I get feed back, distortion, or some kind of broken up signal, on one deck only. I've replaced both stylus'. Problem only occurs while using serato.
  • prwonderkid Jan 19, 2009
    Thanx Bro, I appreciate it. I have uninstalle, and reinstalled, but i have'nt yet tried a diff. version. Thanx fr the tip. Peace.
  • thewiz33 May 26, 2009
    I had the same problem, check your computer, if you have an amd athlon processor like I do then there is a hardware problem that causes serato to not track one turntable and cause distortion one one deck only. Serato knows about the problem but they currently have no solution. I was about to send my SL1 back to the factory, thinking it was faulty, until I stumbled upon someone with my same problem in the FAQ section of the serato website.
  • 476 Answers
Have you tried to uninstall serato and reinstall
It sounds like the version of serato may have issues with it.
Could be worth a try,
this seems to run well for most people that use it,
so I would be looking at the version you have and the equipment its attached to,
to find out if they are compatible,
Any issues should be reported to Serato so they can rectify,
I know an Agent in New Zealand who is a reliable source of information and may be more help if needed,Please let me know thanks
Misterdj
Posted on Jan 19, 2009
Tascam 122 Mk III - input signal is low and distorted
It is hard to guess what is causing this but for all of the gain to be reduced like that either the deck has seen some really high input signal in the past that blew out some amplifiers or that there is a power supply component that has taken the input electronics down.
I suspect that you will need to have a Technician look at it. If you are near Chicago, I may be your answer, I have been working with these Teac units for 40 years and was a Lead Tech at Chicago Factory Service in Arlington Heights.
I can be reached at skywavebe@sbcglobal.net
If you are far off- I have other people that can do the job one in New Jersey and a few others.
Aug 14, 2012 | Tascam Audio Players & Recorders
I use my Sl1200 with Serato and the other day one of the decks was starting slow. I solved the problem by spinning the record first and then placing the stylus down. But I want it to go back to the way...
p { margin-bottom: 0.21cm; }
HI,
After long years of use the electrolytic capacitors in the circuitry will get slightly change its value. If so it can affect the speed of the turntable. Its better to replace all the electrolytic capacitors in the turntable's electronic circuit board. It will not coast a lot for all the capacitors. Will only come around $3 or $4. .
OK
Oct 28, 2011 | Technics SL-1200MK2 Turntable
All is fine with this turntable eccept for the fact that when the sound comes through the speakers you can make out the track but the sound is distorted.
Hello
You don't say whether you have only just acquired this deck or if you have been using it for some time and it has only now started to give problems.
There are 2 or 3 possible explanations.
  1. If you have only just got this deck and are using it on a stereo that has a dedicated phono (record player) input it may be that you need to get inside your turntable to turn off the built in pre-amplifier switch. To do so make sure the tone arm is securely fixed into it's holder (a rubber band will hold it in tightly) before turning the deck upside down and unscrewing the bottom.
  2. If you have just got this deck and are trying to play it through a stereo system that does NOT have a dedicated phono (record player) input you may need to get inside the deck to turn the phono pre-amplifier switch on.
  3. And if the deck has been used for some time this is the most likely - the record stylus (needle) probably needs replacing. Personally, although it is a bit more expensive, I prefer to replace the whole cartridge rather than just the stylus as they do need changing from time to time anyway. Always replace the stylus at least at the frequency recommended by the manufacturer. Regularly clean the stylus with very gentle strokes from the back towards the front using a small soft brush.
Feb 02, 2011 | Aiwa PX-E860 Turntable
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
Tonearm not emitting signal into Serato
there is a switch that cuts off the signal when the tone arm docks.check the wiring is not broken inside and that the switch is ok.typically,red green white black red and white are plus and left ground is green and right ground is black.the collar that screws on to the head unit has 4 pins.make sure the contacts are clean.measure the wires one at a time from the tone arm to the rca plugs on the back.the green and black go to the outside collars,and the red and white go to the center pin of the rca plugs
May 26, 2009 | Technics SL-1200 Turntable
Distorted sound, Low signal, unable to use deck with serato.
I just want to clarify the way you have your gear set up.,
Normally this is enough to annoy anyone.
Having set all the equipment up,this is what I would do.....
Try without Serato
Firstly I would set the records & platters and then the counterweights,
Then I would do an audible check.Headphones,Monitors and then front of house system
If this passes I will then set the room levels for comfort and then the eq band gets a tune up for the room,
If this set up procedure works then connect Serato,
If problems persists then Uninstall Serato and Reinstall.
Try Again if all else fails ......
www.serato.com they have a contact us,report the problem.
Hope this helps ,If you need more help please let me know,Misterdj
Jan 18, 2009 | Technics SL-1210 Turntable
Song playing backward but table going foward with serato.
hi... swap the left and right rca cable.the one who said it works good on the deck but on the screen goes back ward....see what hapen..u
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Axis 9
i have exactly the same problem, its annoying
1 thing which works is holding the button down then spinning the deck round, let go, turn off the scratch button, press play and turn on the scratch button again
Jan 15, 2008 | Nu Mark AXIS 9
210 people viewed this question
 Grubhead
Grubhead
