Question about Panasonic PT-50LC13 50" Rear Projection HDTV
The picture is off.
The red and blue out line everything on the tv and we tried adjusting the lights in the back but they wont ever correctly match up.
  • 90 Answers
Sounds like you have a convergence problem with the set. Usually will need amplifiers and possibly some resistors replaced. Should be $300 or less to repair by a professional.
Posted on Jan 29, 2009
Color was bad couldn't adjust it better , then last week red curvy lines showed up on the bottom om screen . opened the back and found 6 adjustment knobs slowly turned one and screen went dark. repowered...
sorry but those adjustment are not the right one , to correct the color problem u have frist , u need to hire a tv tech , tv would has to adjust the screen and focus back to normal after that , need to replace the oil on green and blue picture tube
Apr 12, 2010 | Philips Magnavox 9P6034C 60" Rear...
No Color Picture
Are you using the Red/Green/Blue cables or are you using the Red/Yellow/White?
Also make sure you are matching the colors up correctly. If you find that you only have two of the three RYW, try hooking it up to another AV jack on the side or front of the new TV. If you are using the RGB, sometimes in low light settings, the blue and green are easily mixed up.
Another thing you might want to try is changing your settings on your tv for NTSC as it might be set up for PAL.
Dec 15, 2009 | Nintendo Wii Console
Red, Green convergence lines are wavy
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
My tv color is messed up at the top and bottom the thing wont line up its a philips 60pp9202 , wondering whats wrong with it, I tried the multipoint red and blue match up things. The blue is all matched...
My TVs are all old enough that they don't even have the adjustments you've tried. But one thing to look for. CRT televisions are vulnerable to magnets. Do you have any large speakers nearby? Magnets screw up CRT colours.
Mar 05, 2009 | Philips Televison & Video
Lines on the screen
Are they thin, white lines running east to west? If so, they are called retrace lines and indicate that the screen settings for the picture tubes is set too high or there may be a mal-function of the CRT driver circuitry. Try adjusting the screen controls which are located behind the front grill of the TV behind an access panel. Once you remove the grill and access panel, you'll see a small control assembly the has two sets of controls. Three for adjusting the red, green, and blue focus, the other, the red, blue, and green screen controls. To adjust correctly, put the TV on an unused input(dark, blank picture) and adjust until there are no visable retrace lines or color in the image.
michtech
Feb 14, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Rca tv r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
rca t v r52wh73 the picture is bowed at the top and bottom also the colors red green and blue wont match together as one picture
Apr 05, 2008 | RCA Televison & Video
Screen
What you may have needed to do was adjust the green & blue crt screens to match the red. Go into your picture menu adjust, turn color all the way down to a black & white px. Now adjust each crt screen so that you end up with a true black & white px. Then adjust each focus control to get a sharp px, have your tv on a channel like the home shopping network so you can adjust each crt focus one at a time for clarity by cover the other 2 up. Then go back into picure adjust & turn color ahlf way up, you should see a better px.
Jul 01, 2007 | Philips 60P8341 60" Rear Projection...
Sony KP-57WS500 Pictures problem
Your Convergence Correction Amplifier ICs have gone bad (STK329-110) They must be replaced along with the biasing resistors
www.electronix.com has the parts you will need plus I would suggest that you have a qualified TV repair person do the installation for you.
Make sure the traces on the circuitboard are good and that the solder connections are good.
But the ICs and resistors need to be replaced.
Thank you,
Shuttle83
Oct 30, 2006 | Sony KP-46WT500 46" Rear Projection...
No picture coming from red lamp
Sounds like you have two differant problems. A red drive or red picture tube is bad and the conbvergence IC's are bad. To test the red drive disconnect the green picture tube socket BUT MAKE SURE THE SET IS UNPLUGGED!!Then remove the red socket and move over to the green tube. Then turn on the set. If you get the same out of the green then you have a drive problem that needs to be trouble shot for a bad componet. If you do get a picture with the red connected to the green then the red tube is shot. If you know how to read a schematic, get one and then you should have no problem troubleshooting the red drive and the convergence problem. If you dont then there is no easy or quick fix as this is a solid state set and there are no user replaceable parts inside this.,. Your going to need, for safetys sake, call in a trained tech to assist you with this repair
Sep 15, 2006 | Philips Magnavox 51MP392H Rear Projection...
Panasonic PT-50LC13 50" Rear Projection HDTV Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
