Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
COLOR TONE LINES IN PICTURE
THE COLOR IS NOT TRUE AND THERE ARE LINES THROUGH THE PICTURE MOSTLY THE SUBJECT OF THE PICTURE . I HAVE A KODAK EASY SHARE 5300 ALL IN ONE PRINTER HELP
  • 45 Answers
You have a bad printhead. It is a known defect and Kodak will send you a new printhead.
Posted on Jan 21, 2009
I have a Kodak Easy Share CD82. What do the designs on top of the dial mean there is one red design What does that mean?
In order, starting with the "P"
P - Program - Access to more manual settings than Smart Capture mode.
"hand" - Blur Reduction - Reducing blur caused by camera shake or subject motion.
"VIDEO" - Capturing Video with sound
(red colored camera) - Smart Capture - General picture taking - it offers excellent image quality ad ease of use. The scene is analyzed for other content and for lighting. You can choose the best picture size and aspect tatio for your needs - just press the Menu button and choose picture size.
"Flower" - Close up - Use available light instead of flash, if possible.
"Sport" - Subjects that are in motion.
"SCN" - Scene - Point-and-shoot simplicity when taking pictures in practically any situation.
You can download the PDF file by Googling your camera make and model. I'll try adding it here with the link. You might have to copy and paste to your own browser.
Hope this helps. Mike
[PDF] KODAK EASYSHARE CD82 Digital Camera resources.kodak.com/support/pdf/en/manuals/urg01070/CD82_xUG_GLB...
KODAK EASYSHARE CD82 Digital Camera Extended user guide www.kodak.com For interactive tutorials: ... Use power-saving features (see Using the Setup tab, page 28).
Sep 25, 2015 | Kodak Easyshare CD82 Digital Camera
I understand that the flash is different in the iPhone 5S, how?
The Camera on the new iPhone 5s is improved. The new flash is called smart "True Tone" flash that can sense the coloring of your subject and choose a flash color to match it.
Sep 11, 2013 | Apple iPhone 5S
Reddish w/ horizontal lines on pictures when review on its LCD.
You no need to fix this problem. This is a CCD failure and in some cases had been subject to a recall.Contact Kodak support this may be one of the recalls and replacement camera could be on its way. They will do it for free of cost.
Thank you !!
Jul 13, 2010 | Kodak EasyShare MD853 Digital Camera
Pictures turn out pink & with lines in it.It also displays this on the screen when previewing pictures.Old pictures on the memory card still look normal on the screen when reviewing them. The camera...
Try to reformat your internal memory, and then turn On the camera and use the auto mode or smart scene mode. Take a two pictures on a same subject then review the pictures after, now if the two pictures has lines on it and it has a pink in colors it means that the lens of the camera is defective that`s why it will not take a good picture. Please call kodak 1 800 235 6325 so you can request for repair
Nov 22, 2009 | Kodak Easyshare M753 Digital Camera
Yellow lines appear in picture after taken. Picture color is way off even when lines are not very apparent. Does not do this all the time! Picture quality is excellent when all is well!! Whats up??????
Ok dont worry about that, first thing you need to do is to remove the memory card., Turn On cmaera wothout memory card, now press menu button and go to setup menu and under setup menu please look for format then press Ok, under format please for mat the internal memory.
Now if you already reformat the internal memory, take atleast 3 pictures on a same subject., then hit review if the lines appeared on both pictures on same location, it means camera needs of service please call Kodak toll free 1 800 235 6325., For U.S and canada support. Gudluck!
Nov 03, 2009 | Kodak EasyShare Z612 Digital Camera
What is and how do i adjust the white balnceon my fujitsu S550 digital camers?
Adjustment is in the menu screen, you shouldn't have to go very deep as it is a frequently adjusted setting.
White Balance is how the camera interprets white depending on ambient lighting. Have you ever noticed how when you are taking pictures inside at night and all of the light comes from lamps and the flash that your pictures have a yellow look? Take a picture under flourescent lamps and the pictures look different as well? How about outside? Best true color rendition on the picture taken outside, but different than the others.
White balance is a way for the photographer to adjust the tone of the picture to accurately reproduce the true colors seen in real life in the picture. Most cameras have an automatic white balance and they usually work fairly well. But for the best results, set it manually. Your whites will be white and skin tones appear accurate.
Hope this helps! Good Luck!
Oct 06, 2009 | Fujitsu Cameras
MY KODAK 5300 PRINT PICTURES WITH RED SKIN TONES
The Cyan-yellowish color has either dried up or has bad nozzles. Take out the color cartridge and put in on a glass dish with 1/8 inch of warm water on it. After 5 minutes, wipe it dry with tissue paper or paper towel and try it in printer again. You'll probably need a new color cartridge, there is a large failure rate of cartridges from the mfg. and re-mfg.
Jun 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
The skin tone is very red and blotchy, not true to color.
You have a mode you place your camera in for either landscapes,portraits, etc.. There should be a switch on top of the camera that allows you to select this. Normal or standard is the best setting to leave it on!!
Jan 01, 2009 | Kodak Easyshare C813 Digital Camera
Pink lines/dots in pictures
Pointing a digital camera directly at the sun can damage its sensor. You should have the camera checked by a qualified repair facility
Aug 30, 2005 | Kodak EasyShare DX4330 Digital Camera
Photo colors are not true on my new Kodak....something wrong?
The Kodak CX4310 is the same as the CX4300 but the 4310 is a Wal-Mart special color. The camera feature that controls color balance is called "white balance" and on the 4310, it is totally automatic. Which means you have no control. If your color is not correct, return the camera. There are not many cameras that use a dock to recharge the camera batteries and connect to the computer. So you will not have many choices if you are looking for a different camera. One camera (without a dock) you should look at, is the Olympus Stylus 300. It is a better choice than the Kodak. It uses rechargeable batteries and the charger is included.
Aug 30, 2005 | Kodak EasyShare CX4310 Digital Camera
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
83 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
