Question about Drills
I have a Bosch 14.4 driver and with full charge I han hold the chuck an prevent from spinning when on drill speed. Can I fix this?
I also have a similar issue with two small 12 V AEG drivers whereby you can hold the chuck and it just clicks away. Would new brushes fix this or have I bought duds?
  • Andrew Sinclair Jan 02, 2013
    T The driver has 50Nm of torque and thats my problem. I should not ba able to hold the chuck and stop it from turning when set to the drill setting. I'm wondering if new bushes may fix or is the drill a dud? The two AEG 12V drills have the same issue
    Genius:
  • 1,669 Answers
Battery powered drills generally are much weaker thah house current drills. With that in mind, realize that they aredrills and not intended to be power screwdrivers! The less the supply voltage, the less the torque (turning power). They are suppurb at doing small jobs where torque is not an issue, like using drill bits through wood, etc!
Posted on Dec 31, 2012
3 Suggested Answers
comax
  • 154 Answers
SOURCE: Bit stuck in Bosch PS20 keyless chuck
These units have only been out for a short while and most are on warranty. Take it to a Bosch Service center in your area and they will replace the front of the unit. Unfortunatly this is a problem with this type of unit. The bit will deform slightly from the impacting action and lock itself in the chuck.
Posted on Apr 13, 2009
rowdy45176
  • 2176 Answers
SOURCE: chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Posted on Jun 27, 2009
On my BOSCH CSB 470-RLE 470w electric drill the chuck is slipping i can hold it in my hand and it wont move
It is a spring loaded hammer drill. You need to push the chuck down just a bit for it to engage the clutch. If it is still slipping then either the clutch pieces (items 23 and 32) are worn or item 32 is spinning freely on the spindle shaft. Here is a parts diagram.
Bosch CSB470-RLE diagram
Aug 16, 2012 | Bosch Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
How do i remove the chuck from a ridgid hammer drill
Remove the REVERSE-THREAD screw at the bottom of the chuck. Set the clutch collar to the highest setting, and set the gear to the slowest setting if this drill has a 2 speed transmission. Remove the power source! Get the biggest allen wrench you can fit in the end of the chuck(the shortest leg) and tighten the chuck down around it, allowing the jaws to rest and tighten on the flats of the wrench. Lay the drill on its side(chuck toward you, handle to the left, and allen wrench to the left, horizontal to the deck. Then with a hammer(soft hammer if you care about the allen wrench) quickly and deliberately hit the allen wrench in an attempt to cause the allen wrench to spin counter clockwise. Let me know if this works for you!
Jun 27, 2010 | Bosch HCBG500, 5 Pc Industrial Hammer...
How to use hand drills?
Use of both is the same:
- loosen "chuck" (part where bit is installed).
- insert bit (hand tighen chuck so that bit is secured)
- tighten chuck securely with chuck tool, or by holding rotating chuck with hand and pulling trigger (GENTLY or you will shave off skin!)
- put drill in forward or reverse mode and pull trigger to inser or remove screw / drill hole.
ensure that battery is charged on cordless drilll.
squeeze connectors to remove and place in charger when battery is too low to operate drill.
Apr 27, 2010 | Bosch 14.4V Brute Tough Drill Kit
Bosch keyless chuck stuck
Make sure you try it in both directions.
Apr 18, 2010 | Black & Decker 3/8" Variable Speed...
Drill is stuck in chuck, and cannot be removed.
try using two sets of mole grips one on the small par tof the chuck and one on the large and try turning it with them it should come out
Jan 22, 2010 | Bosch 1/2" 6.5 Amp High Speed Drill With...
How do you replace the chuck on a Bosch 650 RE
while holding the drill like a gun, hold the lock button REALLY tight and pull the black part to the right really hard. this will unlock the chuck and if you keep twisting the black part to the right it will loosen it enough so that you can remove it
Jan 03, 2010 | Bosch Drills
Trying to remove a jacobs key less chuck 500 series fitted to a DS18DL Hitachi drill
It twists off counter clock wise. The best way I have found to remove the chuck is to stick a screw driver into the chuck, tighten the chuck, hold the screw driver in some type of vise and run it all full speed in reverse
Jan 02, 2010 | Hitachi DS18DMR 18V 1/2" Driver Drill
I have a Bosch PSR12 12V Cordless drill, but no instructions.
This drill has a keyless chuck. Put your bit in the chuck and hold the collar of the chuck while pressing the trigger in the forward position. To undo the chuck do this in reverse. You can also hand tighten the keyless chuck if you prefer. I have a 1/4' adapter that I keep in my drill so I can change bits quickly.
Sep 09, 2009 | Bosch Drills
Drills Logo
37 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
