Question about Lenovo 3000 J Series 1.80G VBE PC Desktop
Ddc/ci disable This is on my monitor screen. How do I remove or turn off??
  • 230 Answers
Hello there
ok you can go to your bios and check the settings on it while you'll on there. all you have to do is look for this ddc/ci if it's disable then you just enable it. (save it) and reboot. that should take care of your problem if not let me know we can go from there.
ty best regards richard
Posted on Nov 16, 2009
3 Suggested Answers
Justintechno
  • 36 Answers
SOURCE: DDC/CI FUNCTION DISABLE KEEPS FLASHING
This is an error with your computer's video card. You will need to have your computer serviced by a hardware expert.
Posted on Jul 28, 2011
tvrookietech
  • 66 Answers
SOURCE: ddc/ci disable enable
Best and by far easiest method would be to make use of "System Restore". Simply restore your computer to an earlier time - you want to restore the system to a time as close to the current date as possible but at the same time - restore it to a time/date that to your recollection, would be before this problem on your desktop occurred.
Not sure if you are familiar with system restore so here's the click path to get you there:
...from your desktop and with all programs closed:
1) click on <start>
2) point mouse to < All Programs>, <accessories>, <system tools>
3) when mouse is pointed at <system tools>, navigate mouse down
the list to where you see <system restore> and click on it.
from there, just follow the on-screen instructions and pick your restore point by the calendar that will appear.
Should solve your problem as there is a key stored in the windows registry which may be very difficult to decode otherwise.
Posted on Jan 07, 2010
My mointor just flashes different colors and won't turn off
If you can find a setting for DDC/DI and turn that OFF, this could solve your problem (it did for me).
Description of the setting is included below, but put simply it allows your monitor to communicate with your computer and make adjustments.
From wiki: The Display Data Channel or DDC is a collection of digital communication protocols between a computer display and a graphics adapter that enables the display to communicate its supporteddisplay modes to the adapter and to enable the computer host to adjust monitor parameters, such as brightness and contrast.
Mar 04, 2013 | Hyundai Electronics W240D LCD Monitor
DDC/CI FUNCTION DISABLE KEEPS FLASHING ON THE MONITOR
Jul 28, 2011 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Vga cable color code of 17" monitor of samsung SyncMaster can u send color code pichear
1 - Red
2 - Green
3 - Blue
4 - NC
5 - DDC Return
6 - GND (R)
7 - GND (G)
8 - GND (B)
9 - NC
10 - GND-Sync/Self raster
11 - NC
12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
The wire colours in the actual cable are:
Red (foil wrapped with 1 bare ground wire)
Green (foil wrapped with 1 bare ground wire)
Blue (foil wrapped with 1 bare ground wire)
Transparent (foil wrapped with 1 bare ground wire)
All the above go to the corresponding Gun Color, the Bare wire goes the one GND pin.
Purple
Yellow
Black
Orange
White
Bare braided outer ground wire. Combine ALL earths to a single point.
You will have to open up the unit, to see what colors are used for the 5 - DDC Return 10 - GND-Sync/Self raster 12 - DDC Data
13 - H-Sync
14 - V-Sync
15 - DDC Clock
Settings they are marked on the motherboard.
Aug 03, 2010 | SAMTRON 55V 15" CRT Monitor
I have an old acer monitor model 7134T, the problem is its 15-pin connector (that plugs into cpu) is broken and i want to repair it. Can anyone tell which color wire goes to which pin #?
A female DE15 socket (videocard side). Pin 1 RED Red video Pin 2 GREEN Green video Pin 3 BLUE Blue video Pin 4 ID2/RES formerly Monitor ID bit 2, reserved since E-DDC Pin 5 GND Ground (HSync) Pin 6 RED_RTN Red return Pin 7 GREEN_RTN Green return Pin 8 BLUE_RTN Blue return Pin 9 KEY/PWR formerly key, now +5V DC Pin 10 GND Ground (VSync, DDC) Pin 11 ID0/RES formerly Monitor ID bit 0, reserved since E-DDC Pin 12 ID1/SDA formerly Monitor ID bit 1, I²Cdata since DDC2 Pin 13 HSync Horizontal sync Pin 14 VSync Vertical sync Pin 15 ID3/SCL formerly Monitor ID bit 3, I²Cclock since DDC2
Feb 16, 2010 | Acer Computers & Internet
Ddc/ci disable enable
1) click on <start>
Jan 07, 2010 | Lenovo 3000 J Series 1.80G VBE PC Desktop
I am looking for a monitor driver for Windows Vista for LT1919
Windows XP and Vista should "auto-detect" the capabilities of this LCD screen.
If not, access http://WindowsUpdate.Microsoft.com
and scan for updates.
When the scan is done, look for "optional hardware" updates.
If Microsoft has a driver, it will be offered for download.
Nov 20, 2009 | Mag Innovision Computers & Internet
Dual monitor, Intel 82915G & nVidia RIVA TNT2 64, FC6, Dell Gx520
Here is a little guide for setting up dual monitors with fedora core 6: http://blog.taragana.com/index.php/archive/how-to-setup-dual-monitors-on-linux-fedora-core/
I haven't had to use duals monitors with Linux yet but if this doesn't work let me know and I'll run some tests as I can easily set this up at work (we use the same computers and similar cards).
Jan 12, 2009 | Dell OptiPlex GX280 PC Desktop
Dual monitor, Intel 82915G, ATI Rage 128 card, FC6
the ati chip is not so good dual monitor so please use nvidia for dual monitoring
Jan 09, 2009 | HP ATI FireGL4 (128 MB) Graphic Card
Acer X243w monitor as a TV Pic great but "not supported" box
My assumtion is that the monitor is not displaying in 1920x1080 but has defaulted to a resolution that it can handle so as to display something. Step down the resolutions on the monitor until the gray box disappears. If you're satisfied with the picture your watching then hopefully you will be happy when you find the resolution the monitor is actually displaying.
Sep 19, 2008 | Acer Computers & Internet
Lenovo 3000 J Series 1.80G VBE PC Desktop Logo
4,130 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
