideas?
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
  • 610 Answers
SOURCE: 32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
Posted on Dec 29, 2009
  • 927 Answers
SOURCE: Which Replacement Power Board for LNT4665F Samsung LCD TV?
Howdy,
It would be a lot cheaper if you just replace the two caps that have gone bad. Just get a cheap solder pencil from the store and about an inch of solder and you are in business.
The Power Supply Board is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thaks for using FIXYA, BIG IRISH.
Posted on Jan 02, 2010
  • 304 Answers
SOURCE: Samsung TV now takes over 30min to come on
There are a number of Capacitors on the IP/Power supply bd and they have gone bad. Replaced them with the proper Capacitance as the old ones are BUT get the 35 volt Caps. Going from 10v to 35v will fix this problem.
Posted on Apr 16, 2010
brownline45
  • 310 Answers
SOURCE: Samsung LN40A530P1F LCD TV keeps blowing main
good day. your power supply is defective. maybe the regulator is shorted. you need a qualified technician to fix your problem.
Posted on Jun 22, 2010
I have a Samsung TV that will not turn on.
You have diagnosed the fault yourself. The main board of your TV is defective and needs to be replaced.
Good Luck.
Oct 02, 2017 | Samsung Televison & Video
Trying to figure out why my samsung plasma tv clicks when I try to turn it on
Do yourself a big favor and just replace the TV, replacing parts is just to costly and in most cases it doesn't fix the problem.
Oct 23, 2015 | Samsung PN50B450B1DXZA - 50in Ws Plasma Tv...
Why does my Samsung LED TV have sound but no picture?
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 30, 2014 | Samsung Televison & Video
I have a Samsung TV ln32C 450E1d that I recently replaced the power board. Now the TV comes on but if I turn it off and then try to turn it back on I cannot. I have to wait for some time until I can turn...
The problem is capacitance issues. The problem can occur via an associate circuit board, other than the main board that was replaced. If you have test equipment to trace the circuits, then you may find the culprit.
Jan 16, 2018 | Samsung LN32C450 32 in TV
I have a samsung plasma tv modelPs42b430p2wxxu recently it has been clicking a few times when tv has been turned on, tv now constantly clocking so wont turn on or off
The tv power supply board is the problems and the causes.That the board,where the power a/c cord plug in to it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Nov 25, 2010 | Samsung PS42P2S 42 in. Plasma Television
When I turn on my Samsung LE46F86BDX LCD TV it click's for some time. After about 2 minutes the TV starts playing normal. Afterwards you can turn off the TV and back on again. The TV starts normal....
This problems very common on a LCD tv.It the tv power supply board,have bad dying capactors,these capacitors are alway bulges or puffing up on it tops.That the board,where the power a/c cord plug into it.U have all the tools,know basic electronic and can do basic soldering?Just check the power supply board,for those dying capacitors that bulges or puffing up on it tops.Replaced these dying capacitors on the tv power supply board,ur tv will power up normal again and have no more clicking sounds and will not take anymore 2 mins or more to turn it on.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 25, 2010 | Samsung LN-S4692D 46 in. LCD HDTV
I HAVE A SAMSUNG LN46A550P3FXZA LCD TELEVISION. RECENTLY WHEN I TURN IT ON I GET THE BLUE LED POWER LIGHT AND POWER ON ELECTRONIC SOUND BUT NO TV AND NO SOUND. I PUSH MENU AND STILL NOTHING. THIS...
There are many tips already on how to replace the capacitors in these units. In your case it will probably be CM852 and CM853 on the Power supply board. They should say 1000uF at 10Volts on both.
Oct 12, 2010 | Samsung Televison & Video
Red power light is on but TV not coming on keeps clicking as if turning itself on and off????
Try tv unplug,replug it back about an hour later.The tv now,it resetting back to factory setting.The tv now,should work.Not,than the power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | Samsung LE40R74BDX 40 in. LCD Television
Samsung LNR408DX/XAA Wont power up
I had the same problem with a 52" Samsung LCD. I found 2 electrolytic caps with bulging tops on the power supply board. (see pic). I looked to be the 5v section but I'm not sure. I got replacement at Fry's for $1.90 each. All is well!
Ahwatukee Al
Mar 07, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN32C450 32 in TV Logo
53 people viewed this question
Jerry Greenberg
Jerry Greenberg
