Question about D-Link DIR-615 Wireless Router
Dlink 615 is it wps or not wps
I need to know if this model of d link is (wps) wifi protected or non wps
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
  • 81 Answers
SOURCE: How to configure D-Link Wireless Router 615 on LAN ?
The following procedure should get you a connection with any broadband modem that is configured to use DHCP for the router connection, such as cable modems, and many DSL modems. If you require PPPoE configuration for the DSL modem, that will have to be configured to match the ISP requirements.
Note that the wireless encryption and channel selection will have to be done after the basic wired connection is established, the first step is to get wired connections working.
  • Reset the router to factory defaults by holding the reset button down for 15 seconds with power on.
  • Turn off everything, the modem, router, computer.
  • Connect the modem to the router's WAN/Internet port.
  • Connect the computer to one of the router's LAN/Network ports.
  • Turn on the modem, wait for a steady connect light.
  • Turn on the router, wait for two minutes.
  • Boot the computer.
When the computer is completely booted, let's see this.
Hold the Windows key and press R, then type CMD (COMMAND for W98/WME) to open a command prompt:
NOTE: For the items below in red surrounded with < >, see comments below for the actual information content, they are value substitutions from the previous command output!
In the command prompt window that opens, type type the following commands one at a time, followed by the Enter key:
IPCONFIG /ALL
PING <computer_IP_address>
PING <default_gateway_address>
PING <dns_servers>
PING 206.190.60.37
PING yahoo.com
Right click in the command window and choose Select All, then hit Enter to copy the contents to the clipboard.
Paste the results in a message here.
<computer_IP_address> - The IP Address of your computer, obtained from the IPCONFIG command above.
<default_gateway_address> - The IP address of the Default Gateway, obtained from the IPCONFIG command above.
<dns_servers> - The IP address of the first (or only) address for DNS Servers, obtained from the IPCONFIG command above.
Posted on Sep 22, 2009
  • 85 Answers
SOURCE: dlink dir-615 won't power up. I think maybe it
Have you checked the power supply to see if it is supplying the rated voltage to the plug that plugs into the router. It should be somewhere around 5 - 15 VDC. That's a great place to start. If you have voltage there then repair of the router will require someone with knowledge of testing ICs and soldering.
Posted on Jan 15, 2010
  • 105 Answers
SOURCE: How do I secure the router so that no one else can
You should follow the next steps:
1. Log in via http://192.168.0.1
default username: Admin (use admin if it doesn't work) password: (leave it blank with no password) ----- 2. Go to setup tab ----> internet ----> internet connection wizard 2.1 CHANGE PASSWORD ! click next 2.2 choose time zone. 2.3 Configure your Internet Connection DHCP Connection (Dynamic IP Address) Choose this if your Internet connection automatically provides you with an IP Address.
2.4. press "clone your computer's MAC address" ; hostname: 'your computer name'
3. Go to setup tab ----> wireless settings ----> Wireless Network Setup Wizard (after this we're gonna do manual settings) 3.1 give your network a name= SSID 3.2.Automatically assign a network key (Recommended) and chose WAP or WAP2 3.3 Write down the network key Or do printscr and save this page.
You can leave it here, but it's better if you continue with the next step: -----
4. Go to setup tab ----> wireless settings ---->Manual Wireless Network Setup 4.1
Wireless Network Settings Enable Wireless : ALWAYS Wireless Network Name : (Also called the SSID) the name you gave in 3.1 802.11 Mode : chose "mixed 802.11n,g and b" Enable Auto Channel Scan : YES Wireless Channel : AUTO Transmission Rate : BEST (Mbit/s) Channel Width : AUTO 20/40 MHz Visibility Status : !!!Invisible!!! (so that no outsiders know your SSID except you)
4.2 Wireless Security Mode : WPA-Personal
4.3 WPA mode: WPA2 only Cipher type: AES Group key update interval : 3600 seconds
4.4 Pre-Shared Key : the one that you generated in 3.2.
Now you're all set, but you can't see your network from your PC (as you set it to be invisible in step 4.1). Now you'll have to set it up manually (the specific instructions will depend on your operating system) You'll need to enter the following date when you set it: your SSID name that you entered in 3.1 wireless security: WPA2 personal type: AES enter password that you've generated in 3.2 (or 4.4).
Posted on Oct 19, 2010
puertobori
  • 7733 Answers
SOURCE: D-Link Dir-615 do not connect
Step 1: Open your web browser and type in the IP address of the router (192.168.0.1 by default).
Step 2: Enter the username (admin) and password (blank by default), and then click Ok or Log In .
  • How do I find my routers IP Address, in Windows XP?
  • How do I reset my router back to the factory default settings?
    (NOTE: To reach the configuration page of your D-Link router in Mac OS, you will need to use a Java compatible browser such as Firefox or Camino.)
    (NOTE: Some routers have a "Captcha" graphical login option. This option can be disabled in the advanced options of the routers configuration.)
  • Posted on Nov 20, 2010
    I have Dlink DIR-615 Hardware Version: C2 Firmware Version: 3.01 and want to upgrade firmware as it hangs when i use my Samsung Tab2 over wifi...
    The new firmware is available with instructions at Dlink's Website.
    http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
    This is the english address for the support on your model of router.
    Feb 01, 2013 | D-Link DIR-615 Wireless Router
    I just want to set up an internal network with dlink router
    To setup a network just follow the step by step guide that came with the DIR-615 router. When it comes to setting up the internet on the router wizard just select Cable or DHCP and leave the other internet settings as default.
    As regards to your printer we need to know the make and model number so we could further assist you. By knowing the make and model of the printer it will help us how to best setup your printer on the network. The model number is usually the name of the printer or near barcodes on the back or bottom of the printer.
    Dec 17, 2012 | D-Link DIR-615 Wireless Router
    How to connect TP LINK TL-WA901ND with Dlink DIR 615
    Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
    Also DHCP server is where ?
    IN the TP LINK TL-WA901ND or in DLINK DIR 615
    Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
    What subnet mask are you using is it the same through out all devices ?
    Oct 30, 2017 | TP-LINK TP link TL-WA901ND 300 / 11n...
    I am trying to hook up a netgear universaL WIFI INTERNET ADAPTER to my tv and it says to push the WPS button on my router and i dont know what to push
    The dlink dir 615 wireless router hasnt got wps. So its no good trying to connect it via that way you can only do it via wep or wapor wap2 here is a link to the manual for your router http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
    Mar 11, 2011 | D-Link DIR-615 Wireless Router
    Where is the WPS button on my router
    i am trying to set up my Kodak ESP Office 2150 series printer, scanner, copier, fax. It says to enter PIN on my router, but I do not see any buttons to enter. Help me please!!
    Does the d-link airplus xtreme g model DI-624 support WPS?
    yes there is RESET or WPS button for RESET all settings to factory defaults. For that press RESET/WPS button for 1 seconds it is in the back side of router. Then all settings defaults . You need to configure your router with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. Then set WAN settings as internet service provider settings enable DHCP. .Click on wireless and enabled it. Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa.
    Mar 03, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
    After 3 days of trying, I still cannot access the online setup page for my DIR-615 router. I had to reset the router as our password was lost, and have been trying to reconfigure it since then. Everybody...
    OK, have you tried to reconfigure after resetting with a non password protected mode just to see if it can connect to your laptop or other computers on the wifi network that way?
    http://d-link.com/products/?pid=DIR-615&tab=3
    The above link says there are multiple versions of the D-Link 615 router.
    Maybe you can read over the FAQ's for your revision.
    Oct 28, 2010 | D-Link DIR-615 Wireless Router
    Lost Network Key
    if it supports WPS[ wireless protected setup] then you can add new device, if not you need reset router to fabric settings and re-setup it
    Sep 22, 2009 | D-Link DIR-615 Wireless Router
    Side Button - Blue Light
    every time you press the flashing blue button someone you dont know will die and you will receive $1000000 dollars, oh wait that was the plot to a **** movie. It's for hooking up other computers or devices that are wps security enabled.
    Dec 05, 2008 | D-Link DIR-625 (790069292637) Wireless...
    D-Link DIR-615 Wireless Router Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
